1986 - 1993 Ford Mustang Steering Column Ignition Switch Lock Actuator
This replacement Steering Column Ignition Switch Actuator Lever is just what you need to get your Ford & Mercury vehicle in good working condition again!
It mounts inside the steering column and connects the ignition lock (where the key goes) to the internal ignition switch. When the key is moved to any position, this lever moves inside the steering column, and is what turns the ignition switch on or off. It has a small pin attached to it and if that breaks off, you will be unable to start the vehicle. This part is commonly broken when vehicles are stolen. It also is the cause of why some ignition switches will not move. If any part of this lever is broken, the key will be unable to move!
If your vehicle is having problems starting because of a bad or malfunctioning ignition switch actuator lever, this is the part for you!
1A Auto Parts Offers FREE SHIPPING On All Orders.
Diode Dynamics
28
05-26-2022 12:02 PM
NorthAmericanTuning
11-09-2016 11:45 AM
NorthAmericanTuning
03-18-2016 11:21 AM
NTO_GUY
12-24-2015 11:23 AM
08-10-2015 01:44 PM
