Go Back   MustangForums.com > Ford Mustang Tech > 2005 - 2011 Mustangs
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 09-08-2009, 11:11 PM   #1
Lethaldosage423
Lethaldosage423's Avatar
Vehicle: 05 Ford Mustang/06 Ford Mustang GT
Default Coolant Flush
Im looking into doing a coolant flush on my 05 V6
are there any bleed valves so i can get the air out the system or is it self bleeding?
__________________
05 White V6 4.0
GT takeoff m/t single muffler--GT shocks and coils--15% tint--17x8 Bullitts--GT front end
Clear corners-- 14 inch Shorty Antenna--C&L / X-Cal 3 From BAMA. (91 Race Tune)
Roush Hood scoop C/S Rear bumper
06 Black Mustang GT A/T.
Maganaflow Axlebacks--18X9.5 Black Deep dish bullitts--Chrome taillight bezels
15% Tint
Lethaldosage423 is offline   Reply With Quote
Old 10-05-2009, 06:10 PM   #2
zanypunk
13. Have your heater temp. control in the max heat position
14. Slowly add new coolant (50/50 mix of water and antifreeze) to the expansion tank until the level is at the Cold Fill Range mark (CFR).
15. Leave the expansion cap off and turn the engine on until the thermostat opens and the upper hose is going to get hot. Make sure you perform this test in a well vented area.
16. Turn the engine off and let it cool. Add more coolant to the CFR mark in the expansion tank again.
17. Squeeze the upper radiator hose to expel the air and then add more coolant mixture if necessary. I recommend replacing the expansion cap at every 100k miles.
18. Start engine and allow it to reach at a normal temp and check for leaks.
19. This is very important. Set the heater and blower controls to the max settings and check if the heater output from the air ducts is warm because that would be a good indication that all the air has been purged from the cooling system.
http://mustangforums.com/forum/2005-...ml#post6298822
Nope just follow these procedures and you should be good.
zanypunk is offline   Reply With Quote
2006, 40, bleed, body, change, classic, coolant, correct, flush, flushing, ford, fox, mustang, system, v6
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
