Go Back   MustangForums.com > Ford Mustang Tech > 2005 - 2011 Mustangs
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 11-02-2009, 10:29 PM   #101
scheetz83
scheetz83's Avatar
Vehicle: 2005 Ford Mustang V6
Quote:
Originally Posted by ZeyadK View Post
I visited the Ford dealership in Egypt and they said that there is nothing they can do to help me. Is there a way that I can Reflash my PCM on my own?
WOW thats messed up sorry to hear about your issue. I was all set to try this but now not so much
scheetz83 is offline   Reply With Quote
Old 11-02-2009, 10:53 PM   #102
jz
jz's Avatar
Vehicle: 06 mustang GT
Disconnect the battery over night. Sometimes a short disconnect will not fully reset the computer. A overnight disconnect will.
__________________
06 Yellow GT 5 Speed. Pro 5.0 shifter, Steeda HD rear sway bar with billet end links, Steeda front sway bar, Steeda UDP, BMR combo adj LCA's, BMR combo UCA, BMR adj panhard bar, K&N CAI, Steeda strut tower brace, Magnaflow Magnapack cat back, BAMA chips SCT, Ford Racing 4.10's, Sequential tail lights, Shorty antenna, Silverhorse Racing rear center cover.
jz is offline   Reply With Quote
Old 11-03-2009, 10:57 AM   #103
ZeyadK
Vehicle: 2005, Ford, Mustang GT
Quote:
Thanks for the suggestion. Are you sure it'll work?
ZeyadK is offline   Reply With Quote
Old 11-04-2009, 02:31 AM   #104
ZeyadK
Ok so I disconnected the battery for 14 hours and just reconnected it, but its still the same
Old 11-04-2009, 10:20 AM   #105
jz
jz's Avatar
Unforutantely that's all I have for suggestions. I've had quite a few problems that were not resolved with a quick unplugging of the battery, but an overnight unplugging resolved the issue. Other than seeing if the Ford Dealer could reflash it, I'm short on suggestions.
Do you have any other Ford dealers in Egypt?
One last question, when you unplugged the battery, which terminal(s) did you unplug? If you didn't unplug both, do that over night. I know it sounds stupid, but I've had dumb issues through the years that have been resolved by completely unplugging the battery (both terminals) overnight.
Good luck.
__________________
Old 11-04-2009, 12:39 PM   #106
ZeyadK
Good luck.
I only unplugged one of them, the positive
but I guess il give it a shot, I have nothing to lose.
thanks for the suggestion
Old 11-04-2009, 05:49 PM   #107
harraid5711
harraid5711's Avatar
Since you performed that sequence and it "enabled" something, try doing the same sequence and maybe it'll disable it.
I know that when you perform the seat belt chime disabling sequence, you can turn it back on by performing the sequence again.
worth a shot....
__________________
05 GT Prem,5spd,JLT2 w/Bama race, 4.10s, Steeda UDPs, Street Scene Gen 1 bodykit, Eibach prokit springs, hoodpins, Hurst shifter,O/R-H, various other appearance mods, Boomtube Crew
Exhaust Clip
harraid5711 is offline   Reply With Quote
Old 11-04-2009, 09:10 PM   #108
atldave
atldave's Avatar
Vehicle: 2008, Ford, Mustang Convertible V-6
I have done #1 myself, but it's not necessary to disconnect the battery first. There are step-by-step instructions somewhere on this forum about how to do it. I did it to reset the adaptive memory because I bought my car from a rental fleet and it had learned to acccelerate like there was a granny driving it.
BTW, I am simply amazed at the settings that are controlled by computer. My Shaker 500 CD player died (under warranty, thankfully!) I noticed that the new one didn't have a convertible setting. The dealer uploaded some code to the computer to add that function. I also had some bounce-back from a power window. You would think that would be fixed in the window itself but the dealer fixed it through the computer again.
__________________
2008 V6 auto convertible. GT single take-off exhaust, front and rear GT sways, rear blackout panel, 17" Bullitt rims. Door molding deleted so don't bug me about it!
atldave is offline   Reply With Quote
05, 2007, 2008, belt, chime, extensions, gt, manual, mustang, radiator, s197, satin, seat, tricks, v6
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
