Agent 47 Mirror install help
I am having a problem removing one of the nuts holding the stock mirror in place. I was able to remove two of the nuts holding the stock mirror in place. The 1st one I was able to use a socket, the 2nd I had to use a wrench, but the third one I can't use either. The socket is too big to fit in between the door panel and the nut and the wrench doesn't seem to work.
Im not sure exactly what the problem is as ive never installed mirrors but i do know the door panels are easy to remove. Just a few screws around the perimeter and one by the handle if i recall correctly. You might need a special bit if i recall correctly.
i'm assuming you are talking about the 3rd one, the tough one. i used a wrench, i forget the size, but it worked just very very tiny turns, probably took me about 15 mins just for that one. just keep trying the wrench, maybe even a different size and it will eventually come off, remember it will also be a p.i.t.a to resintall the agent 47s
Finally got them installed. A flex wrench worked well. The biggest PITA was removing the wiring from the old mirrors. I used a little too much force on the drivers side and broke one of the wires. Good ole electrical tape should fix it.
I will keep them unpainted. I'll post pics later.
