Go Back   MustangForums.com > Ford Mustang Tech > 2005 - 2011 Mustangs
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 06-10-2008, 02:14 PM   #1
07GTCS4ME
Default Any input about CMCV delete plates?
I've done a little bit of looking into some CMCV delete plates and and curious if anyone has some first hand experience with them and would like to share any information or tips with me.
__________________
2007 Mustang GT/CS Vista Blue
C&L Cold Air/SCT Livewire Tuner/Bassani BX Exhaust (X-Pipe/Axle-Back)/Steeda Intake Spacer/Steeda Strut Brace/Lots of Extras Inside/Out
07GTCS4ME is offline   Reply With Quote
Old 06-10-2008, 02:28 PM   #2
05Saleen#243
Vehicle: 05 Saleen S281 #243
Default RE: Any input about CMCV delete plates?
Go for it. The stock ones with the valves will limit your top-end HP depending on your mods.
__________________
2005 Saleen 3-valve #243 - aka "Candi"
MMR Annihilator Intake
GMS Coils
SLP Longtube Headers
SLP x-pipe
1-piece Aluminum Driveshaft
Pro 5.0 STS
BMR Rear Suspension
05Saleen#243 is offline   Reply With Quote
Old 06-10-2008, 02:38 PM   #3
acascianelli
2001 Volkswagen New Beetle
My Garage
acascianelli's Avatar
Vehicle: 2007, Ford, Mustang GT
Send a message via AIM to acascianelli
You'll gain a little top-end power, but lose a little low-end torque. If you're going from a stock setup, then you probably won't notice the loss in low-end torque because a new tune will usually comphensate for it. You'll also lose some fuel economy. Don't bother with the $300 billet set, they aren't any better than the cast ones. If you can find them used, that's probably the best deal because for $140 new there are better mods that you can do. If you ever plan on getting a roots or twin-screw supercharger they will be useless after that because the supercharger will replace them.
__________________
2007 Mustang GT
Bamachips Race Tune
Sequential Tail Lights
Steeda Billet CMDP
Hurst Short Throw
Pypes O/R X-pipe
C&L Racer Intake
Switchblade Key
5 Speed Manual
3.55 Rear Axle
SCT Livewire
Steeda UDP
acascianelli is offline   Reply With Quote
Old 06-10-2008, 02:51 PM   #4
tn_gt
Vehicle: 2008 Mustang GT
ok not too mechanically inclined yet, what exactly are the delete plates compared to stock, how hard to install, how much and how much performance gains? with a bama 93 race tune
__________________
FOR SALE: BRAND NEW GT FOG LIGHTS
2008 Mustang GT 5spd
Bamachips 93 Race Tune
C&L CAI
Pypes Mid-Muffler System
20" American Racing Rogue Wheels
CCFL Headlights
tn_gt is offline   Reply With Quote
Old 06-10-2008, 04:08 PM   #5
acascianelli
My Garage
Quote:
ORIGINAL: tn_gt
Charge motion control valves are a set of small butterfly valves that sit in each intake runner. Their purpose is to disrupt air and create a more turbulent air flow to promote better low end torque and fuel economy. The valves open up completely at around 3000rpm to allow the intake to flow freely. The cross section of these valves does create a slight obstruction in the intake runner. There for, removing these valves allows air to flow more freely and thus giving you more power in the higher revs.
They are not that hard to install, I was able to install them in about an hour and I consider my skills to be slightly higher than novice. I'd say you're looking at gains between 6-8whp.
__________________
2007 Mustang GT
Bamachips Race Tune
Steeda Billet CMDP
Hurst Short Throw
Pypes O/R X-pipe
C&L Racer Intake
Switchblade Key
5 Speed Manual
3.55 Rear Axle
SCT Livewire
Steeda UDP
Old 06-10-2008, 04:13 PM   #6
white07
When I installed mine afterwards my car wouldnt start. I thought they were the problem so I took them off. I did this a couple times and I got to the point where I took them off and put them on in about 10 minutes. very very very easy and straight forward. My TB was the problem.[:@]
__________________
12.71 @ 99.40mph
white07 is offline   Reply With Quote
Old 06-10-2008, 04:24 PM   #7
DarkFireGT
DarkFireGT's Avatar
I didn't seem to lose anything down low. It's all in the tune. Go for it. It's a cheap easy mod. While you're going to have the intake off, might as well do underdrive pullies, too, to get the best gain, if you don't already have them.
DarkFireGT is offline   Reply With Quote
Old 06-10-2008, 04:28 PM   #8
acascianelli
My Garage
I installed my UDP at the same time as my delete plates. I also upgraded from a canned Diablosport tune to a Bamachips race tune. I'd say I picked up around 15-17hp between the three.
__________________
2007 Mustang GT
Bamachips Race Tune
Steeda Billet CMDP
Hurst Short Throw
Pypes O/R X-pipe
C&L Racer Intake
Switchblade Key
5 Speed Manual
3.55 Rear Axle
SCT Livewire
Steeda UDP
Old 06-10-2008, 05:21 PM   #9
07GTCS4ME
Thanks for all your help guys! Right now my last dyno put my at right under 290whp, but I really want to break the 300whp mark. I've thought about underdrive pulleys, but I'm not sure how complicated that install is. I'm confident I can change the CMCV's with no problem though. I'm fairly new to the tuning world (hence professional tune/dyno) but I'm assuming I'll need to take it in again and have the tune adjusted for either of those. I suppose after this I'm pretty much done with the "less expensive" work.
__________________
Old 06-10-2008, 05:35 PM   #10
Leos06gtLL
Leos06gtLL's Avatar
Vehicle: 06 gt /84 svo 9w
or you can do what i did, I got my factory charge motion plates, removed the butterflies and had a aluminum welder weld the little holes shut, dont know if its cost effective on the welding part but my friend did it for free, great mod by the way DO IT!!!
__________________
06 GT Legend Lime
84 SVO, 09 Charger R/T
Leos06gtLL is offline   Reply With Quote
cmcv, delete, livewire, plates, sct, tuner
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
