Go Back   MustangForums.com > Ford Mustang Tech > 2005 - 2011 Mustangs
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 09-12-2009, 09:33 PM   #1
JDWalton
Vehicle: 08 Mustang GT
Default Bullitt suspension differnece?
Hey guys, I got the GT, my moms got the Bullitt. Shes been asking me what speficaly is different about the suspensions. I told her I assume she probably has higher rates springs and better shocks /struts, but were trying to figure out for sure, so as I help her upgrade parts, were not going after something thats already pretty good from Ford before we get other items that will be better. Thanks for the help.
__________________
My cars pics, vids and mods
To Lazy to update pic again right now:
WeaponX COPs, BBK 62MM Throttle Body, Stephs Catch Can, Spec Stage 3 clutch, 4.10 Gears, 18X9 up front, 18X10 in the rear, Eagle F1 Supercars
In Route: CDC Classic Chin - C/S Style, 1/4 Louvers
JDWalton is offline   Reply With Quote
Old 09-12-2009, 11:00 PM   #2
socalwrench
socalwrench's Avatar
Vehicle: 2008 Mustang V8
I have discussed this in great detail for several months. What KC and myself determined was that the Bullitt Mustang suspension came with slightly lower springs (and barely stiffer) and stiffer dampers. The front springs are the lowest standard GT springs and the rears are .5" lower than the standard GT springs (remember, there are several different springs that Ford uses according to the weight and options of the car). The dampers are special to the car, but are NOT the Ford Racing ones. I can't tell you that exact compression and rebound rates, but they are higher than the standard GT ones.
Bottom line, the Bullitt sits .5" lower in the rear and uses stiffer dampers.
I will dig up the part numbers if you wish.
__________________
Greg - Owner/Operator: GRH Performance
socalwrench is offline   Reply With Quote
Old 09-12-2009, 11:23 PM   #3
wolfie
Vehicle: 2008 DHG Bullitt
Hey,
Head over to IMBOC.com. All the information you want about the Bullitts is there. While you are there maybe register your Bullitt.
regards
Wolfie
__________________
'08 DHG Bullitt #3307
MRT Hood Struts
WebElectrics Sequential Lights
35% Tint
wolfie is offline   Reply With Quote
Old 09-12-2009, 11:26 PM   #4
Tylus
Tylus's Avatar
Vehicle: 2009 Bullitt #6451
what he said basically
good luck trying to figure out the spring codes. it has been kicking peoples behinds for quite some time.
nobody really knows, and Ford Tech is useless for any help. Everybody agrees the Bullitt sits lower..and that is about it.
http://www.imboc.com/forums/showthread.php?t=171961
by comparing spring codes to radio type, the general consensus is that the Shaker 1,000 cars have softer springs, and the regular/shaker 500 are harder springs.
__________________
2009 Bullitt
3.73 Gears | FRPP CAI & Tune | FRPP Strut Tower Brace | Hurst Short Throw
Blackout Panel | Billit 9mm Door Locks | UPR Fuel Door | Custom Shelby Hood Pins
Currently deployed...see y'all on the flip side
Tylus is offline   Reply With Quote
Old 09-13-2009, 11:08 AM   #5
JDWalton
Yeah, this is what I have heard in other places as well, all though the .5" lower rear is something I hadn't heard before. Basically everyone seems to come up with thinking the suspension is just set up slightly stiffer but cause of the vagueness of any response from Ford it is hard to prove or get the actual specifications.
However this leads me to another thought now. I would think Ford used the same rear axle as the GT, aside for the gearing. If the mount on the axle is the same and Ford lowered the rear end, wouldnt these cars greatly benifit from LCA relocation brackets, even more so then a stock height GT?
__________________
Old 09-13-2009, 11:26 AM   #6
socalwrench
Well, since you guys seem to be hungry for more information.
The spring tags for the Bullitt are FR: Orange (code: SGF), RR: Light Blue (code: SAR). The part number for the springs are FR: 6R33-5310-GA and RR: 5R33-5560-AC
I can't seem to find the damper part numbers.
RE: Rear Axle
The rear axle is the same 8.8" 31 spline unit that the GT and GT500 uses. The Bullitt came standard with the 3.73 gears, which was/is optional on the GT models. .5" isn't much of a difference in ride height. Do you know how much a full tank of gas weighs compared to a 1/4 tank? Ever had four people in the car at once? My point is, your ride height can change by as much as a .5" during normal use, so there's no need to change the LCAs. However, it is widely accepted that swapping out to stronger LCAs (with stiffer bushings) helps improve overall traction. As far as relocating/changing the angle of the LCAs, I wouldn't bother either.
__________________
Old 09-13-2009, 11:32 AM   #7
JDWalton
Its all right man, no need to look up the codes, not gonna be doing anything with them.
As for the brackets though, its widly accepted that if you lower the static height of the car through suspension mods that you want to add the brackets to restore the mechanical advantage they gain at the angle there in. Granted people are usualy doing more then a .5" drop but then again I have seen people add them to stock height vehicles to generate more of a lifting affect for there straight line driver.
__________________
Old 09-13-2009, 11:38 AM   #8
socalwrench
Well, the relocation brackets change the instant center of the car- for more weight transfer. You may try it, but I'm not about to change any of the rear suspension angles at this point.
__________________
Old 09-13-2009, 01:46 PM   #9
Tylus
Tylus's Avatar
RE: Rear Axle
the 8.8 used in the GT is different from the one used in the Bullitt/GT500
different gearsets and axleshafts. You have to use the GT500 gears and Install Kits on a Bullitt.
several guys have found out the hard way that the normal GT 8.8 stuff isn't applicable. Externally, everything should be darn near identical though
http://www.imboc.com/forums/showpost...1&postcount=44
__________________
2009 Bullitt
Old 09-13-2009, 02:58 PM   #10
JDWalton
nice, thanks for the info. I didnt even know the 3.73 was optional at that time for the GT as well, the only option I was able to find after looking around (unless maybe you were going to special order one and wait) was with 3.55 that I got, then later replaced anyway with 4.10. But I'll take a look at hers anyway and make sure the arms are the same length and see what were going to do from there.
__________________
2010, blue, bullit, bullitt, difference, kit, light, mods, mustang, number, part, ride, spring, springs, strut, suspension
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
