Illuminated Door Sill Plates for 05-13
Check out these new illuminated door sill plates for the 05-13 Mustangs! Please let me know if I can help you with anything!
Boss 302 - $209.95:
Mustang GT - $209.95:
Mustang - $189.95:
Boss 302 - $209.95:
Mustang - $189.95:
Add a touch of class to your 05-13 Mustang with our Illuminated Door Sill Plates.
Easily snaps into place of the factory door sill plates and includes custom wiring harness for illumination function. LED illumination insures very low power draw.
Scuff plate portion has attractive and durable aluminum finish. Availble with various logos including Mustang, Mustang GT, and Boss 302.
Product Benefits
Product Benefits
- Easy snap in installation
- Includes wiring harness
- Low power draw and looks great!
Hello all,
I wanted to let you guys know that the illuminated door sill plates can be used in conjunction with your ambient lighting system and match every color within this system for all 2010 and newer model Mustangs. Please note, the vehicle MUST have the ambient lighting package in the vehicle in order for this function to work. All vehicles without the factory ambient lighting option will be able to choose from 4 colors (Red, White, Blue or Green).
For 2005-09 Models. Currently, we have not developed the wiring harness for the Ambient lighting system in these model years.
Any model year Mustang which does NOT have the ambient lighting function from the factory will have the four colors (mentioned above) available to select. The color choice is selected at the time of installation (these plates to not have to be ordered with a specific color, they are all capable of lighting in the desired colors).
These plates are lit up as long as your ambient lighting is turned on. If your vehicle is not equipped with ambient lighting, these plates will illuminate upon opening the door(s) and turn off with the map lights.
My color is a separate function from the ambient lighting system and has no bearing on the color or function of the illuminated door sill plates.
Hope this helps clear a few questions.
Please let me know if anyone has any additional questions regarding this product.
Thank you!
Reon
Thank you!
Reon
Hello all,
For 2005-09 Models. Currently, we have not developed the wiring harness for the Ambient lighting system in these model years. Is this still true? Please see the link and pic below from AM...They are the only vendor that I have found that sells the "appropriate" GT/CS sill for the 2007-09...I say that as all the others have '5.0' and 'powered by ford' on them as well...
My color is a separate function from the ambient lighting system and has no bearing on the color or function of the illuminated door sill plates. How do I know what I have? My footwells and cupholders and speedo cluster change to many colors, but I have no idea if this is ambient or mycolor? Please advise?
Reon
Reon
http://www.americanmuscle.com/gtcs-i...sill-0513.html
Reon: Please see my questions in red above and the referenced link below.
The door sills can be made to do any of the 7-8 colors the console does. They do not work off the dash MyColor. I put my door sills in this fall off eBay. I gave 89.00 for the Mustang ones and installed them in about 20 minutes. I wired mine blue then, but have since come up with a console out of an 08 with ambient lights, so now they work off the console switch. If you want to wire them to one color, you could use the right pillar post wiring for hooking it up. It's a quick and simple way to wire it up. You can choose between the two wires on how you want it to work also.
