Go Back   MustangForums.com > Ford Mustang Tech > 2005 - 2011 Mustangs
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 04-26-2008, 08:18 PM   #1
DoctorQ
Default Fuel Tank Fill Update: 2nd Fix by FORD
About 4 weeks ago I posted a poll regarding the fuel fill issue. I wanted to share those results (which I took to my meeting with Ford) with this forum along with events from the meeting. The poll question asked if forum members have experienced the premature fuel nozzle shut-off while attempting to fill their tanks (usually shutting off after ½ tank). I posted the poll on 3 separate S197 Mustang Forums with the following results:
224 Total Responses:
20% (44) responded that they ALWAYS encounter the fuel fill issue.
51% (115) responded that they have encountered the issue, but not all the time.
29% (65) responded that they have NEVER encountered the fuel fill issue.
Now, I know this poll may not subscribe to accepted scientific study standards, however, most of data was collected within days of the posted poll. IMO, this is a surprisingly high percentage (71%) of S197 owners who have experienced this fuel fill issue (either all the time, some of the time, or resort to flipping/inverting nozzle in order to fill their tanks).
Background: I have an 06GT (18 months since I drove off the lot). For the 1st year, I would encounter the fill issue about every 3rd or 4th fill-up… stopped at half-tank each time. I tried all the tricks to re-engage the fill (turning nozzle.. inverting nozzle…), no dice. No additional fuel could be added. During the past 6 months, the problem began to escalate to just about every fill-up. Finally decided I’ve had enough and scheduled my first fuel-fill warranty service trip. Ford found that the EVAP Canister was slightly obstructed causing excessive tank pressure build-up as the tank was being filled. They did this by monitoring the FTP (Fuel Tank Pressure) sensor. Sensor voltage started out at 2.6v, then reached 3.5v at ½ tank. As was explained to me, any voltage above 3.5v is too high, meaning excessive tank pressure is being experienced. Fuel system interpret this as tank is full (no room left for fluid), and causing pump to shut off. This voltage should never exceed 3.2 – 3.3v. Ford replaced my entire EVAP Canister assembly tray (EVAP canister, canister vent solenoid, EVAP filter), cleaned all the lines, checked purge-valve, tank check-valve, and tank pressure…all was good.
Within 3 weeks, issue came back; however, after the ½ tank fill stop, I was now able to invert the nozzle to 2-o-clock position, and continue to fill tank completely. So I contacted Ford dealership and they arranged for a Ford Rep to come out. I was instructed to return to the dealership with less than ¼ tank. Upon arrival, the Ford Rep was a no-show, but he left instructions with the Service Manager insisting we take my car to a station of his choice, as he claimed the issue is with certain stations (fuel flow rates) and nozzle design. I refused and shared with them that I bought this vehicle in good faith assuming I could get gas anywhere of my choosing… dealership lead tech agreed, so we piled in my S197 and headed to my local fueling station. Ford’s Drivability Lead Tech hooked up his laptop to the OBD port then instructed me to open tank cap and begin filling. I was also instructed to lock the pump on the lowest speed auto fill and do not touch it (i.e., “step away from the nozzle”). He monitored the FTP sensor voltage as the tank filled. Sensor started out at 2.6v.. .then slowly climbed to 3.1v, but no higher (due to the new EVAP canister assembly). CLICK… tank shuts off @ ½ tank. This was actually good news as it indicated that excessive pressure was not to blame (as it was before) for the premature nozzle shutoff… but something else. I then challenged him to attempt to fill tank completely. He tried, several times, unsuccessfully. I then showed them by inverting nozzle to 2 o clock position I could continue to fill up… and fortunately this worked… the remaining 7.5 gallons (right side saddle tank). Ford’s Drivability Lead Tech stated this proved it is NOT just an EVAP emissions pressure issue, but also a filler neck design issue.
