Go Back   MustangForums.com > Ford Mustang Tech > 2005 - 2011 Mustangs
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 12-11-2008, 12:02 AM   #1
imyy4u
imyy4u's Avatar
Vehicle: 2006 Ford Mustang GT
Default Free WHP and mostly unknown computer tricks for 05+ Mustangs
OK, so the other day I ran into a friend who knows the 05+ Mustang inside and out. He has played around with the computer in our cars to no end, connecting and datalogging to his laptop constantly. Anyways, in the course of his experimenting, he found and confirmed the following procedures to gain some easy whp and performance without popping the hood. Best of all? They're free, and anyone can do them. OK, here goes:
1) This trick will give your car a lot firmer shifts if you have an auto, and wake up your car a bit if you're a manual. First step is disconnect the battery and let the car sit for 15 min or so, thereby resetting the computer and learning algorithm. Next, reconnect the battery. Get in the car, put your key in, and turn the key to the right almost all the way but do not start the car. Now, over the course of the next 10 seconds: for the first 5 seconds, slowly (and iI mean slowly) depress the gas pedal all the way to the floor. Now, during the next 5 seconds, slowly release the gas pedal until 10 seconds when the pedal should be fully released. Now in order for this to work, you must have your timing right - close won't do it (you must be within 1 second). What this does is reset the drive-by-wire mechanism, and resets the gas pedal so that if you have some lag when you floor it, now the power will be instant. The gas pedal will basically be much more responsive and power more instantaneous. This makes a much bigger difference in autos than manuals. This will work with 2005-2009 v6 and GTs and it probably (I'm not sure though) will work with custom tunes loaded.
2) This trick will give you about 15whp, give or take. After detaching the battery and letting it sit for 15 min, go ahead and reattach it. Get in your car, and turn the key almost all the way to the right - as far as you can without starting the car. Now, over the next 10 seconds, turn traction control off, then on, then off, then on...etc until you have turned it both off then on 9 times each (on must be the initial state, so if you have a tune that turns it off on startup, you can't do this procedure). After the 9th time, you *may* (not all cars do this for some reason) see either your T/C light in the dash or your T/C switch/button flash 1 or 3 times. After the flash (or if you don't see it, wait 1-2 seconds), turn the T/C off, then on, once more. What this does is set your computer programming into dev/test/aggressive mode - this was the mode used by the Ford engineers to test the limits of the engine and was originally designed to be the final programming. However, to cut back on gas requirements, and because this tune was too aggressive (!!!), this tune was dropped in favor of our current stock tune that is more gas friendly. If you do this mod, you won't notice a difference unless you have 91 or 93 octane in your tank, because otherwise it just reduces the power to the normal stock tune level if you are running regular 87 octane. However, if it detects 91 or 93 octane, it will bump up timing as much as it can safely resulting in a lot more whp. This may not work on 08/09 and probably works on 07. Def works on 05 and 06 v6/GT models. Oh, and if you're wondering why it doesn't come up on a list of included tunes on the ecu if you use a programmer? It's because it's made hidden in memory as part of the base/stock tune and therefore scanning/tuning devices only see the stock tune. I must warn you guys tho, that I don't think this will work if you have a custom tune since this tune is hidden inside of the stock one which you aren't running. Oh, and wanna hear something funny? I hear this tune, with a few mods for CAI, is the tune that the 2010 Mustang will run...how interesting...
3) Third, and most of you know this, is to disable the seatbelt warning chime. Turn the key in the car to on, but don't start the car (like in the other steps). Then, buckle and unbuckle your seatbelt 9 times each over 10 seconds. Now the seatbelt light will blink in your dash, and after that, buckle and unbuckle once more. This will permanently get rid of your seatbelt chime. This procedure can also be repeated on the passenger side, but both cannot be done at the same time. You must do one side first, turn off the car, and then do the other after putting the key back to the on position without starting it. Then both seatbelt warning systems will be permanently disabled :-D
Just thought you'd guy's appreciate this...I've tried #1 and #3 and they both work, but I haven't tried #2 yet. All I can say is that these hidden features are great!!! Let me know what ya'll think of them after you try them :-)
__________________
-john
2006 ford mustang gt coupe 5spd
black on black, shaker 1000, IUP, 3.55 gears
slp loudmouth exhaust
13.498 in the 1/4
2003 s/c debadged pwp rsx-s
265whp/186wtq = ~302hp
sold 7/25/06
imyy4u is offline   Reply With Quote
Old 12-11-2008, 12:10 AM   #2
rford426
Vehicle: 2005 Mustang GT
hmmm? seems kinda out there
__________________
2005 Black GT Manual
Steeda CAI-SCT XCAL-Pypes O/R X pipe-Pypes Mid Mounted M80s-Red Top OPTIMA-HurstSTS-Tein Tech S-AVIC f900bt-Back up Camera-20" Black Chrome FR500s-GT500 FRONT/REAR-Factory GT500 6k HIDS-3k HID Gt500 fogs-
303rwhp/319tq
rford426 is offline   Reply With Quote
Old 12-11-2008, 12:59 AM   #3
Ato
Ato's Avatar
Vehicle: 2008 Mustang GT
2) sounds exactly like what ford is doing w/ the 2010 like you mentioned at the end. Basicly instead of burying this programing they are letting the addaptive learning work at high octane levels. What I wonder is if you were to do this tuning trick w/ an aftermarket intake if it would still throw a code. While I don't know the size off hand the bullitt intake in the 2010, it is larger then the stock airbox in a 2005-2009.
