Go Back   MustangForums.com > Ford Mustang Tech > 2005 - 2011 Mustangs
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 09-01-2009, 03:32 PM   #1
Got_GT
Got_GT's Avatar
Vehicle: 2006 Mustang GT
Default Vent Gauge Pods
Do you have to drill a hole in the AC duct work in order to run the wires to a Gauge installed in the vent (with one of the Roush Vent Gauge Pods)?
I assume you do, but I thought that I would verify.
Thanks
__________________
Tungsten 06 GT
Vortech Supercharged
4.10s
Borla Stingers
XPipe
Got_GT is offline   Reply With Quote
Old 09-01-2009, 04:35 PM   #2
bigray327
bigray327's Avatar
No. The wire can snake between the vent pod and the sleeve it slides into.
__________________
bigray327 is offline   Reply With Quote
Old 09-01-2009, 05:21 PM   #3
Got_GT
Got_GT's Avatar
So what is the best route to take from the engine bay (vacuum line for the boost gauge) to the interior A/C vent?
__________________
Tungsten 06 GT
4.10s
Borla Stingers
XPipe
Old 09-01-2009, 05:38 PM   #4
VistaGT
VistaGT's Avatar
Vehicle: 06 GT
I would run it through the firewall under the dash and snake it into the vent pod from the side of the dash(there's a passage).....and no the vent pod does not require any cutting or drilling--nice piece.....used it for my aeroforce and wideband
__________________
06 Vista Blue GT 5-Speed
C&L CAI, Steeda Strut Tower Brace, UDPs, LCAs, Flowmaster American Thunder
Welded Pypes O/R H, FRPP 4.10s, Hurst Shifter, SCT w/ BRENSPEED Tune
Shorty Ant, Ford Splash Guards, Staggered Black FR500s w/ Nitto 555s
311rwhp 318rwtq on the dynojet---NEXT: Thumpr cams or blower (idk yet)
VistaGT is offline   Reply With Quote
Old 09-01-2009, 06:13 PM   #5
bigray327
bigray327's Avatar
Quote:
Right, there's a rubber grommit that some other wires go through. Punch through that. You may need to take the wheel well liner out, if you can't snake the wire to the engine bay. I use a wire snake that gets it done after about 500 tries, without removing the wheel well liner. I have since learned to keep a spare wire run through it just for pulling other wires through easily.
__________________
Old 09-01-2009, 06:44 PM   #6
Got_GT
Got_GT's Avatar
Excellent. Thanks Guys. As soon as I get my gauges in, I'll give it a shot.
__________________
Tungsten 06 GT
4.10s
Borla Stingers
XPipe
Old 09-01-2009, 07:36 PM   #7
Vehicle: 2006 Ford Mustang Pony Vert
For the mechanical boost you may need to open a slot in the inner sleeve so that the vacuum line can fit. They sometimes don't go in the same slot as the wires and might be too big.
__________________
Xcharger #020, J&M LCA/UCA; 8.8/3.55 & LPW cover; Dual GT500 take offs. Black bullitts. Shaftmaster aluminum DS. PB: 13.60 @ 100+ juiced - Xcharger: 13.42 @ 101
JimC is offline   Reply With Quote
Old 09-02-2009, 11:47 AM   #8
09Stroker
Vehicle: 2009 Mustang GT
I just drilled a new hole in the firewall near the rest of wiring in the driver's side fender well (w/ new rubber grommet). I used a wire clothes hanger to fish the wires/tubing through.
Be careful of just slipping the wires/tubing through the gap between the sleeve/vent they can get pinched. Its easy enough to reach in with a razor and cut out a small notch.
__________________
2009 Mustang GT - Paxton Novi 2200 SL, Kooks Long Tube Headers w/ Catted H, FRPP 3.73 Gears, GT500 TB, CMCV delete plugs, AFM power pipe, blow through setup, RWR Tune
531hp/462ft-lb on 9.6 lbs of boost
09Stroker is offline   Reply With Quote
2000, 2006, 50, body, dash, forums, fox, gauge, mustang, pod, pods, run, set, vent, vert, wires
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
