Go Back   MustangForums.com > Ford Mustang Tech > 2005 - 2011 Mustangs
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 10-11-2007, 11:17 PM   #121
WaterSoakedLemon05
Default RE: MUST READ. leak problem
I was one of the first victims of the S197 leak. My car leaked so badly it eventually ended up going to Ford reclamation (or the auction. I believe the auction thing more than the reclamation thing).
If you can't find the leak, try this. Open the hood. On the passenger side fender there is a small drainage hole. This hole is near the hood hinge and the point where the firewall meets the fender. Take a hose and aim it right down into the hole. If your car is anything like mine, the passenger side will fill up in seconds. It was pretty obvious that the car was not seam sealedproperly at all. The BBB inspector also noted thatmore than likely thefloor pan to A pillar seamwas cracked. The seam sealer inside the car had started to pull apart in this areal. It was almost like the whole car was shifting andcausing the sealer to seperate. He didn't pull the fender, but he was more than confident that if he had he most likely would have found a wider separation in this seam area.The BBB claimed the car as a total loss. Ford STILLmaintained that the car never leaked even after the inspector found water running into the car.
FORD WILL NOT HELP YOU IF YOU HAVE A LEAK.
They will do every thing in their power to ignore the whole issue and lie to you about it. I even think the dealers were also told to ignore the issue. Every time I went to one looking for help I was told it wasn't their problem. All I can say is ...Good luck. You're gonna need it. It took me 6mos and 9 days to dump the rolling piece of garbage. The electrical problems thatoccur because of theleak are a whole lot of fun. (ABS failure, TCS failure, dashboard failure, Charging system failure, radio only worked in park and neutral. To make things a little more interesting the car would just shut off) Good thing I never needed the airbags.With all of the electrical problems, I wonder if they would have deployed properly.
WaterSoakedLemon05 is offline   Reply With Quote
Old 12-22-2007, 09:36 AM   #122
lyyroix
Well I can tell you that with the 2008 model, as you might expect, they have not resovled the issue. My GT stays parked outside and we had our first big rain since I had mine. I happened to notice about 1/2 a gallon of water behind the passenger seat. The saet back was forward since one of my kids had ridden in back. Oddly enough that morning I had gotten into the car to take it to the dealer to have a common syncro issue in the 5 speed looked at. The service guy said their peson that worked on the leak was only there on Thursdays. Looks like my battle is about to begin. In this case, ole Lyyroix may have to go if they cant fix it.
**Update**
Got the car back last Thursday (12/27)after the dealer attempted repair the leak. On Friday (12/28) I discovered the carpet was still soaked and took it back. The service dept had not attempted to dry the carpet other than vacuuming out some water. Got the car back on Saturday (12/29) and the carpet was acceptably dry. We had intermittent rain but the leak ahd apparently been stopped. Well last night we had a good rain shower and this AM (12/31) I have found another puddle but smaller this time. I will be taking the car back in on Thursday AM for attempt #2. I checked the SC Lemon Law and here it may begin to apply after the third attempted repair. Oh and the service dept did not observe the gear grinding issue so we we will readdress that too.
2nd puddle
[IMG]local://upfiles/36049/DCB756A3541C42AFB53F47AEDCBEB779.jpg[/IMG]
__________________
Wouldn't trade ole Lyyroix
Vapor 2008 GT
lyyroix is offline   Reply With Quote
Old 12-22-2007, 02:03 PM   #123
odiaz
2005 Ford Mustang
Send a message via AIM to odiaz Send a message via Yahoo to odiaz
This might help. IT's a copy of the ford TSB for the infamous leak problem:
http://www.2005stang.com/gallery/alb...sb07-14-06.pdf
__________________
My website and mods
http://www.cherod.com/mustang
How to articles:
http://www.cherod.com/mustang/HowTos.htm
odiaz is offline   Reply With Quote
Old 04-22-2008, 12:03 AM   #124
2k05gt
Vehicle: 2005 Mustang GT
Send a message via AIM to 2k05gt
Well after 3 years of little rain in Virginia we have had 3 days of non stop rain, My car never had this leak till today.
over 3 inches of water on the passanger floor. My car is an 05, I bought in June of 05, it has 46,733 miles so no warrenty
and other ideas for people like me that will have to sort to fixing this themselfs?