He shared with me that the Ford Rep had previously shared with him that Ford was aware of the S197 tank design flaw, and they have encountered this fuel fill issue numerous times. Midpoint mounted saddle tanks… in a lower-profile vehicle… with all the required EVAP emissions systems, just don’t play well together (late model Corvettes have this same issue). Many things must come together in order to fill our tanks completely: (1) proper filler neck angle (more on this below); (2) pristine EVAP emissions system; (3) slow fuel fill rate. When excessive tank pressure builds, station nozzles will shut off. The S197 has multiple points causing back pressure: tank inlet check valve, saddle tank design and improper venting, inlet filler neck hose size and inlet hose angle, EVAP emissions system (EVAP canister, canister vent solenoid, EVAP filter, canister purge valve, FTP sensor, etc, etc).
So here is what they did: We returned to the dealership, put my rig up on the lift, and the Ford Drivability Lead Tech showed me the inlet hose issue. This hose attaches directly to tank inlet, and in most cases, is a bit too long and improperly angled. He disconnected this inlet hose and cut off approximately 3/8 of an inch (depending on each car, this can vary). He cut off enough to angle the tube directly down to the tank inlet flange. Shortening the hose also required lowering the hose support bracket. Lowering the hose support bracket required adding a spacer between bracket and body. This spacer allowed the bracket to drop down another ½ inch helping the overall inlet angle to tank. See pictures in post #2 below. Next 2 fill-ups (at the same station, same pump where I ran into the fill issue) no stoppage! Tank filled to full each time without stopping.
On the record, Ford said this issue is caused by the variability of each station’s pump pressure and nozzle design. Off the record, Ford admitted the issue is caused by the inherit S197 tank design flaw. They also said they are aware of the issue and designed a fix about a year ago; however, this fix involved re-routing the inlet hose through the trunk and strait down to the tank. Two problems with this fix: (1) too costly for Ford to retrofit all the problem S197s on the road; (2) safety concerns with routing fuel into trunk area. Bottom-line: Ford abandoned this fix.
Now, why don’t all S197s have this issue? It appears that for issue to surface, (1) vehicle’s EVAP emissions system has a slight obstruction (either due to dirt or kinked evap hoses), AND/OR (2) fuel inlet hose is improperly angled and slightly too long (causing a slight upward rise in hose immediately before attaching to tank), AND/OR (3) fuel fill rate is too fast and/or filling station tank pressure too high. So, if you’ve never encountered this issue, feel fortunate all the “saddle-tank filling stars” are all aligned in your favor. However, keep in mind over time, your EVAP emission system will begin to become dirty, and that may be just enough to tip the scales to the ½” fill syndrome down the road.
Sorry for the lengthy post, but I wanted to provide feedback to possibly help those still plagued with the fuel fill issue. For some, cleaning (or replacing) the EVAP canister/ emissions system is enough to allow full tank fill. For others (like me), it took both the replacement of the EVA
DoctorQ is offline   Reply With Quote
Old 04-26-2008, 08:25 PM   #2
DoctorQ
Default RE: Fuel Tank Fill Update: 2nd Fix by FORD
Here are the attachments (pictures of modifications)
[IMG]local://upfiles/48520/0E21AE7AAEAC41DCB00FF9326E1660F1.jpg[/IMG]
[IMG]local://upfiles/48520/531C9A3B389648B7A45693E81404A2A0.jpg[/IMG]
[IMG]local://upfiles/48520/E496732A11464F09B2F2FA4B247D071D.jpg[/IMG]
Old 04-27-2008, 04:23 PM   #3
Mr_ED
Good write-up. Very informative. Way to stay on top of the problem until you got it resolved. I've had this fill up issue (stops at 1/2 tank full) a few times, but never could figure out what causes it. Nice ride DoctorQ !
