Go Back   MustangForums.com > Ford Mustang Tech > 2005 - 2011 Mustangs
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 12-21-2008, 12:21 PM   #1
eddypython
2006 Ford Mustang
eddypython's Avatar
Vehicle: 2006 GT
Send a message via AIM to eddypython
Default HOW TO: Darken Headlights and Tail lights with VHT
Moderators: might want to sticky this, i know allot of people have asked for it and here it is..
First, There are two things being done in this how to. Headlights mainly, and tails. Do know, that the SAME exact process is involved in both. So every step done on the headlights is done on the tails..
I will post mainly the headlights since I have more pics of them done.
Items needed for this job
-1000 grit sandpaper
-2000 grit sandpaper
-medium and fine scratch rubbing compund
-alcohol or acetone
-lint free rags / microfiber rags
-random spin orbital buffer ( I purchased mine from autozone for $20. the 6 inch one )
might want to get some extra bonnets.. they come in handy
- VHT translucent paint.. bought it from here http://www.trucknvans.com/SearchResults.asp?Search=VHT
- Clear coat . I use ONLY Sherwin Williams " UltraBase 7 KutIn spray can "
- Bowl of water
Start by dry sanding the lens
Only difference between headlights /tails is you ONLY use 2000 grit on the headlight.
Tails you use 1000 grit for the first step
Once done sanding. It should look like this
Clean it with a lint free rag and either alcohol or acetone. This will ensure no oil, wax, or other impurities will be on the lens.
When you spray the lenses, ALWAYS start with the edges. The edges need more attention so that light won't shrow through or have imperfections.
Spray a THIN coat of VHT. When I say thin, I mean thin. This coat will act as a bonder..
Should look like this
Wait about 10-20 minutes in between each coat ..
After the first thin coat you can make them a bit thicker. not too thick though.. And always spray both lenses evenly... Don't want one darker than the other
After about 2 more coats. it should look like this
another coat will have them looking like this
http://i226.photobucket.com/albums/d...0SCARLET/8.jpg
Finally after the 6th coat ( remember they are not heavy coats ) it will look like this
After the final coat is dried up, inspect it to make sure nothing got on the surface, sch as duct, a gnat, fly or something of that sort. If that happened you can do a quick wetsand with 2000 grit to get the impurities off the lenses. And clean it with alcohol.. Don't rub it too hard as alcohol or acetone will strip paint off.. so you might want to be careful with that. If you feel uncomfortable with that just use soap and water and wipe it clean..
Then comes the clear coat.
again, thin coat first as a bonder..
Wait about 15-20 minutes for that coat to dry.. then spray a medium wet coat..
when you spray clear, try to look at the lenses with light coming towards you not from behind you, so that you can see how even you apply the clear..
( when I talk about light, I mean face the garage door or whatever place you are in )
After about 20 minutes, apply the last coat. this one will be heavy..
Allow the clear to dry overnight..
One thing you will notice is that the clear at first might be a bit hazy/. That happens when you apply too much. Dont' worry, it will clear up..
The whole cure time on the lenses would be aprox about 2 weeks, depending on temperature and if you park in the sun or in the garage..
so if your lens fogs up after about a week and it's not as shiny as it was when you were done, it's ok. It's because it cured up.. All it needs is another quick buffing and it will be like new again.. ( in case this happens )
So once you are ready to start making magic happen you need to grab you a bowl of water, some 2000 grit sand paper, some elbow grease and patience ..
Srat Wetsanding the lens in a side to side motion only. Don't do circles or any othe pattern. I've done that in the past and bellieve me you don't want to repeat my mistakes heh
You want to make sure your lens does NOT look like this when you think you are finished
You need to sand those little shiny bubles off the lens.
Your end result WILL look like this
Now you are ready to buff.
Grab your orbital buffer, and the rubbing compund.. Again medium to fine scratch remover.
apply a generous ammount of compund to the lens and spread it around..
Buff it for a good ammount of time untill the compund is no longer white, but looks like a oily residue on the lens..
Then clean up the lens, and change the bonnet on the buffer. You want to repeat this last step again.. So twice per lens.. usually about 15 minutes each time.. so about an hour for both lenses toghether.
Once done, clean up the lens.. Change the bonnet and time to wax it ..
I use NXT 2.0 and I love it..
Give it a good wax and the end result will look like this
Hope this helps all you guys that want to do these mods your own selves.
One thing you need to remember though..
The headlights are for SHOW ONLY. Do not use them as daily drivers.. they will shine through purple and will NOT be legal in most states.. The ones I did I did as a custom order for a club member that uses the car just for shows..
Have fun with this mod, and if there are any questions that I did not answer here, feel free to PM me.
