Go Back   MustangForums.com > Ford Mustang Tech > 2005 - 2011 Mustangs
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 03-15-2009, 11:38 PM   #11
kingsofcrunk
kingsofcrunk's Avatar
Vehicle: 2006 Mustang GT
Didn't crane cams just go out of business?
__________________
kingsofcrunk is offline   Reply With Quote
Old 03-16-2009, 12:08 AM   #12
str8wick3d
Send a message via AIM to str8wick3d Send a message via Yahoo to str8wick3d
Quote:
Originally Posted by kingsofcrunk View Post
http://www.brenspeed.com/05-08-musta...-camshaft.html
"Looking for that radical muscle car idle? Comp Cams has released the 3V modular engine line of rough idle camshafts. The best solution for a mildly modified Mustang is the Thumpr cam set by Comp Cams. Not only can some Mustangs pick up to 25 rwhp at high rpm but you will also get that very choppy muscle car sound and make more low end power than comparable choppy idle cams. This cam set was designed for a rough idle so if that is what you are looking for you will love these cams. This cam set is a NSR grind meaning you do not need to change the valve springs. Because of the Ford Variable Cam Timing these cams require the use of phaser limiters. You can add the phaser limiters at a discounted price using the drop down box above. Also click on the tab above to read about why phaser limiters are needed when choppy idle cams are used."
Gunna cost a lot of money if you want to get camed, but gl if you do.
In the video on their website they rev the car with the thumpr cams and the rpms still hang.. So I guess its not just the cam?
__________________
2004 V6 - Traded / 2002 GT - Totaled / 2005 GT - Current
Muffler Delete / 3.55s / 2007 GT Appearance Package
str8wick3d is offline   Reply With Quote
Old 03-16-2009, 12:09 AM   #13
07musclemustang
2007 Ford Mustang
07musclemustang's Avatar
Vehicle: 07 Mustang GT Rag Top
I WANT CRANE CAMS BUT CANT FIND ANTHING ABOUT THEM OTHER THEN THERE CRAP WEBSITE
HEY IS SOMEONE IN THERE AREA THAT CAN CALL
oPP
__________________
07 GT Rag Premium, Black on Black
GT 500 Front End, Rear Spoiler Delete,
FRPP Hood Pins, Functional Hood Scoop,
PIAA 510 4300k Fogs, 4300k HID DRL Delete,
Steeda 90mm Intake and Tube, Steeda UDP,
BMR Combo LCA, UMI Poly UCA, BMR FSB Delete,
SCT Xcal 3, FRPP CMDP, Innovate Wide 02
PRO 5.0 Shifter, Custom T and Handle
Pypes Mid Muffs, FRPP X pipe
FRPP 4.10s and True Track
13.2 @ 109 at 2400ft above sea level
12.8 @ 111 DA corrected
07musclemustang is offline   Reply With Quote
Old 03-16-2009, 12:10 AM   #14
07musclemustang
2007 Ford Mustang
ha caps lock sucks
ok yeah is someone local who can call and get the skinny
im up in canada and will call if no one else does.. bloody long distance, why dont they have toll free
__________________
Old 03-16-2009, 04:18 AM   #15
mygt500
Multi-Tasking Moderator!
mygt500's Avatar
Vehicle: 2006 Ford Mustang GT
CAMs and LT with no CATS and x pipe
__________________
2006 Mustang GT with Cervinis Kit
Whipple Crew member
H.O. S/C 465 RWHP and 440RWTQ
First online article about my car! check it out!
http://www.examiner.com/examiner/x-8811-Detroit-Sports-Car-Examiner~y2009m5d30-Jason-McGuires-2006-Mustang-GT
http://www.cardomain.com/ride/3342086
www.mocsem.com
mygt500 is offline   Reply With Quote
Old 03-16-2009, 10:34 AM   #16
acmike
Yes, Crane cams is out of business,,, COMP cams is alive and well.
__________________
'08 GT Alloy w/ Black/Chamois 5speed Coupe
IUP, PTP, AAT, HID, Comfort group.
MODS: Tokico D-specs, Tokico springs, MGW shifter, 35%/20% tint, more soon...
acmike is offline   Reply With Quote
05, 0508, base, cams, camshaft, camshafts, choppy, idle, limiters, muscle, mustang, mustangs, oldschool, phaser, sound, sounds, totaled, youtubecom
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
