Go Back   MustangForums.com > Ford Mustang Tech > 2005 - 2011 Mustangs
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 10-29-2009, 06:59 PM   #21
miloman
miloman's Avatar
Vehicle: 2005 GT
What should my ET be at when I'm running on a strip at about 4300 feet and between 50-70 degrees?
Where are you guys finding these calculators?
__________________
Quote:
Originally Posted by ImpOnFire View Post
i always swallow
miloman is offline   Reply With Quote
Old 10-31-2009, 04:10 PM   #22
robs
robs's Avatar
Vehicle: 06 GT Coupe
Don't want it too cold... I just got back from Gateway... High 40's, low 50's in temperature. Rained all week. Track was total grease... Actually had to peddle 2nd gear after lighting 'em up...
Best run was a 14.1 @ 100, but there was no way to launch as the track had NO grip. 60' times were 2.3 as I literally had to walk away from the line before punching it...
New LCA's show up Wed to help with wheel hop.
__________________
69 Mach I (Since 5/78) / 06 GT (Since 5/09) Boomtubes, sequential lights, Bama 91 Torque tune, Hurst billet shifter, J & M LCAs. Home brew lowering brackets next.
Life is better at WOT!!
robs is offline   Reply With Quote
Old 10-31-2009, 07:23 PM   #23
Steve68Cougar
Vehicle: 2008 Mustang Bullitt
The conversions factors are probably coming from NHRA. They have conversion factors for all of the NHRA sanctioned tracks. Do a Google search and you should be able to find one online (make sure it's the Stock/SuperStock factors and not the index class factors). I took my car out to Great Bend, KS a couple of months ago and ran a 13.96@100.7. The altitude factor put it at a 13.66@102, which doesn't account for the weather. A lot of bracket racers will have weather stations that will get you a Density Altitude reading. If you use the factor for that number then you can get what your car would THEORETICALLY run at 0 altitude and standard conditions. I emphasize theoretically because that assumes your 60' will improve that much, which is not always the case. The weather was really crappy the night I had my car out and the DA was over 3500ft. It equated to something around 13.45@103.
Steve68Cougar is offline   Reply With Quote
14, 14th, 1500, 2009, 427r, 50, 57, density, fox, mile, mustang, quickest, ram, roush, specs, speed, stock, time
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
