Go Back   MustangForums.com > Ford Mustang Tech > 2005 - 2011 Mustangs
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 04-15-2009, 02:16 PM   #1
Doogie65
2007 Ford Mustang
Vehicle: 07 GT Alloy vert
Default Shaker 500 CD Error Problem
Man, these shakers just suck! My battery went dead due to my own fault (left the key on after putting the top up.. don't ask) and the next day I noticed a CD Error flashing on shaker display that popped up when I opened the door. I already had the trickle charger on it, so I let it sit over night... but the problem is still present. The car starts and runs fine as well.
Even without the key on or in the ignition, the 6 CD "circles" pop up on the screen as soon as the door is opened, followed by a "CD Error" message. Also when the CD button or the load button is pressed when the shaker is turned on, it momentarily displays "initializing", then diverts back to radio mode. It does appear to something with the CD functionality the more I think about it. The battery is reading 12.6v, but I put the big charger on it to see if maybe a deeper charge will help.
Does this sound like a discharged battery issue that just has low current output or has my shaker taken a dump?? I am still under warranty, but really don't want to take it in unless absolutely necessary. But if this does not go away after a lengthy charge, I will have no choice.
__________________
Mods: Edelbrock Supercharger 422RWHP/394RWTQ, CDC convertible bar & Classic Chin, Roush rear springs, GTAs, Steeda Billet LCAs & adj. panhard, CHE anti-squat, Pro5.0 shifter with Hurst stick/knob, RotorPro Rotors, Agent 47 mirrors, Dual Aeroforce gauges, CS69 wheels
Foose hood awaiting paint
Doogie65 is offline   Reply With Quote
Old 04-15-2009, 02:28 PM   #2
Smooth_J
Vehicle: 2008 Ford Mustang GT Prem
Send a message via AIM to Smooth_J
"CD Error" was an issue way back when during the Mach 460 days and they were known for it. Warranty should cover it, but I haven't hear a lot of issues about these new ones.
Do you have all 6 CDs loaded?
__________________
2008 White Mustang GT - 6 Spd - 434 RWHP/417 RWTQ
Go:
EB E-Force, Roush Stage 2 Suspension, Corsa Xtreme Exhaust, Prochamber, GT500 Brakes, BMR Adj Panhard and UCA/LCA w/relo, Hawk HPS Brakes, Alum DS, and TR-6060
Show:
Scott Drake Hood Pins, FRPP Black on Black Steering Wheel, Black GT4 Rims w/ NT555, 14" shorty antenna, OE GT500 Spoiler, CDC Chin Spoiler, and Factory "Bug Deflector"
For Sale:
http://mustangforums.com/forum/s197-...-parts-fs.html
Smooth_J is offline   Reply With Quote
Old 04-15-2009, 02:32 PM   #3
Doogie65
2007 Ford Mustang
As far as I know, there are no CDs loaded.
__________________
Old 04-15-2009, 02:32 PM   #4
wilkinda
2010 Section Moderator
wilkinda's Avatar
Vehicle: 2010, Ford Mustang GT Premium
Send a message via AIM to wilkinda
My Shaker1000 did the same thing. After having (3) head-units replaced... I replaced it with a pioneer Avic-D3. I did receiove another head-unit from Ford that is in a box..brand new..from Ford.
__________________
USAF (Retired) / Gas Turbine Controls Systems Engineer (Current)
Current: 2010 Ford Mustang GT Premium, Grabber Blue, (401A) Premier Interior Char /w Grabber Blue Stripe, 5-Speed, 3.73 rear, Electronic Pkg (Nav), 19" Painted Nickel Luster Wheels, Comfort Pkg, Security Pkg...
Current Mods: FRPP lowering springs, Roush O/R Exhaust, tinted windows, 3M Clear Bra, Headlight / Fog Tint
Delivered: July 27th, 2009
MyCarDomain Page
wilkinda is offline   Reply With Quote
Old 04-15-2009, 02:41 PM   #5
CutterWolf
CutterWolf's Avatar
Try disconnecting your battery for a few mins and then hook it back up and see if that clears the error for you.
__________________
My CarDomain page: http://www.cardomain.com/ride/3382054
CutterWolf is offline   Reply With Quote
Old 04-15-2009, 02:45 PM   #6
Smooth_J
When I had my Mach 460 HU I tried virtually everything. So then I just said heck with it and took it all apart. Once I took all the CDs out I put it back together and it was fine till I traded the car in.
__________________
Go:
Show:
For Sale:
Old 04-15-2009, 02:52 PM   #7
Doogie65
2007 Ford Mustang
Quote:
That was the first thing I tried... but given how it failed after a battery drain, I would assume it is somehow "hung up" and needs to get cleared.
__________________
Old 04-15-2009, 03:02 PM   #8
CutterWolf
CutterWolf's Avatar
Have you tried unpluging the radio its self yet?
__________________
Old 04-15-2009, 03:05 PM   #9
Doogie65
2007 Ford Mustang
Is there an easy way to do that without pulling the dash apart?? Or could I maybe just pull a fuse?
__________________
Old 04-15-2009, 03:18 PM   #10
CutterWolf
CutterWolf's Avatar
You would be suprised how easy it is to pull apart. The two side kick panels on either side of the radio area just pull off and once you pull those off you will see the screws that need to come out. Once those are out the whole face around the radio just pulls out and you will see the plugs to your air and other controls, just unplug them and that whole part will come away leave you just your radio and the 4 screws that hold it in. Take off those screws and pull the radio out and you will see your plugs to it. You will only need to unplug the biggest one. The small plug is for your subs and the other thick wire is your anntena.
__________________
1000, 500, battery, cd, drain, error, face, ford, initializing, load, mach, mustang, problem, problems, shaker
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
