Go Back   MustangForums.com > Ford Mustang Tech > 2005 - 2011 Mustangs
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 06-05-2009, 09:40 PM   #1
whtcanbrwnd04u
whtcanbrwnd04u's Avatar
Vehicle: 2007 Mustang GT
Default Did my retro solutions hids blow out?
My cousin drove my car to the gas station, parked it, probably 2 hours later, a co-worker told me that my lights were on, and i went out there, and sure enough they were on. I un-locked the car to turn them off, and the light switch was OFF. The lights were on for no reason? I tried starting the car, and it barely turned on. When the car was ON the lights turned OFF, and i actually turned the switch ON, and they worked. Let the car sit for a bit and then drove it around to juice up the battery a bit. Parked the car. 2 hours later, (time to go home) and my lights aren't turning on at all. My fogs work fine, but the headlights are out. I dont even hear the hid's whining noise. I don't have my owners manual with me, so i can't check if its maybe a fuse? Idk. Any help would be appreciated... thanks!
__________________
07 GT - 5 Spd.
Eibach Sportlines.
Ford Racing 4.10s.
JBA LT's + O/R H + FRPP Stingers.
Hurst Shifter.
BBK CAI + Brenspeed 93 Oct Tune.
CHE LCAs + Reloc Brackets.
CHE K-member brace / Tq Limiters.
13.2 @ 105 mph (W/ 3.31s & Stock Exhaust)
300rwhp / 318rwtq (Before LTs)
whtcanbrwnd04u is offline   Reply With Quote
Old 06-05-2009, 10:17 PM   #2
doode
Vehicle: 2005 Mustang GT
has it been raining lately?
sounds like an electrical issue with your SJB
__________________
Weekend car = 2005 Mustang GT
Daily Beater = 1992 Nissan Pathfinder
doode is offline   Reply With Quote
Old 06-05-2009, 10:57 PM   #3
whtcanbrwnd04u
It rained a couple nights ago... and my car was in-fact outside. Ahh!
__________________
07 GT - 5 Spd.
Eibach Sportlines.
Ford Racing 4.10s.
Hurst Shifter.
Old 06-05-2009, 11:14 PM   #4
denice25
Vehicle: ford
check the relay or fuse........
__________________
"thanE"[img]http://******************/images/85690f81aadc1749175c187784afc9ee.gif[/img]
denice25 is offline   Reply With Quote
Old 06-06-2009, 03:51 AM   #5
mygt500
Multi-Tasking Moderator!
mygt500's Avatar
Vehicle: 2006 Ford Mustang GT
I agree check the fuse that comes off the battery or SJB (depending on where you got your power) and see if the fuse went....bet it did....
I installed mine last week and when I powered them on and then turned them off they stayed on.... I went ahead and turned then back on then off and they turned off. Hasn't happened since and though the ballasts are water resistant....moisture can get into anywhere (including fuse blocks) and cause issues.
__________________
2006 Mustang GT with Cervinis Kit
Whipple Crew member
H.O. S/C 465 RWHP and 440RWTQ
First online article about my car! check it out!
http://www.examiner.com/examiner/x-8811-Detroit-Sports-Car-Examiner~y2009m5d30-Jason-McGuires-2006-Mustang-GT
http://www.cardomain.com/ride/3342086
www.mocsem.com
mygt500 is offline   Reply With Quote
Old 06-06-2009, 10:21 AM   #6
157db
Got Troy'd
157db's Avatar
Vehicle: 2007 Pony Package
Quote:
http://bradbarnett.net/mustangs/time...nersManual.pdf
The headlights work off of the SJB.
Go up front and bypass the SJB and manually provide
12V to the relay for the HIDs. If they come on, its either
your headlight switch (cheap piece of plastic junk) or
the SJB or associated wiring. The headlight switch is wired
for failsafe operation. The headlight request wire from the
headlight switch is grounded when the headlight should be
off and ungrounded when the headlights need to be on.
If the switch breaks or the wire to the SJB from the headlight
switch breaks, the headlights will illuminate but the auto power
down feature should turn them off after a while. Sounds like
you have the dreaded underdash water dispensor option we
didnt want. The SJB is all wet and corroded and the problems
will just keep getting worse until nothing electrical thats controlled
by the SJB will work. Passengers side carpet/pad wet? Any
signs of mold indicating that this has been an ongoing problem?
__________________
NON PUMKIN JACKER
Quote:
Originally Posted by Boozshey View Post
Oh yeah, I forgot Norm was God on here.
Give me a break!!!
Quote:
Originally Posted by Norm Peterson View Post
<rises to the bait>
. . . Definitely not God.
Norm
157db is offline   Reply With Quote
2000, 250, blow, f250, fuse, fused, hids, lights, located, mustang, oe, retro, retrosolutions, solution, solutions, time
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
