Overspray
Overspray
Does anyone know the best way to get overspray off of a hood? It is very "gritty".
I need to get it off before I put vinyl stripe on so I don't think I want to polish it off. And I especially will not be putting wax on it.
If it's just the hood, claybar it.
Buffin' makes a mess and you have to be **** about cleaning residue.
It's a real pain to clean dry compound off in nooks and crannies.
You could always tape the car to prevent that...
Clay bar is an option...
From our experience the best way to remove overspray, expecially heavier overspray that claybar will not remove is to buff the car.
Buff the car using a foam cutting pad with rubbing compound. Then hit it with swirl remover on a black waffle pad.
In past we've also just used a black waffle pad with 3m Ultrafine SE. Takes overspray right off and leaves surface like glass.
