New Features: Ford Mustang Knowledge Base
Go Back   MustangForums.com > Ford Mustang Tech > 2005 - 2011 Mustangs
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 06-27-2009, 03:46 PM   #11
Stkjock
Street Strip Sheriff
2006 Ford Mustang
Stkjock's Avatar
Vehicle: 2006 Mustang GT
Quote:
Originally Posted by flounderlipps View Post
Dude, I didn't say it could not be done
I said it gets harder
I can do it also (BIG DEAL)
my point is its really not that hard if the car is set up right. I'm not a great driver, the car hooks and goes on a dump with no sidewall DRs.... so Stan just needs some seat time IMHO
__________________
Tngstn 06GT-5 spd -Vortech HO S/C-Tuned by Realspeed Auto
You can never have too much power, just not enough traction.
11.867 @ 119.35
Stkjock is offline   Reply With Quote
Old 06-27-2009, 04:25 PM   #12
STANMAN
Quote:
I doubt seat time is the issue, I am an old man (35) with plenty of seat time in fast stick cars. Hell, my SRT4 hit mid 11's, now THAT was a car that was a handful, lol. I want to try a different track, out local track just isn't the best it seems like. If I hit Joliet and still have these problems then I know I have real problems. Just trying to see if anyone sees something I am missing.
__________________
Saleen twin screw. Enough said!
STANMAN is offline   Reply With Quote
Old 06-27-2009, 05:27 PM   #13
JDWalton
Vehicle: 08 Mustang GT
well everyone did kinda just skip over all my questions about how your suspension is set up.
__________________
My cars pics, vids and mods
To Lazy to update pic again right now:
WeaponX COPs, BBK 62MM Throttle Body, Stephs Catch Can, Spec Stage 3 clutch, 4.10 Gears, 18X9 up front, 18X10 in the rear, Eagle F1 Supercars
In Route: CDC Classic Chin - C/S Style, 1/4 Louvers
JDWalton is offline   Reply With Quote
Old 06-27-2009, 05:34 PM   #14
PolkThug
If your car isn't on the factory springs anymore, you need LCA relocation brackets. Otherwise, you have made your traction worse by having the front of the LCA lower than the back.
FWIW, I dump the clutch every time from the launch. You'll having to vary your RPM's depending on track prep.
PolkThug is offline   Reply With Quote
Old 06-27-2009, 07:12 PM   #15
AmericanSpeed
2005 Ford Mustang
Try reversing your D-Spec setup. I usually go almost full soft in the front and about 4 turns from full soft in the rear. Those 4.10 gears and the positive displacement blower might make things a little more dicey, but I think you should try and come out the hole harder. Sometimes babying it out the hole leads to spin and shocking the tires with a hard launch can give more traction.
edit: your mph is def good for mid 11s
__________________
05 Redfire GT: WHIPPLE HO @ 10psi, VMP dyno tune & other goodies - stock block, stock exhaust, stock 3.55s
11.324 @ 121.84 w/ 1.627
http://www.youtube.com/watch?v=dlBxdF5IqFM
11.36 @ 122.72 w/ 1.663
http://www.youtube.com/watch?v=BoGf6DiMVk4
Previous runs:
CAI+tune only 12.877 @ 106.79 w/ 1.819
CAI+tune+suspension 12.783 @ 108.05 w/ 1.841
both on stock tires
Please do not link companies in your sig
AmericanSpeed is offline   Reply With Quote
Old 06-27-2009, 08:24 PM   #16
flounderlipps
Vehicle: 06 Mustang
I got 20 years on you Stanman
Hang in there man
__________________
mods to come: fuzzzy dice, strawberry air freshner, floor mats, compass, clover leaf key chain
flounderlipps is offline   Reply With Quote
Old 06-27-2009, 08:54 PM   #17
Gene K
Second the soften the fronts and firm up the rear. Try and get the instant center up. Thats more important than the pinion angle.
__________________
Gene
2007 GT-D M5 3.55 3700 lb (280 lb Driver)
CAI/Tune and Stock Pirellis
1.909 8.345@84.83 12.957@106.62
http://i253.photobucket.com/albums/h...nePirellis.jpg
Gene K is offline   Reply With Quote
Old 06-27-2009, 09:06 PM   #18
Riptide
Riptide's Avatar
Vehicle: 2006 GT
Wow GeneK. Seems like a million years since you've posted?
__________________
2006 GT, Manual
JLT2 w/93 Tune
FRPP 4.10, Steeda LCA
265whp/275wtq
Boomtube Crew Member
Riptide is offline   Reply With Quote
Old 06-27-2009, 09:24 PM   #19
JDWalton
Quote:
Hes got adjustments for both, so if max traction is what he is going for, it makes no sense to say one is better then the other. How about, oh I dont know, do both? Get everything dialed in the way it should be (thats why you bought all those adjustable components,) then tray again
__________________
Old 06-27-2009, 09:41 PM   #20
Stkjock
2006 Ford Mustang
Stkjock's Avatar
Quote:
Maybe so Stan, however it seems that your current set up is a bit new to you, so I'll stand by my statement that you need some seat time to get the set up dialed in.
Also you need to leave harder, with those tires and your power you should IMHO be able to dump it 4500 or so.
Again 55mph on the burnout for 4-5 seconds to get some real heat in the tires.
I'd agree with the comments above about the shock set up to help the weight transfer.
Again - the lowered stance will hurt your 60s no way around it.
__________________
11.867 @ 119.35
14, burning, clutch, insight, mach, mile, mustang, na, power, prep, quarter, saleen, smell, times, track
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
