Go Back   MustangForums.com > Ford Mustang Tech > 2005 - 2011 Mustangs
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 03-17-2009, 01:59 AM   #1
miloman
miloman's Avatar
Vehicle: 2005 GT
Default Stereo and stupid dimming lights.
Ok, so I finally had the time this weekend to do the "big 3 upgrade"..........positive battery to alternator, negative battery to chassis, and engine to chassis. I used 4 AWG though, thick as I could find in town on a Sunday, I did find some 1 AWG, but the guy only had 4 feet. I left the stock cables in tact as well. Either way, didn't work...........I'm still getting headlight dimming when the bass hits at higher volumes.
For those who don't remember, I recently put a Pioneer DEH-P5000UB stereo in the car. The rest of the system is still the Shaker 1000.
What's next? High output alternator? Optima battery? Capacitor?
I priced a 130 Amp alternator from Napa today for about $157..........which seems cheap, I was expecting a ton more. The stock alternator is 110 Amp I believe.
Would this 130 amp alternator be sufficient enough?
What about the physical size of the alternator? Will it fit snugly into the same already tight spot the stocker rest in? Will the stock belt be reused or will the bigger alternator affect the length of the belt?
Do I even need the alternator? Or would a Optima Red top cure the problem? I don't think a capacitor is really necessary
I'm confused. I do know that I don't like watching my lights flicker when some insanely fast double bass is playing, I'm sure the people in front of me are thinking the same.
Thanks,
Mike
__________________
Quote:
Originally Posted by ImpOnFire View Post
i always swallow
miloman is offline   Reply With Quote
Old 03-17-2009, 03:58 AM   #2
mygt500
Multi-Tasking Moderator!
mygt500's Avatar
Vehicle: 2006 Ford Mustang GT
The capacitor is necessary IMO and cheaper then an alternator. Get a new battery too (optima-red or yellow I cant remember) and that should solve the problem. Have comfort in knowing you have excellent grounds though! You have alot of AMP draw and if you do buy an alternator (last case scenerio IMO) get a 200 amp one and be done with it!!!!! forget 20 extra amps get 90 extra amps....JMO
__________________
2006 Mustang GT with Cervinis Kit
Whipple Crew member
H.O. S/C 465 RWHP and 440RWTQ
First online article about my car! check it out!
http://www.examiner.com/examiner/x-8811-Detroit-Sports-Car-Examiner~y2009m5d30-Jason-McGuires-2006-Mustang-GT
http://www.cardomain.com/ride/3342086
www.mocsem.com
mygt500 is offline   Reply With Quote
Old 03-17-2009, 08:00 PM   #3
miloman
miloman's Avatar
Vehicle: 2005 GT
Bumpity bump bump!
Anyone else?
__________________
i always swallow
Old 03-17-2009, 08:25 PM   #4
charliebrown266
charliebrown266's Avatar
you need a cap! I had this problem on my 96 GT. It would draw over 55amps at peak bass,lights would dim,volt gauge would move with the beat,put a cap in,problem gone.
__________________
08' GT ALLOY, MGW, Roush Suspension, roush body kit, Magnaflow Magnapack Cat back, Mtx Sub Encloser.C&L racer,93 brenspeed tune,20" TSW wheels,AVIC-D3
charliebrown266 is offline   Reply With Quote
Old 03-17-2009, 09:54 PM   #5
07musclemustang
2007 Ford Mustang
07musclemustang's Avatar
Vehicle: 07 Mustang GT Rag Top
i would get a good cap as it will store the peak energy you need for the bass hits to keep the lights from dimming.
if your getting dimming its from too much draw on the system with the amps.
if the caps are installed in line to the amps power supply the amps will draw power from the cap to hit the note at the amplitude desired without drawing from the rest of the system
if that fails get an optima battery as our oem is crap,
if the battery is good dont fix it untill its broke though
as for the alternator, i would do that last but it shouldnt be necisary untill you run more then the shaker 1k's output
cap first, 1 farad shoul do
batt second
alternator last
__________________
07 GT Rag Premium, Black on Black
GT 500 Front End, Rear Spoiler Delete,
FRPP Hood Pins, Functional Hood Scoop,
PIAA 510 4300k Fogs, 4300k HID DRL Delete,
Steeda 90mm Intake and Tube, Steeda UDP,
BMR Combo LCA, UMI Poly UCA, BMR FSB Delete,
SCT Xcal 3, FRPP CMDP, Innovate Wide 02
PRO 5.0 Shifter, Custom T and Handle
Pypes Mid Muffs, FRPP X pipe
FRPP 4.10s and True Track
13.2 @ 109 at 2400ft above sea level
12.8 @ 111 DA corrected
07musclemustang is offline   Reply With Quote
Old 03-17-2009, 10:54 PM   #6
miloman
miloman's Avatar
Vehicle: 2005 GT
I guess I need to look into getting a capacitor!
__________________
i always swallow
Old 03-17-2009, 10:56 PM   #7
07musclemustang
2007 Ford Mustang
yup i would look into a 1 farad, any more is reallt overkill, wspecially in your situation
__________________
Old 03-18-2009, 12:40 AM   #8
Shadow7874
2007 Ford Mustang
Vehicle: 2007 Ford Mustang GT
I would order some 1/0 gauge wire, then a cap/second batter/alt.
Pretty much in that order till your problem is solved.
__________________
07 Redfire GT Manual
DIY Shorty antenna, SHR Honeycomb Blackout Panel, wheelskins Louvers, GT/CS Rear Bumper, window tint, tinted turn signals
Awaiting install: BBK Chrome Shorties
Next in line: boomtubes?
Shadow7874 is offline   Reply With Quote
Old 03-18-2009, 12:50 AM   #9
robsimp
Vehicle: 2K7 Ford Mustang GT
caps are bad for your alternator.. just get a yellow top optima, 200amp alternator and upgrade your BIG 3 to 1awg and be done with it..
__________________
*Satin Silver
*jlt intake*91 bamachips tune*mac LTs*catted prochamber
*gta's*udp*cmcv deletes*4.10 gears*tokico dspecs*eibach pro-kit
*gt500 spoiler
waiting to install
-cdc classic chin spoiler
robsimp is offline   Reply With Quote
Old 03-18-2009, 01:04 AM   #10
doode
Vehicle: 2005 Mustang GT
caps are a bandaid fix
instantly discharge, and then the alternator has to charge it back up
__________________
Weekend car = 2005 Mustang GT
Daily Beater = 1992 Nissan Pathfinder
doode is offline   Reply With Quote
0506, 200amp, 46l, alternator, ford, high, mustang, output
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
