Go Back   MustangForums.com > Ford Mustang Tech > 2005 - 2011 Mustangs
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 11-27-2007, 06:35 PM   #21
ChiDiddy
ChiDiddy's Avatar
Vehicle: 2008 Mustang Saleen 3 valve
Default RE: DIY HID INSTALL on a 2007 V6
I have been running the Retro-solutions Bixenon 55w kit on 3 cars, no melting here. $180 shipped w/ lifetime warranty is a good deal.
It was a straight plug n play kit, no splicing needed.
__________________
08 Mustang Saleen WHIPPLED
ChiDiddy is offline   Reply With Quote
Old 11-27-2007, 07:51 PM   #22
chupac
I'll be ordering 4 sets from them, I'll be doing headlighs and fogs on both my Mustang and my H-D.
__________________
Stupid people are like slinkies. Only fun when you throw them down stairs...
chupac is offline   Reply With Quote
Old 11-27-2007, 09:28 PM   #23
miloman
miloman's Avatar
Vehicle: 2005 GT
Do the ballasts produce any heat? Don't know, and just curious.
__________________
Quote:
Originally Posted by ImpOnFire View Post
i always swallow
miloman is offline   Reply With Quote
Old 11-28-2007, 01:42 AM   #24
tube
lol way to copy my mod write up format!
__________________
2008 Mustang GT Premium
White
Manual
Factory HID headlights
tube is offline   Reply With Quote
Old 11-28-2007, 05:06 PM   #25
kdrshocker
miloman - I'm not sure if they produce a huge amount of heat. I know that they produce some. I'm not too worried about it. They are in the engine bay, they're made out of metal, they will get hot regardless. However, they do have to be kept under 105 deg. If they rise above that temp they will shut off. Air circulation is key to that problem.
tube - What are you talking about?I haven't copied anything...
__________________
kdrshocker is offline   Reply With Quote
Old 11-29-2007, 08:15 AM   #26
madmax69ca
Humm ... I saw on another forum a different wire connection:
black/blue
green/white
red/yellow
Source (http://forums.bradbarnett.net/showpo...p;postcount=97)
Which one is correct ? Probably both work but what is the correct connections ???
__________________
Martin D
Ford Mustang GT 2005 Coupe
Black, 5sp, IUP, ICAP, Shaker 500, 17" Bullits and Active Anti-theft.
Mods: Eibach Pro-Kit, Tokico D-Spec, Corsa Exhaust, MAC Straight Shot, SCT XCAL II & Bamachips Tunes, Sparco Evo 2 Seat, MGW Sh
madmax69ca is offline   Reply With Quote
Old 11-29-2007, 05:23 PM   #27
kdrshocker
yeah, i noticed that... the way i did it in my write up is the correct way.esp because i didn'thave a yellow wire. If you hook it up that way nothing bad will happen/ but your high beams won't work. You'll hear the relay click but that's all you'll get.
FYI - in cars ground is normally a black wire (one of the 3 wires on the OEM ford headlight harness); In homes ground is normally a green wire. Brown is another wire that is colored for Ground. The HID kits wires are white/blue/brown. white is the low beam, blue is the high beam and brown is ground, brown = dirt/earth/ground
__________________
Old 11-29-2007, 05:32 PM   #28
alex0o85
I still wich someone had a writeup for the V6 PP fog lights. I don't like having lights that don't match. Nice job though, I'll be borrowing this for my reference when i do this.
__________________
:P
alex0o85 is offline   Reply With Quote
Old 12-01-2007, 03:43 PM   #29
madmax69ca
Here you go !
Just installed the Headlights AND Fogsyesterday ! The V6 fogs should identical as I think it is using the same bulbs.
I wrote this write-up on another forum:
http://forums.bradbarnett.net/showth...81#post1057681
__________________
Martin D
Old 12-09-2007, 05:13 AM   #30
djmac95
Kdr thanks to yourdetailed writeup I just got the VVME HIDs installed tonight and all I can say is wow! [sm=happy046.gif] There is an absolute hell of a difference in light output and the high and low beams work perfectly! The kit for me was a PIA to installand very timeconsumingdue to my lack of electrical systems skills, but if I can do it anyone can do it and now that it's done I'll never go back. Thanks again for the outstanding writeup! [sm=smiley20.gif]
__________________
'06 Performance White GT, AT
Go: Polished C&L Street Intake w/ Bama & VMP Tunes
Suspension: Vogtland Leveling (GT500) Springs, Tokico D-Specs, GT500 USM's, Steeda Adj. Panhard bar w/ brace, Steeda Adj. UCA, GT500 LCA's, OEM A-Arm Brace
Show: WebElectric Sequentials, Clifford Remote Start, Incubus 20" Rims, Shorty
djmac95 is offline   Reply With Quote
2005, diy, fog, h13, headlight, hid, housing, install, kit, lights, melting, mustang, retrosolutions, v6, vvme, wiring
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
