Hey all...I've got a question for you all that I'm hoping comes with an easy fix...LOL!! Anywho, I've got a 2006 GT with a Pypes CATTED X-Pipe and the cat-back exhaust. I'm completely welded...no clamps at all. I have been back to the exhaust shop a number of times, but I cannot get rid of this ticking/rattling noise. Under any amount of acceleration, it's there. It's very clear. Even though this exhaust is super loud, I can still hear it. At first we thought it may be a clamp or the tips being loose, but like I said before, I am completely welded. I'm soooo frustrated!!! I'm about to go back and have the stock exhaust put back on because this rattle/tick makes the car sound trashy. Anyway, I wanted to know from other folks, specifically those who have the pypes system that I do, if this is just a characteristic of the system, or if there is something special I need to do to get rid of this noise!! Any input would be greatly appreciated!
This ad is not displayed to registered or logged-in members. Register your free account today and become a member on Mustang Forums!
I have the Pypes mid muffler dual exhaust set up on my V6. I don't have any ratteling or ticking noise and i have them all clamped up. I do however get back firing and popping noise when i first start my car for about a minute or so.
your hangers are hitting in the back. jack up the rear of the car,look at the hangers that come off the pipes where the mufflers would be. they will be very close to the hangers on the car but not touching. when you accell the hangers will start making contact with each other. i used some rubber hose and zip ties it to the matal hangers, problem solved.
__________________
2007 GT
5 Speed
Forged and Turbocharged
Quote:
Originally Posted by tampa07gt
Next week Willy's going to wire his electronic throttle to the fan relay and run it off his on board LAN to NASA to ensure he runs at the correct temp based on real time global atmospheric conditions. Oh yea after he makes his own installation tools
I know what it is. Nothing is hitting. It's just how the pypes systems sound. Is it mid muffler or rear, because it is worse with the rear mufflers system, I had the same problem with an offroad x and stock mufflers, and with the pypes system. The only way i got rid of it was putting the factory cats back on.
I have the pypes O/R X-pipe and pypes MM system, i have no ideal what you mean by "It's just how the pypes systems sound", mine do not rattle or sound like rattling in any way. They did when i first installed them,but soon as i found the rattle and fixed it ,the rattle went away. If properly installed, there should be no rattling noise at all,its just metal pipes, no moving parts, nothing to rattle unless it is making contact with something.
__________________
2007 GT
5 Speed
not the way the exhaust sounds. its an install issue. check your hangers and the hangers should not be tight into the bushings, there should be some slack. there should also be about an inch of clearance everywere. I tried and tried and tried to install the mid muffs myself but had to get my uncle to bend the pipes and hangers to make it right. the fitment is crap.
go back to your shop and tell them to fix it
__________________
07 GT Rag Premium, Black on Black
GT 500 Front End, Rear Spoiler Delete,
FRPP Hood Pins, Functional Hood Scoop,
PIAA 510 4300k Fogs, 4300k HID DRL Delete,
Steeda 90mm Intake and Tube, Steeda UDP,
BMR Combo LCA, UMI Poly UCA, BMR FSB Delete,
SCT Xcal 3, FRPP CMDP, Innovate Wide 02
PRO 5.0 Shifter, Custom T and Handle
Pypes Mid Muffs, FRPP X pipe
FRPP 4.10s and True Track
13.2 @ 109 at 2400ft above sea level
12.8 @ 111 DA corrected
I have the Pypes cat free X pipes and Pypes polished mufflers. My car is loud but I have never heard any noise like you have described. After about 50 or 60the systen is fairly quite as you kind of get ahead of the sound and still I have heard nothing at all out of the ordinary. I am thus far pleased with the way my car sounds.
__________________ Never do today what you can put off until tomorrow. www.michellesfords.com
