Go Back   MustangForums.com > Ford Mustang Tech > 2005 - 2011 Mustangs
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 05-06-2009, 08:49 AM   #21
CutterWolf
CutterWolf's Avatar
Quote:
Originally Posted by zombiehouse View Post
I just did this swap last weekend. I also purchased my front GT bumper from Newtakeoff. Mine did not have a bulge underneath like yours does. Before I did the swap I went to Ford and purchased a new GT engine splash shield, GT front fender liners and upper support foam for a GT. While I was doing the swap I compared the V6 fender liners to the GT liners and the V6 liners were smaller. If you are reusing the V6 liners then the sides of the GT bumper will be forced inward and cause that bump you experienced.
When I installed the bumper, I first installed the fender liners. Then I installed the engine splash shield. There are 4 screws that attach the engine splash shield to the GT fascia. There are 2 screws that attach the engine shield to the radiator crossmember.
I hope this helps.
I was also thinking along these lines too. He mite have a combo of all of the above going on which would create that bulge. raubt, take off the splash sheild, and remove the screws to your fender liners and see if that gets the bulge out. If so then you know what parts you need to buy.
__________________
My CarDomain page: http://www.cardomain.com/ride/3382054
CutterWolf is offline   Reply With Quote
Old 05-06-2009, 11:19 PM   #22
nitecrawler27
Vehicle: 2006 ford mustang v6
I hope this helps.
did you get a radiator shield or an engine shield? ive read in other post that whats needed is the gt fender liners and the radiator splash shield. I just want to make sure i purchase the correct parts since ill be doing this switch during the weekend. Also what did it cost you for the parts?
nitecrawler27 is offline   Reply With Quote
Old 05-06-2009, 11:24 PM   #23
BigGameHunter589
2006 Ford Mustang
Vehicle: 06 Pony
it appears as if your gt bumper as grown a pair of boobs
__________________
Evolution Performance Tuned, Xpipe w/ magnaflows
C&L CAI, Front/Rear Sways, Strut Tower Bar,
GT sideskirts, OEM Hood Scoop, Isimple Adapter.
BigGameHunter589 is offline   Reply With Quote
Old 05-07-2009, 01:40 AM   #24
zombiehouse
Vehicle: 2005 Mustang Convertible
Here are all of the part numbers for the parts I purchased for the swap from Ford.
1. 5R3Z*17626*BA - DEFLECTOR (This is the shield that goes from the bottom of the front bumper to under the radiator)
2. 5R3Z*16102*BA - GUARD (Fender liner)
3. 5R3Z*16103*BA - GUARD (Fender liner)
I actually pulled all of the part numbers from a thread listed in the 4.0 Tech FAQ. That was an extremely helpful write up by SPARTAN VI.
The part numbers for the screws and inserts to attach the lower splash shield can be found there too.
zombiehouse is offline   Reply With Quote
Old 05-07-2009, 03:20 AM   #25
mygt500
Multi-Tasking Moderator!
mygt500's Avatar
Vehicle: 2006 Ford Mustang GT
OP I merged the 2 threads and changed the title...hope everything gets worked out on the front bumper cover!
__________________
2006 Mustang GT with Cervinis Kit
Whipple Crew member
H.O. S/C 465 RWHP and 440RWTQ
First online article about my car! check it out!
http://www.examiner.com/examiner/x-8811-Detroit-Sports-Car-Examiner~y2009m5d30-Jason-McGuires-2006-Mustang-GT
http://www.cardomain.com/ride/3342086
www.mocsem.com
mygt500 is offline   Reply With Quote
05, 2005, bumber, bumper, change, cover, detailed, directions, front, gt, liner, mustang, shield, splash, swap
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
