New Features: Ford Mustang Knowledge Base
Go Back   MustangForums.com > Ford Mustang Tech > 2005 - 2011 Mustangs
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 01-08-2008, 05:48 AM   #11
Menace
2006 Ford Mustang
Vehicle: 2006 Ford Mustang GT
Send a message via AIM to Menace
Default RE: Aluminum driveshaft (did search.....need more opinions)
Well, after looking at my recent Summit Racing catalog... I might hold off on the driveshaft idea.
http://store.summitracing.com/partde...p;autoview=sku I just don't know how complete this assembly is. What kind of differential/gears does it have? Or is it all empty? The price doesn't seem bad, but the driveshaft is some 600-700 extra. Weighing in at 14.8 lbs.
__________________
2006 Mustang GT
Exterior: Black Clearcoat
Interior: IUP, Dark Charcoal, Leather, Shaker 1000
Best 1/4: 13.075 @ 107.75 mph
Weight: 3660. Full Street Trim + Driver
40 series Flowmasters
Menace is offline   Reply With Quote
Old 01-08-2008, 07:07 AM   #12
nineinchnail1024
Vehicle: 2006 Mustang GT
Spydershaft would be my #1 choice. FYI, the steeda shaft is a tapered version of the spydershaft and is made by Leonard Racing Products (The same company that makes the spydershaft). If I ever planned on lowering my car, I'd have gone with the steeda version. I just plain don't like adapter plates. They seem like an afterthought. Replacing the pinion flange makes for a complete job.
__________________
Whipple Crew-10psi-Spec II-BMR LCAs-BMR sway bar delete-Spydershaft-M/T 26x11.5x17-Hurst-Prothane Mounts-PMP Line locks-Flows-Thump_rrr-Moroso separator-11.39@119mph
Daily Driver-2010 Prius-52.3mpg since new
Beater-1995 F150 XL-302 5spd
nineinchnail1024 is offline   Reply With Quote
Old 01-08-2008, 10:30 AM   #13
4LITER6
4LITER6's Avatar
Extreme Quality.............www.driveshaftshop.com
Alot of driveshafts out there...........................you get what you pay for..........
If you are getting a GT Shaft for a GT..........you will not need a flange or adaptor.........
__________________
06 4.0 Vert, Vista Blue Prem. X-Charger, BMR: LCA's & Re-Lo Brkts., UCA & Mt., GT Take Off's: Body Kit, Dual GT's/X-Pipe, 8.8 Diff. 373's/t-lok, Hurst Shifter, Shorty JBA's, Saleen: HID's, 5 Spoke and Watts Link, 3D Carbon: Ctr Fogs & Rear GT500 Spoiler, The DriveShaft Shop: 3 1/2" Alum DS, Bilstien: Shocks & Struts, Vogtland: Springs, Baer: 6s w/14" Rotors, Pirelli: 275/35/20 275/40/20 "Rosso".....
4LITER6 is offline   Reply With Quote
Old 01-08-2008, 05:37 PM   #14
miloman
miloman's Avatar
Vehicle: 2005 GT
Quote:
ORIGINAL: Menace
I don't think it includes the differential, pretty sure it's just the housing.
__________________
Quote:
Originally Posted by ImpOnFire View Post
i always swallow
miloman is offline   Reply With Quote
Old 01-08-2008, 05:38 PM   #15
miloman
miloman's Avatar
Vehicle: 2005 GT
What about drive shaft loops?? Are they necessary? Front vs rear vs both??
__________________
i always swallow
Old 01-08-2008, 05:47 PM   #16
miloman
miloman's Avatar
Vehicle: 2005 GT
Quote:
ORIGINAL: 4LITER6
No adapter???? Here's what the sight says:
"This is the shaft that Ford should have installed, it's the real deal. The 2005-2007 V8 Mustang was dealt a bum deal in the drive shaft department. It left the factory with a 48lb 2 piece shaft that was not only heavy but also had a hanger bearing that moves up and down violently when you stomp on the gas pedal. This is our own designed 3-1/2" 17lb drive shaft that is "completely different" that any other shaft on the market today. Most other manufacturers are making a 4" shaft that has a clearance issue, when the car is lowered or if there is more than 2 people in the car the 4" tube will hit the floor (not good), Our all new 3-1/2" shaft does not have those issues at all. This shaft is designed for 900HP and had solid joints (made to go 50,000 miles with out making a mess under the car).The Big news about the DSS shaft is it has an internal DAMPER designed to reduce the Harmonic vibration these cars seem to be born with. We also have designed an aluminum plate to bolt on to the rear flange, this doesn't sound like much but considering some other company's are selling a similar shaft that has a new pinion Flange that has to be to be changed think about this. You remove the factory installed flange and install the one supplied sound simple right? Not Really this is a "crush collar" type Differential meaning this, if the flange is taken off the crush collar needs to be replaced because it's what sets the pinion depth. The rear needs to then be set up by a professional (not exactly simple), with the DSS shaft all you need to do is bolt the aluminum plate and install the shaft. This kit comes with everything to make this something that can be done it you own garage or very simple for your local speed shop. Dampened shafts are in very limited quantities so order your now !!!!!!
Our Price: $799.99"
This driveshaft is expensive too.
__________________
i always swallow
Old 01-08-2008, 05:58 PM   #17
D_Gusler
Spydershaft here--no probs, and its a well built unit. I'd rather replace the pinion flange and have a conventional style flange, not just the small six bolts that hold the stock unit in. Another plus, is with an adaptor, you'll be adding additional weight(I.E. losing part of the benefit of a alum. driveshaft).
__________________
MUSTANG TRAITOR--now rocking the 09 Pontiac G8 GT
451rwhp 431rwtq
best 1/4: 12.037 @ 113.78mph 1.697 sixty foot
D_Gusler is offline   Reply With Quote
Old 01-08-2008, 06:15 PM   #18
NJ3
NJ3's Avatar
I have a Shaftmaster 4" DS with an adapter. I have no clearance issues, noise or vibration plus its priced right and customer service is excellent.
__________________
2006 Redfire Mustang Coupe GT - Deluxe. IUP, Shaker 500, Side Air Bags, Spoiler Delete. C&L W/ XCal2 | Brenspeed Tune | MGW Shifter | Steeda Ultralite Springs | Steeda Pro Action | 3.5" Shaftmasters DS | BMR Panhard Bar | Spohn LCAs | Steeda UDPs | Corsa Xtreme AB | Bassani X-Pipe | 1/8 Mile 8.503 @ 84
NJ3 is offline   Reply With Quote
Old 01-08-2008, 06:42 PM   #19
miloman
miloman's Avatar
Vehicle: 2005 GT
Quote:
ORIGINAL: D_Gusler
IMO, that's not nessacarily true. The driveshaft with the pinion flange would be longer than the driveshaft with the adapter, right? Not sure of answer myself, but it does make sense. They should be very close in weight.
__________________
i always swallow
Old 01-08-2008, 06:52 PM   #20
4LITER6
4LITER6's Avatar
Quote:
ORIGINAL: miloman
Quote:
ORIGINAL: 4LITER6
Our Price: $799.99"
I would have thought that if you bought a replacement DS for a GT it would bolt right up, I have a V6 with an 8.8 rear...........I needed to get a new flange for my DS, but never heard of an adaptor for a replacement DS for the GT...............I must be wrong!!! Sorry!!! Carry on....
Cheers!
Alum DS worth every penny..................
__________________
35, 40, aluminum, benefit, drive, driveshaft, dynotech, flange, inch, menace, mustang, pinion, powerhouse, shaft, shaftmasters
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