__________________
Eastcoast S197 Shootout 11/1/09 Rockingham, NC (Hope to see you there !!!) Click for Details
MODS: JLT II CAI - JBA LT Headers - JBA Catted H Pipe - Steeda UDP - Steeda CMDP - FRPP 4.10 Gears - FRPP GTA Axle Backs - TCI Super Street Fighter 3500 - Spyder Aluminum DS - CHE LCA - M&H 275/50 17 DR's (12.29 @ 110 MPH)
2k05gt is offline   Reply With Quote
Old 04-29-2008, 10:43 AM   #125
Juntech
Juntech's Avatar
Send a message via AIM to Juntech Send a message via Yahoo to Juntech
Where does the leak affect? I've heard the passenger side and even driver side footwells. There was a photo of the rear passenger footwell??[:-]
__________________
2008 Vapor Silver GT... mods: 3.73 gears. C&L racer CAI. 91 Tune. Shorty antenna
Juntech is offline   Reply With Quote
Old 04-29-2008, 11:13 AM   #126
RideMyAssOff
RideMyAssOff's Avatar
Hmmm, this sucks, I have an 08, will keep an eye on it.
__________________
Life is a matter of risk and the chances of
success are in no way enhanced by extreme caution...
RideMyAssOff is offline   Reply With Quote
Old 05-10-2008, 12:23 PM   #127
JUANCQ1982
I just found out I have the SAME problem. Called the dealer was was told that is was not their problem, they never have heard of such problem occurring.
Anyone found out what to do to have this fixed? Thanks!
JUANCQ1982 is offline   Reply With Quote
Old 05-10-2008, 03:13 PM   #128
Orion_240
Orion_240's Avatar
Vehicle: 2008 Shelby GT Convertible
Just print out the above TSB and take it to Ford.
If you're off warranty then you will know where to look and possible fixes.
The main thing you need to do is confirm where exactly the water is coming in.
__________________
2008 Shelby GT Convertible, Vista Blue, Auto, 100% stock
Sold:2005 Mustang GT, Premium, Screaming Yellow, Auto, Interior Upgrade Package, Black Bullitts & Eibach Pro-Kit Louvers are featured here:http://www.wheelskin.com/
Orion_240 is offline   Reply With Quote
Old 12-22-2008, 12:10 PM   #129
murry
Vehicle: 2007 gt, 5 sp, 3:55's Spoiler delete, box stock.
Default where poll?
Quote:
Originally Posted by HypromanGT View Post
Uh-oh....is it an early '07? I was under the impression that the '07s after a certain date were not having this problem. Sorry to hear you're having this issue as well
Please, please, please go vote here. As you will see in the poll, there's only been 1 person so far with any problems with the '07s after that "magic" date. Once again, I urge everyone to feel behind the passenger access panel in the padding after a rainy day/drive or car wash.
Good luck...you've got a long road ahead of you as far as getting this resolved...
can't find the poll.
07 GT build date late April or Early May 07.
My car leaks water onto the sills. It puddles up. If it is cold it forms ice. If it is warm and dry after a rain the next day I can open the doors and the water will start dripping out onto the pavement. It is not coming throught the door drain holes.
I haven't checked the fuse box and floor. I also have the nice thick floor mats so I would not have noticed it. Can't look now it is snowy outside.
murry is offline   Reply With Quote
Old 12-22-2008, 12:28 PM   #130
murry
Quote:
Originally Posted by twokidsnosleep View Post
Well myvert is going back for water leak check. The passenger floomats are ok, but the passenger door and door sill are always wet. It seems like the door is full of water, drips on opening and drips onto the sill. Anyone have something similar???
Scott [:@]
Yes, yes, yes. It is driving me crazy. I always go out after a rain and open the doors to let the water out. Ford wil do nothing for me and the engineer says "this is normal, we designed the car to drain onto the sills"
06, 2006, amp, ford, gone2, grounding, leak, leaks, mustang, pics, problems, sloshing, sn197, water, wife
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
