Go Back   MustangForums.com > Ford Mustang Tech > 2005 - 2011 Mustangs
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 09-01-2008, 05:51 PM   #101
one eyed willy
2007 Ford Mustang
My Garage
one eyed willy's Avatar
Vehicle: 2007 GT
todays progress
intercooler mounted, pipes plumbed, turbo mounted and downpipe started.relocated the horns.
still need to trim on the bumper for the intercooler,finish the downpipe and make up the pies for the wastegate.i ran out of pipe so i cant finish up for now,and i need to order a few more v bands for the downpipe.i plan to pull it all off in the next day or two and throw my x-pipe back on for the dragstrip meet we are having at bradenton. while its off im handing it off to my dad who will weld it all up for me.then maybe next weekend ill throw it all back on for the last time and go get it tuned.
__________________
2007 GT
5 Speed
Forged and Turbocharged
Quote:
Originally Posted by tampa07gt View Post
Next week Willy's going to wire his electronic throttle to the fan relay and run it off his on board LAN to NASA to ensure he runs at the correct temp based on real time global atmospheric conditions. Oh yea after he makes his own installation tools
one eyed willy is offline   Reply With Quote
Old 09-01-2008, 05:55 PM   #102
one eyed willy
2007 Ford Mustang
My Garage
Vehicle: 2007 GT
Quote:
Originally Posted by MustangGT0405 View Post
So now that you have the oil sender for the aeroforce gauge can you compare what it showed you from the ECM readout to the actual readout? I would be interested to know how close they were.
Thanks,
And great job on all the work so far.
there is no factory PSI gauge,thats the reason i needed the aeroforce. the factory sensor is only a switch, so it open or closed only at certain PSI, it wont show any variables.
__________________
2007 GT
5 Speed
Old 09-01-2008, 06:38 PM   #103
kpaulhus
2007 Ford Mustang
kpaulhus's Avatar
Vehicle: 2007 Mustang GT
looking great....next time we go to the track hopefully it will be cooler out and you can compare your #'s from this thursday.
__________________
2007 Mustang GT / Shaker Hood / Mac LT's and O/R Prochamber
C&L Street Intake / FRPP 4.10's / BRENSPEED 93 Race Tune
1/4 Mile: 13.1 @ 105 mph
286 hp & 292 tq
Buy my car...
http://mustangforums.com/forum/musta...ustang-gt.html
kpaulhus is offline   Reply With Quote
Old 09-02-2008, 11:23 AM   #104
MustangGT0405
MustangGT0405's Avatar
Vehicle: 2007, Ford, Mustang GT
Quote:
Hmm I seem to remember that there was a oil pressure reading, but I might be thinking of Fuel pressure.
I usually monitor Coolant temp and IAT. I had the IAT relocated to after the blower so I can see the real number. Using a blow through setup on a turbo no relocation is necessary
__________________
Whipple Crew Member
484rwhp 469rwtq
MustangGT0405 is offline   Reply With Quote
Old 09-02-2008, 02:18 PM   #105
magden auto
Just a quick note, make sure that IAT sensor is located as close to the injectors as possible, somewhere on the manifold would be best. (Just like the supercharger kits that relocate them to the manifold). Also, adding another one on the inlet of the turbo would give you good numbers to compare between the two. It would tell you how efficient the intercooler is and how much every pound of boost you increase would also increase the IAT the engine sees.
What kind of boost controller are you going to use?
-Jon
__________________
- Jon,
magden auto is offline   Reply With Quote
Old 09-02-2008, 09:31 PM   #106
one eyed willy
2007 Ford Mustang
My Garage
Vehicle: 2007 GT
-Jon
yes,thats a good ideal on IAT. my maf will only be about 12 inches from the TB. im hoping thats good enough for the computer. i would like to know the difference once it goes thru the intercooler, i could buy another sensor for the aeroforce.
im using a AEM boost controller thats built into the gauge. im really thinking that the 5psi spring in the wastegate may be enough i wont have to fiddle with the AEM. hopefully i can get 7-8 psi just off the spring.
__________________
2007 GT
5 Speed
Old 09-02-2008, 11:22 PM   #107
lrgnation
lrgnation's Avatar
Vehicle: 2006 Mustang Coupe
Send a message via AIM to lrgnation
Nice work and make sure you heat paint those brackets!
__________________
lrgnation is offline   Reply With Quote
Old 09-02-2008, 11:40 PM   #108
zporta
2007 Ford Shelby GT500
zporta's Avatar
Vehicle: 2007 Shelby GT500
wow man i havent read this post in a while and there sure has been a world or progress...everything looks great...def starting 2 see the light in the end of the tunnel cant wait 2 see the finished project
__________________
zporta is offline   Reply With Quote
Old 09-03-2008, 07:41 AM   #109
one eyed willy
2007 Ford Mustang
My Garage
Vehicle: 2007 GT
Quote:
the plan is to get all the bugs worked out and tuned on the dyno, drive it for a few weeks and then ill be breaking it all back down to get everything powdercoated. ill be doing the valve covers along with everything else all at once.
__________________
2007 GT
5 Speed
Old 09-03-2008, 10:13 AM   #110
ryanralston07
How much longer till it's finished? Can't wait to see the #'s and see some vids
__________________
07 GT, Street Scene, Steeda Wing, Ram Air Hood, Hurst, Magnapacks, Whipple HO, Autometer Gauges/Pod, Avic D3, BMR UCA & LCA, Spec 3+
ryanralston07 is offline   Reply With Quote
31x12x3, blanket, blow, caution, diy, gt, intercooler, kits, master, mustang, power, t70, turbo, turbonetics, turboparts, valve
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
