Go Back   MustangForums.com > Ford Mustang Tech > 2005 - 2011 Mustangs
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 08-26-2009, 05:38 PM   #21
Mike02z
Mike02z's Avatar
Vehicle: 2008 Ford Mustang GT Convertible
Quote:
Originally Posted by cummins cowboy View Post
why not 10-40, you have light oil when its cold and heavier if you need it when its hot, best of both worlds
in response to another comment never heard of an engine failure running 10-40
That is not how it works. The second number is the viscosity when the engine is at operating temperature. Running a 40 weight oil in a car designed to use a 20 weight oil will most likely give you problems. Not right away but a true 40 weight oil is too thick for the 4.6 IMO.
Running M1 5W-30 is fine because lab tests show that the Mobil 5W-30 is closer to a 20 weight at temperature. I'm not an oil expert but I did read a lot over at bobistheoilguy.com
__________________
2008 Torch Red Mustang GT Convertible 5 Speed, (Borla Stingers, Saleen 475HP S/C Kit)
2008 Atomic Orange Corvette Coupe 6 speed, 422 RWHP/424 RWTQ (ARH LT's, Callaway CAI, 160 T-Stat, ECS dyno tune, VMAX Ported TB)
2009 Jetta TDI
1995 Dodge Dakota 4x4
Mike02z is offline   Reply With Quote
Old 08-26-2009, 05:47 PM   #22
Tylus
Tylus's Avatar
Vehicle: 2009 Bullitt #6451
you'll be okay.
I personally would drain and put the correct oil in there. Just leave the Filter. The 5w20 will dilute down the 5w30 sufficiently that the motor won't know a difference.
Better safe than sorry IMO...just run the spec'd stuff.
Quote:
Originally Posted by Riptide View Post
I've never read or heard of a single engine failure due to using a 20 viscosity oil.
x2
been using the 5w20 in my Fords for about 10 yrs now. From 100% stock motors to Supercharged 5.4 3v that I drove extremely hard.
never once had an issue or any noise. From Washington to Texas and now Hawaii.
Ford Engineers spec'd it for the CAFE requirements...yes. But the engines are also built with this oil in mind. A thicker oil isn't necessarily going to lubricate the same areas as well as the 20 wieght can/will.
They are the Engineers who have intimate knowledge of these motors...not us. I recommend you stick with the Experts. Heck, even Roush/Saleen say to use the 5w20 oil. I think they'd recommend a different viscosity if it was a problem.
__________________
2009 Bullitt
3.73 Gears | FRPP CAI & Tune | FRPP Strut Tower Brace | Hurst Short Throw
Blackout Panel | Billit 9mm Door Locks | UPR Fuel Door | Custom Shelby Hood Pins
Currently deployed...see y'all on the flip side
Tylus is offline   Reply With Quote
Old 08-26-2009, 05:51 PM   #23
Riptide
Riptide's Avatar
Vehicle: 2006 GT
Actually Saleen and Roush do recommend a 30 viscosity oil. At least for their supercharged applications.
Regardless, it doesn't matter much. A 30 viscosity shears down to a 20 pretty quick. From what I've read the 20 doesn't shear as much.
Ford isn't the only company to recommend a 20.
__________________
2006 GT, Manual
JLT2 w/91 Tune
FRPP 4.10, Steeda LCA
MAC Boomtubes
Goodyear 255/45/18, 285/40/18
Riptide is offline   Reply With Quote
Old 08-26-2009, 06:07 PM   #24
Tylus
Tylus's Avatar
where do you see that?
I had a RoushCharger and asked them specifically. I was told to run the 5w20 and nothing else by the Roush Tech department
__________________
2009 Bullitt
Old 08-26-2009, 06:26 PM   #25
Riptide
Riptide's Avatar
Vehicle: 2006 GT
I called one of the two (can't recall which) and was told a 30. I can't remember where but I think I found it on both websites. Was a while back when I looked though.
__________________
2006 GT, Manual
JLT2 w/91 Tune
MAC Boomtubes
Old 08-26-2009, 06:40 PM   #26
onederful100
onederful100's Avatar
Vehicle: 2007 GT 1992 LX 5.0
Saleen does recommend 5w30 on SC applications.
__________________
Whipple Crew Member
2-Stang Crew Member
my car
onederful100 is offline   Reply With Quote
Old 08-26-2009, 06:43 PM   #27
onederful100
gt500's take 5w50
__________________
Whipple Crew Member
2-Stang Crew Member
my car
Old 08-26-2009, 10:12 PM   #28
Nuke
2007 Ford Mustang
My Garage
Nuke's Avatar
Vehicle: 2007 GT
Send a message via AIM to Nuke Send a message via Yahoo to Nuke
Bottom line: 5W30 won't hurt, especially for one oil change, but if it bothers you, spend the few bucks and change it out.
__________________
Rick
07 GT Prem: Alloy, MT, 3.55's, Steeda CAI w/Brenspeed tunes, FRPP Stingers, 275/40/18 Goodyear Eagle F1 A/S on SVT Cobras (OE GT500's), 14" shorty, Wheelskin side scoops & qtr window louvers, A-H rear window louvers, SHR honeycomb blackout panel, Sequentials, Hella Optilux Extreme XY fogs, Silverstars
06 V6: Legend Lime, Pony Package, 14" shorty, Sequentials, Hella Optilux Extreme XY fogs, Silverstars
Nuke is online now   Reply With Quote
Old 08-26-2009, 10:55 PM   #29
PennState
2006 Ford Mustang
PennState's Avatar
Vehicle: 06 Mustang v6
Send a message via AIM to PennState
yeah you should be fine..
__________________
PennState is offline   Reply With Quote
20, 30, 50, 5w, 5w20, 5w30, car, gt, hurt, mustang, oil, put, run, takes, vehicle
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
