i did this install with just little neons and its perfect, only difference is mine is hard wired to the map lights. so it comes on with them, i also have blue 15 led map lights. i will also be putting the same small neons under the back of the front seats, that way light when you want it all matched seamless like factory.
undercarage lights are uck again what you do inside is you, just dont glow like your radioactive while your driving around.
__________________
07 GT Rag Premium, Black on Black
GT 500 Front End, Rear Spoiler Delete,
FRPP Hood Pins, Functional Hood Scoop,
PIAA 510 4300k Fogs, 4300k HID DRL Delete,
Steeda 90mm Intake and Tube, Steeda UDP,
BMR Combo LCA, UMI Poly UCA, BMR FSB Delete,
SCT Xcal 3, FRPP CMDP, Innovate Wide 02
PRO 5.0 Shifter, Custom T and Handle
Pypes Mid Muffs, FRPP X pipe
FRPP 4.10s and True Track
13.2 @ 109 at 2400ft above sea level
12.8 @ 111 DA corrected
