Exterior Mods - Page 2 - MustangForums.com
Sponsored by:
Sponsored by:
Old 10-22-2015, 04:54 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Ford Mustang Exterior Guides
Print Wikipost
Old 05-10-2012, 10:52 AM   #11
kevinmalec
kevinmalec's Avatar
Quote:
Originally Posted by iAerials View Post
I think im ready to do the louvers myself since im kind of a perfectionist. I probably will end up overprepping the surface which is good. However im not experienced with applying stripes so if anyone can give me some advice i would greatly appreciate
I am as well! I followed the instructions to a "T" and was suprised the one corner did not adhere that well. Before installing, adding the extra super duty 3M tape to the louver would have helped tremendously!
Be sure to use 90% or higher rubbing alcohol to clean the area on the car, where the louvers will adhere to. You may need to call around and find out who carries 90% alcohol or higher in your area. I found some at a local grocery store.
I have not applied racing stripes, but I did help apply my Saleen vinyl faded stripes. I used a spray bottle (soap/water), squeegie and microfiber towel to make sure I did not scrape the stripes. I've seen some postings on step by step guide of installing the racing stripes. They use painters tape to line up the stripes and also use a spray bottle, squeegie and xacto blade to cut the stripes. Try using the search function and you should find it.
kevinmalec is offline   Reply With Quote
Old 05-10-2012, 12:24 PM   #12
kevinmalec
kevinmalec's Avatar
Installing racing stripes. Check out the link below on how to install.
http://mustangforums.com/forum/2005-...-them-too.html
Old 05-10-2012, 01:54 PM   #13
iAerials
Good man. Appreciate the help.
iAerials is offline   Reply With Quote
Old 05-10-2012, 03:36 PM   #14
kevinmalec
kevinmalec's Avatar
Wink No problem. ;-)
No problem. ;-)
Original Owner 1970 Mustang b8checker Classic Mustangs (Tech) 8 10-08-2015 01:55 PM
Chassis wiggle when off throttle? UrS4 S197 Handling Section 10 10-03-2015 07:23 AM
October Sale - AmericanMuscle AMAlexLazarus AmericanMuscle.com 0 10-01-2015 11:29 AM
Plastic dip paint TimeLord101 New Member Area 2 10-01-2015 07:40 AM
Original Owner 1970 Mustang b8checker New Member Area 3 09-30-2015 08:11 AM
2005, exterior, good, gt, louvers, mod, modifications, mods, mustang, quarter, rattling, s197, solutions, upgrades, window
