Go Back   MustangForums.com > Ford Mustang Tech > 2005 - 2011 Mustangs
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 08-31-2007, 01:34 PM   #101
acrokat
Default RE: DIY THROTTLE RESPONSE MOD (MUST SEE!)
We are just changing where the brushes contact the track. In essence moving the entire track down a little.
__________________
2007 GT Alloy - Premium, IUP
Functionals - JLT II/BAMA, CHE LCA's, CHE k-brace, Eibach Pro Kit, FRPP GTA's
Visuals - Sequential Tail lights, Chrome inner door handles
acrokat is offline   Reply With Quote
Old 08-31-2007, 01:35 PM   #102
mcburns36
mcburns36's Avatar
Vehicle: 07 GT
Do you want to hear me complain about the magazine makeover? No I really like C&D. Been a subscriber for over 25 years. I like your throttle mod too.
__________________
DING DONG Richie's gone !!!!!!
This gets better and better. hehehe
Yes, poo does happen from time to time. Sometimes you're the poo-er, sometimes the poo-ee. Life is like that.
mcburns36 is offline   Reply With Quote
Old 08-31-2007, 01:44 PM   #103
richmod
richmod's Avatar
Vehicle: 06 Mustang GT
Quote:
ORIGINAL: acrokat
So where is the initiall point of contact - closest to the gold plate or farthest? In other words - Which way does the brush move across the strip when you press the pedal - TOWARD the gold plate or AWAY from it? If the initial point of conact is AWAY from the gold plate and the brush moves TOWARD it, then WOT would be the exact opposite of your picture - it would be over the gold plate. If the brush initially STARTS over the gold plate and moves away from it, my problem there is - how is this physically possible given the position of the brushes?
I thinkI need to see a diagram of exactly how this whole apparatus works. The pictures just aren't cutting it for me.
__________________
06 Windveil Blue GT Auto, JLTII CAI, Bama tunes, FRPP/Supreme GTA Axleback
richmod is offline   Reply With Quote
Old 08-31-2007, 01:45 PM   #104
Derf00
Quote:
ORIGINAL: 157db
Lets see. Bend wipers. No thanks.
Install a new travel stop so the relaxed
travel is a few mm less. Hmmmmmm
Sounds like a better way instead of
bending wipers. Soon the carbon will
be worn away from too much pressure
from misbent wipers. Forget the lag,
how about the new dead spots and
undesired quirky response from missing
resistance material?
Put a travel stop on mine and now its
fully micro adjustable with no bending
of wipers. Hows that for a modified mod?
That would be fine logic but they WILL wear out no matter what. Probably a little sooner with the mod but in the end, it will wear out.
Derf00 is offline   Reply With Quote
Old 08-31-2007, 01:48 PM   #105
marcuskeeler
marcuskeeler's Avatar
It's a nice discovery, I guess, but I don't really see what it gives? Like the clutch or brake bite points, the gas pedal is just something you get used to.
- Unless of course you go to meetings where these things are measured, with an award for the person with the least amount of dead pedal [&:]
marcuskeeler is offline   Reply With Quote
Old 08-31-2007, 01:49 PM   #106
acrokat
Quote:
ORIGINAL: richmod
Quote:
ORIGINAL: acrokat
Take a look at the pic I posted on Page 5. I was asking a question when I modified it. The white circles are where the brushes are located when your car is at idle. The black circles are where your brushes are located at WOT.
__________________
Old 08-31-2007, 01:50 PM   #107
01Steed
I ♥ Acer
Quote:
ORIGINAL: Derf00
Quote:
ORIGINAL: 157db
This may be true, but Ford has life-cycle tested these to last x amount of cycles. This mod may prematurely wear them. How much is anyones guess.
BTW, I think I like "pot" better than "rheo". More sensitivity with a "pot".
01Steed is offline   Reply With Quote
Old 08-31-2007, 01:52 PM   #108
acrokat
Quote:
ORIGINAL: marcuskeeler
I cat tell you how many times I have jerked my car when shifting becauseI have the pedal resting in the "dead zone". It's not a bad jerk but it's enough to piss me off when I shift. Realistically I am just being lazy when I am shifting; not paying attention. If I can improve my shifting while being lazy and learn a little about my car in the process then I am all for it. I just had one question which is listed on page 5. Someone please answer it [:@]
__________________
Old 08-31-2007, 01:54 PM   #109
MartyMoose
*whispering* Pssssst, hey guys, be quiet, here he comes. Lets not tell him about our secret club meetings. shhhhhhh.
__________________
'07 GT Saleen/JDM Stage 1
Pics
MartyMoose is offline   Reply With Quote
Old 08-31-2007, 02:00 PM   #110
richmod
richmod's Avatar
Okay, I think Isee how the throttle works now. That little plastic circle at the end of the black housing carbon strip part AND the end of the whitehousing acts as a hinge (or axis), When you press the pedal, the whole whitehousing slides rotates around that axis thus sliding the brushes across the carbon strips . Correct?
If I'm right about how the throttle works, then the brushes are ALWAYS in contact with the carbon strip. this mod is only changing WHERE the brushes are in contact with the strip. The theory is that somehow if the brushes start above the gold plate instead of a few mm to the right of it, somehow that decreases throttle delay, supposedly because that area of the strip is more "sensitive". But sensitive to what - movement of the brush? Meaning, in that area above the gold plate, it would take less brush movement to illicit the same amount of throttle response than it would elsewhere? I don't get it.The maximumdistance traveled by the brushes across the strip is still the same, just shifted. Seems to me the ECU would just account for this shift and just make the new position it's new "normal". Enlighten me please someone/
__________________
197forumcomforumshowpostphpp31315amppostcount36, 2010, 4r3z9f836bd, 9f836, diy, ford, httpwwws, mod, mods, must, mustang, number, part, potentiometer, response, see, thottle, throttle
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
