You will need the camber kit with the Pro-Kit. Most likely the alignment place will tell you your camber is off, charge you for the rest of the alignment and send you away with the same camber as before. Buy the camber kit now, and hand it to them when you drop the car off for alignment. Some shops will have them on hand and sell you a set, but I have yet to find one.
Pardon my asking. WTF is a camber kit?
This ad is not displayed to registered or logged-in members. Register your free account today and become a member on Mustang Forums!
A camber kit is what is used to get your wheels from leaning so far inward when lowering your vehicle ive run camber in my car before for track purpose but when driving it helps out alot for that. too much camber would be / and correct camber would be l
OK, the Adjustable Panhard bar is used for the REAR of the car. If you lower the rear without one, the rear axle will become off-centered. The adjustable panhard bar will put it back in the center.
On the FRONT end it's a little different. When you lower it, the tops of the front tires will lean inwards towards the car. You need a camber correction kit to fix this, otherwise it will screw up your handling, appearance, and your tires.
You definatley should get an alignment after working on the front suspension of the car, no doubt about it.
__________________
Black 2006 GT Coupe
Dynatech LT headers & X; Borla catback
C&L CAI; 93 oct tune
Full BMR, Spohn & Steeda suspension
D-Specs; Alum driveshaft
Second Skin Audio damping; Infinity spkrs;
Goodyear Eagle F1 255F/295R - FR500 wheels
for what its worth i just put the pro kit on my car and then took it to break check and they did the alignment with there camber bolts.
DO NOT BUY THE STEEDA CAMBER KIT.
the reason i say that is you have to grind out the holes on your struts to make it work if you are useing the stock struts i don know about the aftermarket stuff. so if you use their bolts its less labor i think it was 140 and they did the back as well (ajusted the panhard)
I did use the BMR adj panhard bar but if you measure before lowering you should find that OE is out 1/4" to 3/8". Check it before and after. If after it is within this, save your money unless you really want it "exact looking" (which I did, but OE isn't exact and many think it is off by design) Lots of threads on this and I don't want to get into this much AGAIN.
I thought we determined that our rear axels are off centered when the cars are stock. A plum bob proved that most people's axels are 3/8 inch off-center stock.
