My car is pretty much a stock 06 auto GT except for a CAI and tune. The last time I was at the track I ran a 9.06 in the 1/8th with a 2.2 60ft with other runs in the 9.1s around 80mph. I felt that I had a lot of wheel spin so I bought some Nitto 275/40 DRs mounted on stock 17 wheels. Now I'm running a consistent 9.3 with a 2.4 60ft still at 80mph. What gives? I'm heating up my tires and ran about 29psi but I feel like I'm spinning just as much as with the stockers. I've tried launching just about everywhere between 2000 to 3000 RPM. Anything below and it bogs on take off and then starts spinning. Launching above 2000 leaves me spinning off the line and then it bogs and takes off. When the car shifts to second it always chrips the tires and sometimes gets a little sideways. Spectators tell me I am also chirping third. Do I need to do some suspension upgrades or look at more power to make up for lost time in spinning? What mods are recommended. I'm on a $300 or less budget.
This ad is not displayed to registered or logged-in members. Register your free account today and become a member on Mustang Forums!
__________________
06 Auto GT
CAI and Tune
Pypes MM
There are better choices for drag radials. M&H race-masters 275/50/17 will fit the stock 17x8 rims. I have been told that these really hook. What CAI/Tune are you running? For $300 or less, you could buy some lower control arms (lca). These will reduce wheel hop.
That's way too much tire pressure, I run my M&H DR's at 16psi. With the nitto's don't do a big show stopping burnout just spin them enough to clean them off. The Nitto DR's are better for the street than the track. Invest in some M&H DR's and LCA's.
I see you guys prefer M&H over Nitto. I can invest in some M&Hs as I got a really good deal on the Nittos used. What version of the M&Hs to you suggest? I will only run them on my car from my house to the strip and then back home so I don't need anything that will hold up to a lot of street use, but I'd rather not have to change tires at the strip (yet, maybe when I get more serious about racing). Should I look at 275/50/R17s like gman suggested or stick with 275/40/R17s like I have now?
__________________
06 Auto GT
CAI and Tune
Pypes MM
Should I also get LCA brackets? I read they were only needed if I lower my car and I don't ever plan on lowering it. Also can I remove the weights that are mounted on the axles without effecting anything? I don't know what they are called but I can post pictures if you guys don't know what I'm talking about.
__________________
06 Auto GT
CAI and Tune
Pypes MM
get an adjustable lower control arm and tubular lower control arms and you should be able to hook a hell of alot better... with the mods listed in my sig, I ran an 8.332 at 87.8 mph on my 295/25/20 tires that slid all over the place.
__________________
JLT,CMCV Delete, MAC L/T, X-Pipe & Dumped M80s, 3.73s, CHE LCA, Steeda Adj. UCA, Steeda Adj. Panhard Bar, Steeda Camber Kit, TCI 3000 TC
331/336... 8.291@82.4mph in the 1/8th
Built by Ronnie Sanchez of MMP... Tuned by Chris Jones of BBR... What a great team!
