Go Back   MustangForums.com > Ford Mustang Tech > 2005 - 2011 Mustangs
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 06-05-2006, 10:07 AM   #1
saud alzaabi
Default 4.10 gears VS 3.73 gears
I have been told that the 3.73 gears are for fast take offs and the 4.10 gears are for high speeds ( meaning will increase top speed ) is this true ?
im thinking of getting gears.. i want the best ones that will get me to 200 kph as fast as possible... i dont care about over 200 kph ... i just want to take off fast...
and with this gear ...I know a tune is a must so is it possible to tune the car with a predator tuner ?
__________________
saud alzaabi is offline   Reply With Quote
Old 06-05-2006, 11:32 AM   #2
W1ldcat
Default RE: 4.10 gears VS 3.73 gears
You can get higher top speed with 3.73 and better take off with 4.10. Gears don't effect a tune like intake and exhaust will..
__________________
06 Vista blue Vert all options
Whipple HO 8psi
MAC axle backs
Helwig rear sway bar
Steeda LCA & Panard bar & Brace
W1ldcat is offline   Reply With Quote
Old 06-05-2006, 11:39 AM   #3
zx9rpilot
The 4.10 will give you faster acceleration with a lower top speed.
The 3.73 will give you slower acceleration with a higher top speed.
The reason a tuner will help is to recalibrate the speedometer for the new gear ratio.
I have the 4.10 and it gets up to speed QUICK. It will grab 2nd and 3rd without even trying.
All smiles with 4.10s!!! [sm=burnout.gif]
__________________
2006 GT, 10" Stripes w/ 1/4" Pinstripe, FRPP Axle Backs, C&L Intake, Dyno Tuned By Excessive Motorsport, 4.10 Gears, Sequentials, Hurst Short Shifter, FRPP Springs
zx9rpilot is offline   Reply With Quote
Old 06-05-2006, 11:45 AM   #4
Timmay!!!
The way everyone here talks 4.10s are the way to go!! I can't wait to get mine installed! Only time I've heard 3.73s are good are in FI applications. But in an otherwise stock car I've read that 4.10s will give you a higher top speed since the motor doesn't have enough power to max out in top gear due to drag.
__________________
Black 06 GT 5-Speed premium IUP
JLT CAI/EVO tune, borla,FRPP 4.10s, Trutrac, Steeda, Eibach, Tokico, CHE, Centerforce, Findaza, Spydershaft, two bad feet in the cockpit, to be continued...
Timmay!!! is offline   Reply With Quote
Old 06-05-2006, 02:11 PM   #5
06GT4RAD
Vehicle: 2006 Ford Mustang GT
Quote:
ORIGINAL: Timmay!!!
4.10's will NOT get you a higher speed in fact they will do the oposite and they will also make your RPM's higher at freeway speeds.
Richard
__________________
2006 GT-Borla Stingers, Eibach Pro Kit, Tokico D-Specs, MGW Billet, 20" Foose Nitrous w/BFG KDW Tires, CHE panhard bar & Support
http://www.ca-mustangs.com/home.php
06GT4RAD is offline   Reply With Quote
Old 06-05-2006, 03:11 PM   #6
mustangman02232
mustangman02232's Avatar
Vehicle: 04 F350 6.0
Send a message via AIM to mustangman02232 Send a message via Yahoo to mustangman02232
Quote:
ORIGINAL: 06GT4RAD
Quote:
ORIGINAL: Timmay!!!
Richard
buzz wrong answer, with the T-3650 it will allow you to pull through 5th gear and increase top speed, however if you were in a vacume your top speed would be lower
__________________
2004 Ford F350 6.0 PSD
MBRP 4" turbo back, no muffler/kitty, autometer boost/pyro/trans, SCT X-cal with innovative tunes, MISC appearance, fisher MM2,
not installed: arp head studs, cooling mods, 03 turbo, cfm "small mouth" elbow, ARP head studs, BPD EGR delete
SOLD:
2002 Mustang v6 vert
LTs, catted H, K&N FIPK, SCT X-3 with vmp tunes, misc appearance
RIP tripsevn7
4/1/77 - 7/27/08
mustangman02232 is offline   Reply With Quote
Old 06-05-2006, 03:21 PM   #7
saud alzaabi
Quote:
ORIGINAL: 06GT4RAD
Quote:
ORIGINAL: Timmay!!!
Richard
which means the fuel efficency will get worse right ? well lets say it had the normal predator performance tune will it be better ?
because my friend is giving away his predator tuner so i might take it until i get my own sct 2 and CAI... and lets say i had the 4.10 gears and the predator performance tune ONLY....
and i raced a stock mustang GT 5spd like mine but completly stock how will the race be ? will i give him a huge BYE BYE? or something more like a cars length ?
__________________
Old 06-05-2006, 04:20 PM   #8
zx9rpilot
Here's what I noticed after the 4.10s.....
After the gears, I spend more time in 5th gear because with the gears and tune, it actually pulls pretty well in 5th gear.
Before the gears, I spent a lot of time in 4th gear at a higher RPM because 5th had no acceleration value.
I would say that my mileage is about the same once everything cancels itself out.
__________________
Old 06-05-2006, 05:01 PM   #9
mustangman02232
your milage will go up a bit in the city and go down a bit on the highway, with the T-3650 i would also recomend you look at 4.30 gears cause they have a very tall 5th gear ratio of .68, you will be at 2900 rpms with 4.30s
__________________
SOLD:
RIP tripsevn7
4/1/77 - 7/27/08
Old 06-05-2006, 05:34 PM   #10
paco_pony
i built a simulation model for 05/06 mustang. here's what the 1/4 times and speeds are from the model. I added drag radials to the model to make sure force from gears was getting to the road (that's why stock 1/4 is lower than ~13.5).
3.55: 13.34 sec
3.73: 13.3 sec
4.1 : 13.24 sec
4.3: 13.22 sec
__________________
My Mustang race sim site
'06 GT
Built motor that smokes like a BBQ
'07 GT Vert
Basic bolt on's
paco_pony is offline   Reply With Quote
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
