HID RELAY
Old 10-30-2011, 12:14 PM
S197winstang
S197winstang's Avatar
Default HID RELAY
capacitor required??
Anyone aware of a required capacitor for the bi x kit? I ordered a relay harness from retro and it failed within two weeks. I wrote them and this is what i received as a response:-," the relay wiring purchased is not intended for use on a Ford Mustang that fits H13 bulbs, as the only such models run pulsed voltage to the low beams and therefore a capacitor built into the relay wiring is needed".
I ordered the h13 bi-xenon relay harness.... this is a first for me.... Retro has an excellent reputation so i thought i would throw this out to you guys for thoughts before passing judgment..
S197winstang is offline
Old 11-01-2011, 09:29 PM
flash_xx
flash_xx's Avatar
I have the retro bixenon kit. It has been working fine for 2 years. I installed it myself with the relay kit and didn't see any capacitor.
flash_xx is offline
Old 11-06-2011, 11:33 PM
S197winstang
all is well--Retro built a relay for me-- Great service at the end of the day. they were fair, responsive and easy to deal with. I am still miffed by the original relay failure but impressed with Retro's honest approach.
Old 11-11-2011, 10:25 AM
157dB
Cut & Paste Expert
157dB's Avatar
The pulsed voltage is only present if you have the DAYTIME RUNNING LIGHTS.
Otherwise, when you turn on the low beams, it is NOT pulsed, but straight
12VDC as indicated by the solid oscilliscope readings...
157dB is offline
Seanam
10-04-2015 10:15 AM
1996cobraconvertible
SVT Forums
09-30-2015 02:01 PM
jc409
Convertible Tech
09-24-2015 03:38 PM
schecterplayer
09-23-2015 08:38 AM
kawiguy827
09-22-2015 10:52 AM
Quick Reply: HID RELAY
