sound like the conditions were not very good either... 90s and 1500 elevation = poor da.
What track was it and what time of day did you run?
also post your slips that will help
but your 60s need to improve
This ad is not displayed to registered or logged-in members. Register your free account today and become a member on Mustang Forums!
__________________
Tngstn 06GT-5 spd -Vortech HO S/C-Tuned by Realspeed Auto
You can never have too much power, just not enough traction. 11.867 @ 119.35
3rd Yellow, launch. The time it takes your brain to transmit the light to the foot is about .3 of a second. Keep practicing it and you will get better: http://www.rbracing-rsr.com/nhraxtreesp.html
The time starts as soon as you break the Pre/Staged light. Some people will adjust their staging...some will bypass the prestage, and go to the stage...this will cut down on reaction time, but will increase your probability of a red light. Staging only at the prestage (if allowed), will decrease your reaction time, but cut down on ET/increase your MPH. HOW you are allowed to stage depends on your track policy.
did I read that right? You "missed 2nd gear"?
That doesn't help much, so check your linkage.
This was due to the first time jitters. And the pretty high adrenaline rush. Plus, on my trip down here I was having an issue with first and second gear not working at all. I'm pretty sure the linkage is fine, and I just wasn't relaxed. The car was on stands before I left. All bushings were lubed and I checked things that could have come loose since install.
Quote:
Originally Posted by dtuna42
get some drag radials and start them at about 15-20psi on the track
I don't plan on blowing the money on this yet......this was just for fun.
Quote:
Originally Posted by Chris07GT
What was your MPH?
It varied between 99 and 104 mph.
I was at Firebird in Phoenix. It was like 104 that day, and by my last run it was probably still 90 degrees. First run was around 7:30, last probably 10:30ish.
I will try to post some slips tomorrow once I get home.......I have a dreaded 14 hour drive first thing in the morning.
I went to the track my first time about 2 weeks ago and i sucked as well, so dont feel too bad. I was at Gateway in St Louis at midnight madness. Cool weather at night. My best run was a 14.284 @ 100.4mph. 2.360 60ft. Driver mod needed! I was so freaking nervous I just keep doing everything wrong. Including leaving the traction control on! I hope to make it back once more this season so I can take another stab at it and get some good launches in and break 13's. 14's are embarrasing.
__________________
2007 Satin Silver GT w/ Black Stripes
"Powered by Ford" poser badges
GMS Strut Tower Brace / FRPP Springs
BBK CAI / Brenspeed 87 tune / Steeda CMCV / Hurst Shifter / Mac SS A/B
297 rwhp - 319 ft/lb torque
Firebird's elevation is 1234 ft according to the track website, based on the time you went the DA was ~4000, not good conditions at all, a 14.15 would approximate a 13.5 at sea level DA.
check the pinon angle before you move the LCAs, if it is -2* to -3* you dont need to adjust it IMHO
__________________
Sorry it took so long to post these. Here are the two fastest times i ran that night. Plus the weight of the car with 3/4 tank of gas and me in the car.
Corrected for your elevation you ran a 13.7 or so. Figure in the 90 degrees + humidity, you're probably around 13.4-13.5 which isn't bad for a first go.
Like others have said your times are pretty good for your first time out and for the conditions you were running in. I'm sure with more practice and especially when the temps and humidity are lower you will see better times.
__________________
Alloy 2007 GT Deluxe Manual
Factory 3.55 Gears, 20% Tint, Roush STS, FRPP CAI & Brenspeed Tunes, 20"x9" & 20"x10" Black/Machined CS 40, GT500 Conversion, CHE LCA Poly/Rod & K-Member Brace w/ Torque Limiters, Comp XFI NSR Stage 2 Cams, Pypes LT Headers and High Flow Catted H Pipe with FRPP "Stinger" Axle Backs
