My question is what codes will fail the car on the NYS inspection. I had a VMP tune in the car since this spring, when I took it in a week ago the computer spewed out that several sensors were "not ready". I had asked Justin for an inspection friendly tune, and I haven't contacted him yet as my internet has been knocked out at work. I loaded the stock tune back in but left my MAC cold air intake hooked up, and I am getting the "sys too lean" code. Will this fail the car? I don't really want to have to put the stock airbox back on but I will if I have to. I would think if the car is running too lean that less pollutants would be coming out of the pipe and NY would be happy, but I am wondering if anyone on this forum knows for sure what codes can be on and the car still pass inspection.
Does anyone here run an aftermarket tune that regularly passes NY inspection?
This ad is not displayed to registered or logged-in members. Register your free account today and become a member on Mustang Forums!
the rear O2s are likely off in your VMP tune... they need to be on, then do a driving cycle, common issue with a easy fix
__________________
Tngstn 06GT-5 spd -Vortech HO S/C-Tuned by Realspeed Auto
You can never have too much power, just not enough traction. 11.867 @ 119.35
Yes, the VMP tune has the rear O2 sensors off. That will give you 3 'Not Ready' readings and you'll fail (been there, done that). To use your stock tune, you'll likely need to reinstall your stock airbox, if you still have it. Then reload your stock tune or simply use your SCT or Diablo to 'Clear DTCs', then drive around a couple of days to get through enough driving cycles.
I have a tune from VMP and it has the rear O2 sensors on (and something else off), but 1 'not ready' will pass here, but not 2 or more. Keep trying to get ahold of Justin and get your tune fixed.
__________________
Mike - 2005 V6 Automatic, 300+ RWHP; 12.79 1/4
Vortech supercharger (SOLD); 180*T-stat; PLX Wideband O2, VEI digital gauges, SOS pillar pod; JBA 9MM wires; Mac LT headers, high flow cats; 8.8 w/3.73s, LPW girdle, alum driveshaft, 3000rpm TC; Steeda UCA, panhard bar, brace; CHE lca's & reloc brackets; Steeda Sport springs, Tokico DSpecs. .. "Sally" is getting "balls" ...forged V8 swap in progress
I had this problem last month, I left my C&L airtake on and put the stock tune in and check engine light came on, I had to put the stock airbox on, 5 minute job, keep stock tune on and drive it for a few days, put 10-20$ gas in a few different times, and put a total of 150 miles on and the sensors all finally reset and was able to pass inspection.
__________________
Full 3" Borla exhaust
Steeda underdrive pulleys
Diablo Pro Super Tune
C&L Cold Air Intake
MGW Shifter
