This was my solution, try at your own risk. To me it was simple practical, cheap and very easy.
I have proudly joined this community today to thank everyone that responded to this topic. Thank You guys, if it wasn't for all your insight, I would have wasted a few hundred that I can't afford.
My Car Trouble:
-My Check Engine Light was ON
-My RPMs would rise and fall speratically
-The ODB Code was P0506 (Idle RPM LOW)
-Delay In Vehicle Response to accelerator
-Car would turn off if stopped
-Car would P!SS off Owner
My Solution:
-Replaced Air Filter
-Cleaned Master Air Flow Sensor Connected to tube that goes to Air Filter, with Solution From Auto Zone (make sure its the right solution to clean te sensor). I removed the square casing from the circular tubing and removed the switch.
-Removed Throttle Bottle from air filter connector and intake manifold (very easy) and cleaned it with solution bought from autozone (make sure you get the solution to clean throttle bodies, I believe STP makes it)
-I turned on my headlights and removed the negative post from the battery for about an hour.
- I connected the throttle body and everything else back the way it was and turned onthe car
- My Check engine light turned off and the car was idle as it was when I bought it, SMOOTH.
-I took it for a ride around a few blocks and nothing. Then I took the larger streets and then the freeway. EUREKA!!!!
Tools Needed:
-Flat Head Screw Driver
-Plyers
-Ratchet with a 9mm and 10mm (I believe those are the right ones)
Work:
-Extemely Easy Enough for a 5th Grader to Do. (Not Recommended)
Cost:
-Air Filter $13
-Throttle Body Cleaner and Air Sensor Cleaner both for $12 (Please Note: They were from different manufacturers, I just chose those.)
Learning Experience:
PRICELESS!!!
