Go Back   MustangForums.com > Ford Mustang Tech > 2005 - 2011 Mustangs
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 03-11-2008, 09:32 AM   #1
doctorj77
doctorj77's Avatar
Vehicle: 2006 Mustang GT
Default Fuel Filter Replacement
Just thought I'd share this.
My dad and I went to change the filters on our GTs last night. For anyone considering going to Autozone, don't buy their brand, part # FF686. According to their computers that's the correct one for 05-07 mustangs. Its not. The inlet and outlet tubes are too small for the gas lines to re-attach.
My dad and I sucked it up and bought the $20 Motocraft ones from the dealer. We also bought one for my brother's 04 GT. And sure enough, thats the one Autozone sold me. So I have to take them back and tell them they need to update their system.
After we got the right filter the chance was easy. No differene in throttle or anything, but just a good maintenance item to do.
__________________
06 GT (Screaming Yellow) Brenspeed 93 tune w/Comp Thumpr Cams 320rwhp, 319rwtq
Ford Racing 4.10's, Steeda UPDs, Airaid CAI, Flowmaster A/T Axleback, MAC Long Tubes + Prochamber, Pro50 Shifter, CDC $$$haker
doctorj77 is offline   Reply With Quote
Old 03-11-2008, 01:20 PM   #2
mcburns36
mcburns36's Avatar
Vehicle: 07 GT
Default RE: Fuel Filter Replacement
Special tools? And did you take the pressure of the fuel system first?
__________________
DING DONG Richie's gone !!!!!!
This gets better and better. hehehe
Yes, poo does happen from time to time. Sometimes you're the poo-er, sometimes the poo-ee. Life is like that.
mcburns36 is offline   Reply With Quote
Old 03-11-2008, 01:25 PM   #3
GidyupGo
Vehicle: 2007 GT
There's no special tools required. Just the right size socket to take off the guard, and a screw driver or something to push on and relase the clamps. No way to releive the pressure. I pulled the fuel pump fuse and turned the engine over which may have reduced the engine side pressure off the line, but fuel WILL spill out, like about 1/2 cup from the tank side. No way around it.
__________________
2007 GT Coupe Premium Windveil Blue, Born on date...3/07
O ne
B ig
A ss
M istake
A merica
GidyupGo is offline   Reply With Quote
Old 03-11-2008, 02:10 PM   #4
drbobvs
Vehicle: '05 vert
Good idea to also loosen the fuel filler cap.
__________________
05 GT Vert, Auto, Saleen S/C w/JDM tune, bunch of other stuff. 11.42@120mph
drbobvs is offline   Reply With Quote
Old 03-11-2008, 02:17 PM   #5
Bluestar
I changed mine when I noticed the Car wasn't smooth at Idle....fixed it.
__________________
"A man's gotta know his limitations"...Clint Eastwood
Bluestar is offline   Reply With Quote
Old 03-11-2008, 02:37 PM   #6
doctorj77
doctorj77's Avatar
I did remove the fuse and turned it over. But like GidyUp said, it'll only relieve the pressure forward of the filter. It still drained a decent amount. Took about 10min per car. Pretty easy. The only tools is a 10mm rocket, a large screw driver for the plastic snaps, and needle nose pliers to remove them, and I used a large towell to soak up the draining fuel.
Pretty easy to do. Didn't notice any change, but then again the car was running fire before. Just normal maintenance.
__________________
Old 03-11-2008, 02:50 PM   #7
05BlackPony
I bought my fuel filter from autozone last month and have no problems what-so-ever.
__________________
05BlackPony is offline   Reply With Quote
Old 03-11-2008, 04:11 PM   #8
28HopUp
MF Administrator
1985 Ford Mustang
28HopUp's Avatar
Vehicle: Classic SSP S197
Send a message via AIM to 28HopUp
Quote:
ORIGINAL: doctorj77
For kicks, I tried blowing through the new filter, and then through the old one in comparison. WOW! My old one was MUCH harder to blow through. With the cruddy gas in my area, I now change my fuel filter once a year.
__________________
1985 SSP Mustang - California Highway Patrol Unit #E408395
We are the music makers, and we are the dreamers of dreams - Willie Wonka
28HopUp is offline   Reply With Quote
Old 03-11-2008, 04:20 PM   #9
GidyupGo
Vehicle: 2007 GT
I did the same thing. Blew a little gas out and that was it. No difference between the old and the new after 12k miles. I kept the old one for a backup.
__________________
O ne
B ig
A ss
M istake
A merica
Old 03-11-2008, 11:34 PM   #10
nineinchnail1024
Quote:
ORIGINAL: 05BlackPony
+1
__________________
Whipple Crew-10psi-Spec II-BMR LCAs-BMR sway bar delete-Spydershaft-M/T 26x11.5x17-Hurst-Prothane Mounts-PMP Line locks-Flows-Thump_rrr-Moroso separator-11.39@119mph
Daily Driver-2010 Prius-52.3mpg since new
Beater-1995 F150 XL-302 5spd
nineinchnail1024 is online now   Reply With Quote
2005, autozone, ff686, ff756, filter, fram, fuel, gt, ii, mustang, replace
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
