Go Back   MustangForums.com > Ford Mustang Tech > 2005 - 2011 Mustangs
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 03-24-2009, 10:10 PM   #11
owero01
owero01's Avatar
Vehicle: 06 Mustang GT
Send a message via AIM to owero01
Justin is one heck of a tuner and a fantastic driver. A lot to the NHRA winners are JPC tuned Mustangs. JPC has done all of my mods and I have one beast of a Mustang. Oh by the way, Justin weighs less than 190.
__________________
Pro 5.0 STS, C&L CAI with D/S and JPC 93 Performance Tune, Steeda UDPs, Metco LCAs, Spohn adjustable UCA, FRPP 4:10, JPC Aluminum D/S, Eibach Pro Kit, Tokico D Specs, P/h bar, Chr VCs, FM 40s, BO Strut Brace, Seq. TLs, SLP LTs, SLP XPipe/high flow cats, Comp Cams Thumprs, JPC Chrome fuel rails, MSD COPs, Prothane Motor Mounts, BBK Chrome Plenum Cover, Boss 304 chrome wheels, BF Goodrich KDWs, 361rwhp
http://www.youtube.com/watch?v=1S7GfbipgsY
owero01 is offline   Reply With Quote
Old 03-24-2009, 10:22 PM   #12
modaddict
modaddict's Avatar
Dude, just different tracks and drivers - we are talking up to 1/2 second differences - (yes I said 1/2 second)
The ice cold in the shade makes a difference as well. The vast majority of stock'ish GT's I have seen at the tracks will run up to .3 quicker ice cold versus normal operating temp. I have put this to the test myself at just my last event in a rental car.
You can't worry about what someone else does at a different track. Now if you see someone with similar mods at the same track as you running considerably faster, then you need to evaluate your driving skills or his claims of having the same mods...
__________________
05 Sonic Blue Roush GT - 9.67 @ 141 Daily Driver!
On the cover and featured in the Dec. 09 MM&FF - Check it out!!
Click HERE for My UpCrowd Car Page
modaddict is offline   Reply With Quote
Old 03-24-2009, 10:55 PM   #13
gburke1
I don't think it could have anything to do with driver except a very slight difference due to his weight. I had a better 60', both cars are Automatic... so all there is to do after the launch is keep the pedal to the floor, which I can assure you I do :P
I've done the ice on the manifold thing, and come close to my 13.082 but not quite due to the warmer spring air vs fall air. The 13.082 was after letting the car cool down for a very long time (temp gauge was all the way down).
Due to air and less weight he should have about a .165 advantage, but assume a CAI/Tune gives you 20 RWHP and we both start at 240 RWHP. Full Exhaust in theory should add another 25 RWHP.
So...
His 260 RWHP (with a .165 advantage, roughly equivalent to 16.5 RWHP)
vs
My 285 RWHP
So the difference in my favor should be about 10 RWHP or a tenth... The difference may not be as much as I thought considering:
*I can only get 91 octane, they ran 93 octane
*They iced the intake, probably in weather that was already chilly
*I have the heavy Shaker 1000
I still think I should be able to run at least what he ran maybe a tenth or two better all factors considered. Guess it's time to get the tune checked...
__________________
13.082 @ 105.05 MPH w/ 1.969 60' on Stock P-Zero 17s
'06 Performance White Auto GT, Kooks LT Headers, Kooks Catted X-Pipe, Pypes Mid Muffler System, C&L Racer CAI, Supertune Performance Dyno Tune, Stock P-Zero 17" Tires
gburke1 is offline   Reply With Quote
Old 03-24-2009, 11:13 PM   #14
mygt500
Multi-Tasking Moderator!
mygt500's Avatar
Vehicle: 2006 Ford Mustang GT
I agree not all things are created equal!
__________________
2006 Mustang GT with Cervinis Kit
Whipple Crew member
H.O. S/C 465 RWHP and 440RWTQ
First online article about my car! check it out!
http://www.examiner.com/examiner/x-8811-Detroit-Sports-Car-Examiner~y2009m5d30-Jason-McGuires-2006-Mustang-GT
http://www.cardomain.com/ride/3342086
www.mocsem.com
mygt500 is offline   Reply With Quote
Old 03-24-2009, 11:16 PM   #15
modaddict
modaddict's Avatar
Dude, you are going about this all wrong...
Mistake #1 - thinking mods are a 'shopping list', i.e. counting up each individual HP claims and then adding them together. It simply doesn't work that way. if X mod gives you 10 hp and Y mod gives you 10 hp, and Z mod gives you 10 hp - it does not mean that XYZ mods give you 30 hp - that is a myth.
