Door Panel Leather Sagging - **FIX**
#211
My passenger side had been loose in the middle for a while...then the edges started coming out. now it has flopped all the way down...the drivers side is loose in the middle....time for this fix. I remembered reading it for the 1st time.....a long time ago.
#212
Easy peasy fix, make sure you clear all the loose backing from the panel, 2 coats of weldwood per the instructions, seat the leather firmly with a seam roller or something like that. Tuck the edges in with the tip of a flat head screwdriver. Follow the OP's instructions to the letter and you won't have a problem.
#213
Actually I'm not going to use the weldwood contact cement. I'm going to mask the door panel more and use 3M 38808 Fabric and Headliner Adhesive
I'm sure they are both "Contact cement". But the 3M will not discolor the fabric, not that that would be a problem with the task at hand. But the simplicity of 'Spraying" a even coat of glue pushes me toward using this product.......+ It's known that 3M makes very good products and this product is especially designed for the task at hand.
Features & Benefits
Exceptional strength bonds heavyweight automotive materials. Bonds to fabric, headliners, and foam. Dries in 30 minutes.
Provides exceptional adhesive strength
Bonds heavyweight automotive materials to fabric, headliners, and foam
Adhesive dries in 30 minutes, allowing for easy and quick repairs
#220
I used the 3M that is recommended in many videos and instructionals. I applied this just at a year ago, probably a month and a half after your post, and it has already fallen down again. Has yours?
