GT500 Hood Vent
Old 12-27-2009, 04:38 PM
Import_Slaya
Import_Slaya's Avatar
Originally Posted by Sleeper_08
How far back did you mount it?
How did you decide where to mount it it?
19.5" from the front tip of the hood to the front tip of the extractor flange. I wanted to maximize the heat extraction function. Low pressure area is forward on the hood, with the base of the windshield being a high pressure area. It's basically as far forward as it can go while still being behind the radiator and fan housing.
Originally Posted by Tylus
thanks for the link. I've been contemplating hood vents since I bought my car...but I was hoping more for 1 on each side...but Shelby won't sell them, and refuses to give me a part #
Another route I considered after getting this in hand was ordering a second one, then cutting out both center sections and mounting them Shelby/Cobra style as two separate vents. Something to consider...
Import_Slaya is offline
Old 12-27-2009, 08:40 PM
Sleeper_08
Sleeper_08's Avatar
The idea of getting two and mounting the center sections is also interesting.
I'm actually more worried about high underhood temps with the SC just running around town in the summer in stop and go traffic. The track benefits would be a bonus
As my car is white do you think it would be possible to paint the scoop?
Sleeper_08 is offline
Old 12-28-2009, 12:16 AM
Tylus
Tylus's Avatar
maybe...not too sure how that would flow with the body lines though. the lines along the cut would be pretty sharp compared to the softer rounded edges of the hood
I did see a few months back where a Fox body guy adapted that scoop. wish I was 1/2 as skilled as him.
Tylus is offline
Old 12-28-2009, 02:37 PM
zero2sixd
zero2sixd's Avatar
Awesome job. Looks great and functional too. Those don't often go hand in hand. It's got me thinking about taking power tools to my hood again.
I thought I was done with that business after installing the hood pins; which really just cured the symptom (floating hood) instead of the cause (high under-hood pressures).
Out of curiosity, why not just modify the hood to the point that it would accept the way the piece was intended to be installed? If I read correctly, that's with some sort of keeper flange in the front, and a bolt/adhesive tape in the rear. Would it have required too much modification to the various supports/molded shapes under the hood?
Which brings up another question I had...did this weaken the hood in any significant way? It looks like you had to cut right through some fairly substantial supports.
zero2sixd is offline
Old 12-28-2009, 03:52 PM
zero2sixd
zero2sixd's Avatar
Default Street tire choices for autocross
Whoops, was supposed to be a new thread! :-}
Old 12-28-2009, 06:45 PM
Rubrignitz
Rubrignitz's Avatar
Nice work!! I've had a seibon ss hood since the car was new and it does make quite a difference in underhood heat exhaust. You can see the heat rising up out of it. I noticed it running cooler and the engine bay (oddly enough) stays cleaner, I assume because of airflow blowing the dirt/dust out of the bay area. It stays really clean under there with no deposits on the covers/valley area...another plus.
Rubrignitz is offline
Old 12-28-2009, 08:05 PM
heartinacage
heartinacage's Avatar
That is awesome. I may consider going this route if I can't get the hood I want.
heartinacage is offline
Old 12-29-2009, 12:39 AM
Import_Slaya
I don't see why not if properly prepped. It looks and feels like the same type of plastic as our rear view mirrors, which plenty of people have painted.
I think that modifying the hood to accept it like the GT500's would take a huge amount of time and effort. I don't TIG weld and MIGing aluminum that thin is tough to do with good results. Fiberglassing is an option, but again, it would be a major undertaking. At that point, I would just buy an aftermarket hood.
Is the hood weaker than stock now? Possibly, but not in a noticeable way. The vent insert is actually a pretty stout piece--as stout as the section it replaces. Since it was mounted using urethane adhesive (very strong), it's almost as if the stock hood section wasn't removed. I'll update if it flies apart, though.
Old 12-30-2009, 03:27 PM
Red06
Red06's Avatar
I've been contemplating some way to vent the hood for some time. I hate the way it "balloons" at speeds over 100 mph. This mod just may do the trick. Thanks for sharing this mod!
I guess I should spend more time lurking at cc.com...
Red06 is offline
Old 01-19-2010, 07:01 PM
HeadonaStick
HeadonaStick's Avatar
Do you think that this vent would fit an '08 hood? I really like it and I have a white car and think a carbon fiber vent would look very nice.
[edit:]
I just noticed - this is on 2006.
HeadonaStick is offline
Quick Reply: GT500 Hood Vent
