Go Back   MustangForums.com > Ford Mustang Tech > 2005 - 2011 Mustangs
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 08-18-2009, 11:11 PM   #1
vasman
vasman's Avatar
Vehicle: 2007, GT CS, Convertible
Exclamation Gt500 Pump installed- Fuel Gauge error -SOLVED
Hey guys,
Managed to put on the GT500 Fuel pump. Completed th install, the car runs fine, however about 10 secs after I start the car the fuel goes to empty and I get a low fuel error followed by DTE FLI DATA ERROR. I suspect I may have connected something backwards. Anyone?
*****Read up to the second page. Problem solved******
__________________
2007 GT/CS Convertible
Techco 3L Twin Screw SC @10 PSI
Kooks LTs H-pype hiflow cats, Borla Stingers
4.10 FRRP Gears, Dynotech 3.5 Aluminium Drive shaft
Steeda Superlights, Tokico D Specs, BMR-UCA/LCA-Relo Braket- Adj.Panhard bar
CHE K Brace/torque limiters, Prothane MMs, Ford Racing STB
MGW shifter, Dual GT500 Fuel pump,
Nitto 555 245/45/18, 285/40/18 on 9&10" Omega GS Black Chrome
vasman is offline   Reply With Quote
Old 08-19-2009, 09:33 AM   #2
hammeron
hammeron's Avatar
Vehicle: 2006 GT
yes this has happened to a few people,
it has something to do with the connector
you modify.
hammeron is online now   Reply With Quote
Old 08-19-2009, 10:00 AM   #3
157db
Got Troy'd
157db's Avatar
Vehicle: 2007 Pony Package
Its not hooked up properly.
Back to the drawing board.
Pics would be nice of the 'modified' connector...
__________________
NON PUMKIN JACKER
Quote:
Originally Posted by Boozshey View Post
Oh yeah, I forgot Norm was God on here.
Give me a break!!!
Quote:
Originally Posted by Norm Peterson View Post
<rises to the bait>
. . . Definitely not God.
Norm
157db is offline   Reply With Quote
Old 08-19-2009, 11:18 AM   #4
vasman
vasman's Avatar
OK pics reverting this after noon but basically:
Stock LB/Yl lines up with New harness LBYL
Stock LG/VT lines up with New harness LG/VT
Black and pink left on the old connector and hanging.
__________________
Old 08-19-2009, 11:44 AM   #5
SC1039
SC1039's Avatar
You shouldn't have any pins left behind on the old connector.
On the new 6-pin connector:
Black wire to Pin 1
Light Blue/Yellow to Pin 2
Pink/Black to Pin 4
Light Green/Purple to Pin 5
2 whites should have come already on the new 6-pin in pin 3 and 6. You have to keep them in place or remember where they went.
Hope that helps.
__________________
SC1039 is offline   Reply With Quote
Old 08-19-2009, 12:00 PM   #6
vasman
vasman's Avatar
My setup looks pretty much like this pic from the how to's in this forum. red and black left hanging. The only difference is that the wires from the new harness to the modified connector are the LG and LB instead of Black and pink as they seem to be in this picture.
http://i172.photobucket.com/albums/w...all/d055-1.jpg
__________________
Old 08-19-2009, 12:04 PM   #7
SC1039
SC1039's Avatar
I may have a different harness and connector then.
__________________
Old 08-19-2009, 12:06 PM   #8
SC1039
SC1039's Avatar
I may have a different harness and connector then. Did your setup come with a new fuse and relay block for the trunk?
__________________
Old 08-19-2009, 12:09 PM   #9
vasman
vasman's Avatar
Quote:
Yes it does.
__________________
Old 08-19-2009, 12:33 PM   #10
bigray327
bigray327's Avatar
Here is my experience with that problem.
__________________
bigray327 is offline   Reply With Quote
05, 06, 2010, 500, data, dte, error, fli, ford, fuel, gt, gt500, issues, mustang, pump
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