Mistake #2 - Not factoring tuning. Not to say Justin is a 'better' tuner than your tuner (although Justin is damn good) but you do not have a clue of the parameters of their tune. For example, TIMING is a HUGE difference and higher octane (yes even just 93) gives you a definitive advantage to run more timing. The easiest way to add HP to these cars is to increase timing. I know Justin and I also know at the tracks when he is going for a number, he will really ramp up the timing to the point of leaning the car out to get a number so that by itself could mean a considerable difference if you were lined up next to the guy.
Mistake #3 - underestimating the track. Where did you run? JPC is ground zero to some of the fastest tracks in the country. Those tracks out there are damn good. Every single FFW participant that comes out to Fontana for the November event (including JDM and others) - they all run .3 slower here at the west coast tracks than they do back home. Track conditions are a big factor regardless of the 60'. The 60' only signifies if the track is hooking up at the starting line, not how fast you are going to run overall. Granted, it usually translates, but it's not the whole enchilada.
Based on everything you said, I'd bet money the difference between your car and his is #1 - more aggressive timing and spark advance in his tune and #2 - weight.
__________________
Old 03-25-2009, 12:00 AM   #16
gburke1
I think I was conservative with how much HP the mods add, I remember the claimed gains being higher than my estimates.
I figured the tune was probably to the ragged edge... maybe I'll see what my tuner can do with 92 Octane. (92 is the best you can find here, only 1 station has it..)
I run at KCIR. You can see a partial (full if you're already a member on 1320go) time slip of my run at:
www.1320go.com/kansascity/getDates.php , then select 11-23-08, title not specified, and enter car 685 in the search. This shows the exact conditions at the time as well.
I am not sure how the track prep compares here at KCIR.
I am also experimenting with data logging and trying to learn enough so that I will be able to use the Pro Racer software to tune my own car.
__________________
Old 03-25-2009, 07:56 AM   #17
1morepart
1morepart's Avatar
Vehicle: 2008 S197GT
interesting read.....i thought g would have won with his mod list...
1morepart is offline   Reply With Quote
Old 03-25-2009, 09:07 AM   #18
grampa_stang
grampa_stang's Avatar
Vehicle: 2007 GT Coupe
According to my NHRA correction factor spreadsheet. The diffrence is about 0.19 for every 1000'.
__________________
'07 GT - AT / IUP / Charcoal int / Carbon fiber dash
JLT / SCT Xcal 2 / Bama 91 Race / Eibach Pro / 3.73's
Tint / Shorty / Sequentials / Cervinis side louvers
BFG G-Force SS A/S P255/45-18 / ADR Wheels
BoomTube Crew Member
13.66 @ 100 (DA 4300')
grampa_stang is offline   Reply With Quote
Old 03-25-2009, 09:11 AM   #19
VistaGT
VistaGT's Avatar
Vehicle: 06 GT
The CAI/Tune combo Brenspeed listed as running 12s was the C&L Street. I remember b/c that's what made me buy it lol. THe difference is they ran that with a stick car and M/T Streets.
BTW guys Justin is really small, we're talking 130-140lbs. I also agree he can tune with the best. As far as driving at the track---there may not be as much driver control with auto vs. stick but w/e tricks there are i bet Justin has them down pat!
__________________
06 Vista Blue GT 5-Speed
C&L CAI, Steeda Strut Tower Brace, UDPs, LCAs, Flowmaster American Thunder
Welded Pypes O/R H, FRPP 4.10s, Hurst Shifter, SCT w/ BRENSPEED Tune
Shorty Ant, Ford Splash Guards, Staggered Black FR500s w/ Nitto 555s
311rwhp 318rwtq on the dynojet---NEXT: Thumpr cams or blower (idk yet)
VistaGT is offline   Reply With Quote
Old 03-25-2009, 09:26 AM   #20
deekum1627
deekum1627's Avatar
Vehicle: 2008 Mustang GT
Send a message via AIM to deekum1627
every car is goin to be diff man, also i like that cai more and more i should of got that one instead of my racer
__________________
looks- roush spoiler/cdc aggressive chin/blackout panel/shorty ant/3d carbon grille/sequentail tail lights,steeda strut bar,
performance- full mac exhaust/ mgw shifter/che k-member w/tq limiters/ C&L racer and x3 brenspeed tune/ frpp 4:10s
waiting to go on:eibach pro springs, koni STR.T shocks and struts
YANKEES WORLD CHAMPS #27
deekum1627 is offline   Reply With Quote
bullitt, cai, dyno, headers, longtube, mustang, pypes, results, s197
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