__________________
2008 Mustang GT Premium Alloy
5spd, 3.55 Gears
  • GT500 spoiler, SHR Honeycomb panel, paint matched mirrors, 18" Argent Grey BULLITTS, CDC classic
  • Steeda Axlebacks, JLT CAI/93 street race Tillman Speed Tune, Hurst STS
  • Roush rear springs, Tokico d-specs
Grey Mustangs Registryhttp://www.greystangs.com
Ato is offline   Reply With Quote
Old 12-11-2008, 01:05 AM   #4
suttanstyle
Send a message via AIM to suttanstyle
I hope step #3 works, I've been wanting to disable the seat belt security function.
__________________
2006 Black Mustang GT Premium w/ Saleen Front Fascia & Side Skirts
20" Saleen 5-Spoke Forged Chrome Wheels w/ Pirelli PZero Tires 275/35/20 (front) 305/35/20 (rear)
GT500 Rear Spoiler | UPR Antenna Delete | Limo-Tinted Rear Window | SLP Loudmouth Exhaust
Factory Plenum Cover | Radiator Extension Covers | Shock Strut Tower Covers | Bullitt Hood Blanket
Saleen Head Rests, 3 Piece Pedal Kit, Door Sill Plates, Horn Badge, S281 3-Valve Fender Badges,
Extreme Quarter Window Blanking Plates
suttanstyle is offline   Reply With Quote
Old 12-11-2008, 02:44 AM   #5
Jersey Stang
Jersey Stang's Avatar
Vehicle: 2006 Mustang GT
up, up, down, down, left, right, left right, b, a, start will give you an extra 30 lives i think...
__________________
06 SATIN SILVER GT
SALEEN STAGE III POWERED BY BRENSPEED
STEEDA CAI
FRPP3.73's
FRPP STINGERS
GT500WHEELS
METER4IT CHASE LIGHTS
Jersey Stang is offline   Reply With Quote
Old 12-11-2008, 03:26 AM   #6
So_Cali
2006 Ford Mustang
So_Cali's Avatar
Quote:
LMAO CLASSIC!
__________________
S197 Sized Sig--I Haz It...Thanks Xeno!
2006 Performance White V6
More Show Than Go
Roush CAI BAMA Tuned
Retro-Solutions 8K 35w HID Kit
Staggered 18" Bullitts w/ NITTO 555's
Web-Electrics Sequentials
Eibach Pro-Kit
Tokico HP Gas Shocks
Ninosport Dual Conversion w/GTB's
GT Takeoff Rear Swaybar w/Prothane Poly Bushings
"California Made It Happen"
So_Cali is offline   Reply With Quote
Old 12-11-2008, 05:57 AM   #7
CrazyHorse0217
Angry seatbelt chime
This one is in the owner's manual. Never worked for me.
__________________
CrazyHorse
2006 redfire GTcoupe w/ auto trans
3.73 FRPP gears
Roush supercharger w/ pulley upgrade
Steeda CAI
Custom tune
Roush wheels & Nitto 18 285/275
CrazyHorse0217 is offline   Reply With Quote
Old 12-11-2008, 07:48 AM   #8
Norm Peterson
2008 Ford Mustang
Norm Peterson's Avatar
Vehicle: 2008 GT Premium
Quote:
Any chance that this friend knows how to make the default traction control state = off, or how to make the TPMS system ignore wheels/tires that don't have sensors?
Norm
__________________
08 GT Premium Black/Light Graphite, stick, un-FStock
weenie-EP 626/V6/stick, Prepared just enough, sometimes
Norm Peterson is offline   Reply With Quote
Old 12-11-2008, 07:52 AM   #9
cougarfan088
ill stick with my custom tune.
cougarfan088 is offline   Reply With Quote
Old 12-11-2008, 07:57 AM   #10
Nuke
2007 Ford Mustang
My Garage
Nuke's Avatar
Vehicle: 2007 GT
Send a message via AIM to Nuke Send a message via Yahoo to Nuke
Quote:
Ditto... Why mess with perfection?
__________________
Rick
07 GT Prem: Alloy, MT, 3.55's, Steeda CAI w/Brenspeed tunes, FRPP Stingers, 275/40/18 Goodyear Eagle F1 A/S on SVT Cobras (OE GT500's), 14" shorty, Wheelskin side scoops & qtr window louvers, A-H rear window louvers, SHR honeycomb blackout panel, Sequentials, Hella Optilux Extreme XY fogs, Silverstars
06 V6: Legend Lime, Pony Package, 14" shorty, Sequentials, Hella Optilux Extreme XY fogs, Silverstars
Nuke is online now   Reply With Quote
05, 2007, 2008, belt, chime, extensions, gt, manual, mustang, radiator, s197, satin, seat, tricks, v6
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