Mr_ED is offline   Reply With Quote
Old 04-27-2008, 04:32 PM   #4
probinator
with gas at 4.12+ a gallon here in CA. 1/2 tank dont seem to bad
__________________
2007 Redfire GT with SCT2 W/ C&L CAI. ZEX Nitrous kit, O/R X Pipe, Delete Plates,Steeda UDP, 4:10's, Lowered, spohn Lca's, panhard bar, Sway bar delete, Hurst STS, Tint, MMR rear seat delete. Stock Exhaust, Shortie antenna. ALL GO NO SHOW.
probinator is offline   Reply With Quote
Old 04-27-2008, 05:39 PM   #5
Orion_240
Orion_240's Avatar
Vehicle: 2008 Shelby GT Convertible
I want to thank you for one of the best, most easy to understand write up on all of Mustang Forums!
I am glad you didn't attack Ford but worked with them to find not just what causes this issue, but how to fix it.
It seems to me that the driver's side tank fills up first, and as it gets to the top there's like an inverted nozzle effect which would account for the buildup in pressure and why the pump shuts off at exactly halfway.
Of course my issue is that the pump can shut off after just 20 seconds or so! But I've always been able to turn the nozzle up and get in as much gas as I'd like.
So I don't have the half-tank syndrome, but I bet one of the other fixes would work. I've just dealt with this issue because it's actually kind of unique having to fill my GT this way, but mainly because I wasn't enthusiastic about the prior "fix" which was removing and installing a new tank!
Thanks for the post![sm=smiley20.gif]
__________________
2008 Shelby GT Convertible, Vista Blue, Auto, 100% stock
Sold:2005 Mustang GT, Premium, Screaming Yellow, Auto, Interior Upgrade Package, Black Bullitts & Eibach Pro-Kit Louvers are featured here:http://www.wheelskin.com/
Orion_240 is offline   Reply With Quote
Old 04-28-2008, 02:06 PM   #6
DoctorQ
Quote:
ORIGINAL: Orion_240
Thanks... I extract a lot of valuable info from this Forum, so just trying to give back . I couldn't live with flipping the nozzle around constantly to get gas... we should not have to rely on tricks to fill our tanks. Hope you get it solved as well.
Old 04-29-2008, 12:22 AM   #7
mcgyvertech
Send a message via AIM to mcgyvertech
I've had this issue with my Stang AND my 1991 Jeep Wrangler. I've noticed that the dispenser nozzle with which I've had the most problems is a plastic unit made by HEALY.
Has anyone else noticed this?
__________________
mcgyvertech is offline   Reply With Quote
Old 04-29-2008, 10:41 AM   #8
luckydawg003
2007 Ford Mustang
luckydawg003's Avatar
Vehicle: 07 Ford Mustang GT
Ya lately Iv'e been having a lot of problems filling up. I always go to the same gas station and use the same pump. Last time it put in like 3 gallons then spilled a bunch on my rear quarter panel. I was pissed. Then had to turn handle sideways and slowly fill it up. Ford needs to fix this ****. Guess I better make an appointment.
__________________
luckydawg003 is offline   Reply With Quote
Old 04-30-2008, 08:09 PM   #9
DoctorQ
Quote:
ORIGINAL: luckydawg003
I know the feeling. I found a station which also allowed full fills; but then I found myself worrying if I'd make it back to this station if I got low on fuel. Finally couldn't accept this condition, so I pursued a more permanent solution where I won't be concerned where I have to fill up. Hope you get it resolved as well.
Old 04-30-2008, 08:18 PM   #10
ryterngki
Very good write up. I've got to take my stang in next week about the passenger side air bag issue and will mention this, too. I have the same problem every 4th or 5th fill.
__________________
Every time someone says something wrong on the internet a little puppy dies.
ryterngki is offline   Reply With Quote
2005, canister, delete, evap, imglocalupfiles485200e21ae7aaeac41dcb00ff9326e1660 f1jpgimg, mustang, s197, solenoid, vent
Featured Sponsors
New Sponsors
Internet Brands, Inc.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford is a registered trademark of the Ford Motor Company
