Go Back   MustangForums.com > Ford Mustang Tech > 2005 - 2011 Mustangs
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 08-19-2009, 12:49 PM   #11
vasman
vasman's Avatar
Vehicle: 2007, GT CS, Convertible
No mine came with that piece. It may have fallen off during the install. I will check. Thanks
__________________
2007 GT/CS Convertible
Techco 3L Twin Screw SC @10 PSI
Kooks LTs H-pype hiflow cats, Borla Stingers
4.10 FRRP Gears, Dynotech 3.5 Aluminium Drive shaft
Steeda Superlights, Tokico D Specs, BMR-UCA/LCA-Relo Braket- Adj.Panhard bar
CHE K Brace/torque limiters, Prothane MMs, Ford Racing STB
MGW shifter, Dual GT500 Fuel pump,
Nitto 555 245/45/18, 285/40/18 on 9&10" Omega GS Black Chrome
vasman is offline   Reply With Quote
Old 08-19-2009, 02:14 PM   #12
vasman
vasman's Avatar
Quote:
Originally Posted by bigray327 View Post
Here is my experience with that problem.
Something unrelated. How do you pass emmission in Houston with your setup. ned advise as mine is comming up in sept. have hi flow cats but I am afraid o2 sensors off.
__________________
Old 08-19-2009, 05:43 PM   #13
bigray327
bigray327's Avatar
Quote:
I put on a catted midpipe and load my tune that has the O2 sensors turned back on. Drive for a day, pass the test, get my sticker, switch bad to the offroad setup for another 364 days.
__________________
bigray327 is offline   Reply With Quote
Old 08-19-2009, 10:05 PM   #14
one eyed willy
2007 Ford Mustang
My Garage
one eyed willy's Avatar
Vehicle: 2007 GT
My setup looks pretty much like this pic from the how to's in this forum. red and black left hanging. The only difference is that the wires from the new harness to the modified connector are the LG and LB instead of Black and pink as they seem to be in this picture.
http://i172.photobucket.com/albums/w...all/d055-1.jpg
that fat hand looks very familiar. i had the same problem and it was the wires and th connector, triple check the connector and make sure the wires are the correct ones.
__________________
2007 GT
5 Speed
Forged and Turbocharged
Quote:
Originally Posted by tampa07gt View Post
Next week Willy's going to wire his electronic throttle to the fan relay and run it off his on board LAN to NASA to ensure he runs at the correct temp based on real time global atmospheric conditions. Oh yea after he makes his own installation tools
one eyed willy is offline   Reply With Quote
Old 08-19-2009, 10:33 PM   #15
vasman
vasman's Avatar
Talking Problem Solved!
You are right. The problem was on the modified connector. I had not removed the blue lock from the front so when I inserted the two wires (correct order but...) they never locked into position, thus there was no contact.... I disassembled and reassembled the connector correctly and presto. everything works...
Moral of the story... Never do electrical work that you are not familiar with in the dark.
__________________
Old 08-19-2009, 10:45 PM   #16
one eyed willy
2007 Ford Mustang
My Garage
Vehicle: 2007 GT
good to hear....where do i send the bill?
__________________
2007 GT
5 Speed
Old 08-19-2009, 10:45 PM   #17
hammeron
hammeron's Avatar
Vehicle: 2006 GT
glad to hear it's working vasman
hammeron is offline   Reply With Quote
05, 06, 2010, 500, data, dte, error, fli, ford, fuel, gt, gt500, issues, mustang, pump
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
