DRAG SPOILERS WITH STRUTS...
Old 12-06-2009, 05:38 PM
mike castaldo
mike castaldo's Avatar
Default DRAG SPOILERS WITH STRUTS...
i get alot of pm about my spoiler i thought i help yall out on where it get it.. THERE R DIFFERENTS ONES YOU CAN BUY
http://www.edquay.com/
STANDARD
PROMOD
FULLBODY
the one on my mustang is the standard one..
mike castaldo is offline
Old 12-08-2009, 10:55 AM
-SHIFTY-
-SHIFTY-'s Avatar
Yep Yep, I love the look of this wing and am really thinking about going this route.
Mind elaborating a bit on the specifics of the wing you ordered and what all it took to get that sucker mounted. Any more info on installing and ordering would be greatly appreciated.
-SHIFTY- is offline
Old 12-09-2009, 05:37 AM
mike castaldo
its very simple to install.. comes per drilled holes.. all you have to do is line it up on the truck.. drill a couple holes and revit it down.. not hard at all.
to me level of install would be a 1.. tools needed 5/16th drill bit, philp screw driver, revits and revit gun.. when mounting mine i use alil silcone under the spolier where the holes where drilled.. help to hold it better and no leaks at any holes drilled..
the 2 mounting holes for stock wing if you had it just remove i used some plastic gromlets from auto zone also silconed on.. hope this helps..
Old 12-09-2009, 09:31 AM
-SHIFTY-
-SHIFTY-'s Avatar
How about them struts - do they attach to the backside of the trunk or the bumper. Can you still open your trunk? Do you have to drill holes for the struts??
Thanks
-SHIFTY- is offline
Old 12-09-2009, 06:05 PM
mike castaldo
Thanks
top part of strut mounts to spoiler and bottom you can mount on bumper or trunk.. you can cut the struts to fit where you want.. ya you can still up trunk.. just remove the drop pins that hold the struts to the spoiler mount at top of strut.. and yes you drill holes in bumper or trunk where ever you like..
Old 12-09-2009, 10:00 PM
-SHIFTY-
-SHIFTY-'s Avatar
appreciate it man!
-SHIFTY- is offline
Old 12-10-2009, 04:17 PM
mike castaldo
not a problem..
belam
05-06-2016 06:24 PM
Florida Regional Chapter
09-30-2015 08:04 PM
guitarman376
09-30-2015 05:54 PM
GLOCKer
09-28-2015 07:36 AM
Mr. D
09-17-2015 08:17 AM
Quick Reply: DRAG SPOILERS WITH STRUTS...
