If the throttle pedal seems sluggish, do the "turn the key on, do not start it, depress pedal slowly to the floor, let it back off slowly...turn the key off...then start and drive...." trick.....
It works on mine....
Ok, I know I am posting in the wrong section. I did a search about my car doing the same thing (losing power in that rpm range.) I cleaned my TB and cleaned and re-oiled my K&N filter, changed my spark plugs, and oil change.
Will this pedal trick do the same thing for my 2v as it does to your 3v?
Thanks,
Phil
__________________
2001 Mustang GT Conv 4R70W
K&N drop in
FRPP 3.73s
Speed HIDs 8000K
Mach 1 Grill delete
Super 44 cat-back
Vogtland Sport Springs
Mobil one package
Soon to come: cat X pipe and SCT X3 Tuner
Quote:
Originally Posted by JD1969
My god, you only count the forward gears when talking about how many gears a trans has. EVERY trans has a reverse.
