Go Back   MustangForums.com > Ford Mustang Tech > 2005 - 2011 Mustangs
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 12-30-2006, 05:16 PM   #21
FredTT
Default RE: TECH: Nitrous Oxide FAQ
Quote:
ORIGINAL: KTownGT
cool, I have been wondering the difference between a wet/dry shot...
How much is it to fill a 10lbs bottle?
Good question. Most shops (at least around my area) charge $3 per pound. So, roughly $30 plus tax.
~Fred
__________________
2005 Mineral Gray GT Automatic - Powerdyne S/C @ 8PSI
STATUS: Finally Back...Took 2 Months....But its back....
FredTT is offline   Reply With Quote
Old 12-30-2006, 05:21 PM   #22
Apoptosis
poptart tits
Apoptosis's Avatar
Vehicle: 2005 Ford Mustang GT
Quote:
ORIGINAL: FredTT
Quote:
ORIGINAL: KTownGT
~Fred
Ouch, too rich for my blood [:@][8D]
Do you know if there will be any timing-retards coming out?
__________________
2005 Legend Lime Mustang GT
Power: JLT II CAI, X-Cal II, Brenspeed 93 Tune.
Suspension: BMR Lower Control Arms.
Etc: MAC Axle-Backs, Hurst Comp. Shifter, Steeda Hood Pins.
Quote:
Originally Posted by Mrs.Stang View Post
KTown... why do you know so much about STDs????
Quote:
Originally Posted by Joolander View Post
you reached for the Outer Limits of plausibility with that one, ktown
Apoptosis is offline   Reply With Quote
Old 12-30-2006, 05:58 PM   #23
Black06stang
Quote:
ORIGINAL: FredTT
Your welcome. :-) In the process of writing one for gears.
That would be great! Nice nitrous writeup!
__________________
Black 2006 V6
-MAC shorties
-C&L CAI/XcalII
-15% tint, tinted turn signals
-Roush window louvers
-Dual Flowmaster ATs w/ h-pipe
-SRB Strut Bar
-7" touchcreen monitor w/carpc
-18" black bullits/nitto 555s
Black06stang is offline   Reply With Quote
Old 12-30-2006, 06:10 PM   #24
FredTT
Quote:
ORIGINAL: KTownGT
Yes, we have to retard the timing when we use nitrous. The reason is because the oxygen becomes more dense, and that cause the A/F mix to burn quicker. That cause the peak cylinder pressure to happen alot closer to TDC. Because of that, not all energy created by the combustion is used to power the piston, but instead is it transfered to the rotating assembly, possible damaging it over time. So, to stop all of that from happining, you need to retard you timeing roughly 2-1/2 degrees for every 75 hp added.
~Fred
__________________
Old 12-30-2006, 06:13 PM   #25
FredTT
Quote:
ORIGINAL: Black06stang
Quote:
ORIGINAL: FredTT
Thanks! I forgot about the gear writeup, i'll work on that today.
Two questions Added:
How much does it cost to fill a bottle?
Will there be any timing-retards coming out?
~Fred
__________________
Old 02-08-2007, 01:35 AM   #26
LAK3RS
Send a message via AIM to LAK3RS Send a message via Yahoo to LAK3RS
Hey Fred, what kits do you prefer?
I personally was liking the Zex Kit, and was checking out different things about it etc. But at HPP (My Tuner), they really prefer Nitrous Express (N/X). I just found out that the main N/X place is located in Wichita Falls, Texas. Which is actually only 2 hours away from me. So, I decided to look into them, I've heard great things from them, and have been recommended to check them out if I go Nitrous. You spoke of Dynotune? I'm not to familiar with them. Though all in all, you seem very knowledgeable about Nitrous, so what do you think about the N/X Kits, I mean the solenoids on their's seem soooo much reassuring than other kits like Zex, NOS, etc. I appreciate your info man, it's really helped me out.
- Justin
__________________
06 Scream'n Yellow Vert (Auto:N/A)
A lttle bit of go and a little bit of show...
LAK3RS is offline   Reply With Quote
Old 02-08-2007, 02:06 AM   #27
Timmay!!!
http://www.mustangforums.com/m_2196528/tm.htm
Thought I might throw this in there. I haven't heard much follow-up on this but there might be a way to run a street tune and N2O at the same time[sm=bounceybounce.gif]
__________________
Black 06 GT 5-Speed premium IUP
JLT CAI/EVO tune, borla,FRPP 4.10s, Trutrac, Steeda, Eibach, Tokico, CHE, Centerforce, Findaza, Spydershaft, two bad feet in the cockpit, to be continued...
Timmay!!! is offline   Reply With Quote
Old 02-08-2007, 02:33 AM   #28
FredTT
Quote:
ORIGINAL: LAK3RS
- Justin
This is a question that goes back and forth between MANY people. First of all, I would NOT recommend the Dynotune kit. I had 3 solenoids fail on me before I finally gave up, so its not a well built kit. I was actually going to update the FAQ today.
With Nitrous, it truely is, you get what you pay for. Don't look for cheap kits. Now, with that being said, N/X and Zex are both very good kits. The only real difference between them is the way the solenoids are. The Zex kit contains a box with the solenoids, so nothing is really exposed. Its a MUCH cleaner looking kit, and intalls MUCH quicker (you don't need to pay your tuner to install it, you can do it yourself). Also, the good thing about the Zex kit is the integrated TPS. This way your activation is always at WOT, I don't think the N/X kit comes with that.
Overall, I would suggest the ZEX kit, especially if your are doing the install on your own. However, seeing as there is no major difference, if your installer likes working from N/X, then it probably would be smarted to get that (since the know it better).
Let me know if you have any more questions!
~Fred
__________________
Old 02-08-2007, 02:59 AM   #29
vack75
Vehicle: '07 GT Premium
Great write up, answered alot of questions.
Thank you
__________________
Yeah there are Mods
vack75 is offline   Reply With Quote
Old 02-08-2007, 03:01 AM   #30
FredTT
Quote:
ORIGINAL: vack75
Thank you
Thanks!
Updated:
What nitrous kit should I buy?
Added: CrazyAl's solution to the tuning problem
~Fred
__________________
150hp, 2005, air, boost, dry, dynotune, installation, kit, legal, mass, mustang, nitrous, oxide, sensor, street, supercharger
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