__________________
'06 Premuim GT Torch Red
SLP Crew Member
eddypython is offline   Reply With Quote
Old 12-21-2008, 12:42 PM   #2
MELLOWYELLOW06
2006 Ford Mustang
MELLOWYELLOW06's Avatar
Vehicle: 2006 Mustang GT
Very nice Eddy. Any chance of me shipping my lights out to you and u shipping me yours.
__________________
MELLOWYELLOW06 is offline   Reply With Quote
Old 12-21-2008, 12:54 PM   #3
EagleStroker
2007 Ford Mustang
EagleStroker's Avatar
Vehicle: 2007 Ford Mustang
Quote:
Took the words right oughta my mouth man. Looks great!
__________________
"There are no traffic jams along the extra mile"
http://eaglerod.com/
EagleStroker is offline   Reply With Quote
Old 12-21-2008, 01:08 PM   #4
eddypython
2006 Ford Mustang
eddypython's Avatar
Vehicle: 2006 GT
Those are not GT500 lights and I did not darken mine. I use the car as a DD
It's a very simple process.. and if someone attempting this is a bit scared to do it practice makes better. look for a company eagleeyes that makes headlights and tails for our cars for about 25 $
I am thinking about doing some for other people but I won't be able to be bombarded with orders lol...
Joe if you find a second pair you want to do shoot me a PM and we'll see what we can do.
__________________
SLP Crew Member
Old 12-21-2008, 01:15 PM   #5
One Bad Stang
2007 Ford Mustang
One Bad Stang's Avatar
Vehicle: 2007 GT
good write up. is there any product you know of that wont make the lights look purple at night?
__________________
C&L CAI - Brenspeed tune - FRPP springs - MagnaFlow X pipe - 4.10's - Moser diff cover - BMR panhard relocation bracket - BFG Drag Radials - front sway bar delete - J&M LCA's - J&M relo brackets - J&M adjustable UCA - Pypes Violators - Steeda shock tower brace
One Bad Stang is offline   Reply With Quote
Old 12-21-2008, 04:30 PM   #6
eddypython
2006 Ford Mustang
eddypython's Avatar
Vehicle: 2006 GT
Not that I know of.
__________________
SLP Crew Member
Old 12-21-2008, 05:42 PM   #7
rford426
Vehicle: 2005 Mustang GT
looks good but i need all the light i can get at night with my windshield tinted
__________________
2005 Black GT Manual
Steeda CAI-SCT XCAL-Pypes O/R X pipe-Pypes Mid Mounted M80s-Red Top OPTIMA-HurstSTS-Tein Tech S-AVIC f900bt-Back up Camera-20" Black Chrome FR500s-GT500 FRONT/REAR-Factory GT500 6k HIDS-3k HID Gt500 fogs-
303rwhp/319tq
rford426 is offline   Reply With Quote
Old 12-29-2008, 09:22 PM   #8
eddypython
2006 Ford Mustang
eddypython's Avatar
Vehicle: 2006 GT
Bump for the mods to sticky it PLEASE !
__________________
SLP Crew Member
Old 12-29-2008, 10:19 PM   #9
owero01
owero01's Avatar
Vehicle: 06 Mustang GT
Send a message via AIM to owero01
Nice job. Sounds like an entrepenural opportunity.
__________________
Pro 5.0 STS, C&L CAI with D/S and JPC 93 Performance Tune, Steeda UDPs, Metco LCAs, Spohn adjustable UCA, FRPP 4:10, JPC Aluminum D/S, Eibach Pro Kit, Tokico D Specs, P/h bar, Chr VCs, FM 40s, BO Strut Brace, Seq. TLs, SLP LTs, SLP XPipe/high flow cats, Comp Cams Thumprs, JPC Chrome fuel rails, MSD COPs, Prothane Motor Mounts, BBK Chrome Plenum Cover, Boss 304 chrome wheels, BF Goodrich KDWs, 361rwhp
http://www.youtube.com/watch?v=1S7GfbipgsY
owero01 is offline   Reply With Quote
Old 12-30-2008, 12:16 AM   #10
06satinsilver
06satinsilver's Avatar
pm'ed you ...i wanna get this done asap
__________________
2006 Mustang GT , Vortech V2, AIS water/meth injection, slp line lock, Magnaflow axlebacks, Steeda Tri AX, J+M adj panhard and LCAs, spohn UCA, j+m lca relo brackets, 18x9/10 bullits with Nitto Drags, FRPP springs, Coast Drive shaft.
06satinsilver is offline   Reply With Quote
autozone, buffer, camaro, coats, headlight, headlights, light, lights, mustang, paint, pics, spray, tail, tint, vht
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
