Go Back   MustangForums.com > Ford Mustang Tech > 2005 - 2011 Mustangs
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 08-31-2007, 02:01 PM   #111
GidyupGo
Vehicle: 2007 GT
Default RE: DIY THROTTLE RESPONSE MOD (MUST SEE!)
Quote:
ORIGINAL: 01Steed
Quote:
ORIGINAL: Derf00
Quote:
ORIGINAL: 157db
Lets see. Bend wipers. No thanks.
Install a new travel stop so the relaxed
travel is a few mm less. Hmmmmmm
Sounds like a better way instead of
bending wipers. Soon the carbon will
be worn away from too much pressure
from misbent wipers. Forget the lag,
how about the new dead spots and
undesired quirky response from missing
resistance material?
Put a travel stop on mine and now its
fully micro adjustable with no bending
of wipers. Hows that for a modified mod?
That would be fine logic but they WILL wear out no matter what. Probably a little sooner with the mod but in the end, it will wear out.
This may be true, but Ford has life-cycle tested these to last x amount of cycles. This mod may prematurely wear them. How much is anyones guess.
BTW, I think I like "pot" better than "rheo". More sensitivity with a "pot".
I was lucky to pull that one out of memory that hadn't been touched in 35 years, even with the bad spelling.
__________________
2007 GT Coupe Premium Windveil Blue, Born on date...3/07
O ne
B ig
A ss
M istake
A merica
GidyupGo is offline   Reply With Quote
Old 08-31-2007, 02:12 PM   #112
p51mstg
Quote:
ORIGINAL: tube
The patch of carbon on top of the gold pad is less sensitive because it has METAL underneath it, and that metal is making continuous contact with all of the carbon on top of it, negating its ability to act as a variable resistor.
Only AFTER the metal pad, is the carbon sensitive and acting as resistor.
Definitely related to Taco Bill......
[sm=hail.gif][sm=hail.gif][sm=hail.gif][sm=hail.gif][sm=hail.gif]
__________________
'Will Fly for Food'
p51mstg is offline   Reply With Quote
Old 08-31-2007, 02:24 PM   #113
frdfrst
frdfrst's Avatar
thie is great.just ordered new pedal and will try when it comes.TUBE,[sm=massbounce.gif][sm=groupwave.gif] GREAT POST,YOU HAVE MY GRAITUDE.wish c&d was more into every day cars,but the high dollar ones are great.
frdfrst is offline   Reply With Quote
Old 08-31-2007, 02:28 PM   #114
tube
Quote:
ORIGINAL: acrokat
I have a question.
By changing the angle of the brushes, we are changing the area where the brushes contact the track. My question is what happens if we adjust these brushes too far and they contact the Plates on the other side of the track. this would happen under a WOT scenario. I have modded your pic to clarify my question.
DIGG MY THREAD!!!!!!! RAR!!
http://digg.com/motorsport/Improving...hanical_Means/
MAKE A DIGG ACCOUNT !
Anyway, because you are bending the tabs so they go forward, there is no problem at WOT, as the brush just comes and makes contact with the WOT side brass pad area, and the ECU automatically opens the throttle 100% there anyway.
__________________
2008 Mustang GT Premium
White
Manual
Factory HID headlights
tube is offline   Reply With Quote
Old 08-31-2007, 02:46 PM   #115
kleistang
kleistang's Avatar
Quote:
ORIGINAL: marcuskeeler
It's a nice discovery, I guess, but I don't really see what it gives? Like the clutch or brake bite points, the gas pedal is just something you get used to.
- Unless of course you go to meetings where these things are measured, with an award for the person with the least amount of dead pedal [&:]
it works just like a short trough shifter. if the distance from 1 to 2 is shorten you can shift quicker
here if the the brush touchs the carbon quicker it tells the ecu to open the T/b quicker. you are just
getting rid of the gap. like olf stile cables you use to shorthen the cable and make tight so when you accelerate it is more sensible. imagine we all have a loosen cable, this is the electronic way of making
it tight and NICE!
kleistang is offline   Reply With Quote
Old 08-31-2007, 02:47 PM   #116
acrokat
OK, that makes sense. Thanks for answering
Quote:
ORIGINAL: tube
Quote:
ORIGINAL: acrokat
I have a question.
__________________
2007 GT Alloy - Premium, IUP
Functionals - JLT II/BAMA, CHE LCA's, CHE k-brace, Eibach Pro Kit, FRPP GTA's
Visuals - Sequential Tail lights, Chrome inner door handles
acrokat is offline   Reply With Quote
Old 08-31-2007, 03:00 PM   #117
kleistang
kleistang's Avatar
ahahaha This Sounds like Fun!
Put the cover back onto the pedal assembly. NOTE: There is a rubber gasket that goes in the slot. MAKE SURE not to lose it, or crush it, this could cause your vehicle to accelerate uncontrolably! Screw the 5 TORX screws back in VERY CAREFULLY do not distort the cover, or you may bend the wires and cause bad ju ju.
Old 08-31-2007, 03:02 PM   #118
tube
Yup, any questions i'll try to answer to the best of my ability.
__________________
White
Manual
Old 08-31-2007, 03:03 PM   #119
richmod
richmod's Avatar
Vehicle: 06 Mustang GT
Quote:
ORIGINAL: acrokat
Quote:
ORIGINAL: tube
Quote:
ORIGINAL: acrokat
I have a question.
Well, that doesn't make sense to me. If you're adjusting the brush closer to one edge of the carbon strip intially, then the end point of the brush at WOT would have to be FARTHER from the other end of the strip. If the "side brass pad area" is in reality the WOT area as you say, then you would not be reaching there anymore after the brush adjustment. Correct?Not trying to be confrontational, just truly trying to get a grasp on this.
__________________
06 Windveil Blue GT Auto, JLTII CAI, Bama tunes, FRPP/Supreme GTA Axleback
richmod is offline   Reply With Quote
Old 08-31-2007, 03:15 PM   #120
157db
Got Troy'd
157db's Avatar
Vehicle: 2007 Pony Package
Quote:
ORIGINAL: acrokat
I have a question.
Exactly. Thats why the travel stop works much better than the bending method.
"Open thyn eyes for the sake of being blinded by the light."
__________________
NON PUMKIN JACKER
Quote:
Originally Posted by Boozshey View Post
Oh yeah, I forgot Norm was God on here.
Give me a break!!!
Quote:
Originally Posted by Norm Peterson View Post
<rises to the bait>
. . . Definitely not God.
Norm
157db is offline   Reply With Quote
197forumcomforumshowpostphpp31315amppostcount36, 2010, 4r3z9f836bd, 9f836, diy, ford, httpwwws, mod, mods, must, mustang, number, part, potentiometer, response, see, thottle, throttle
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
