Go Back   MustangForums.com > Ford Mustang Tech > 2005 - 2011 Mustangs
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 09-17-2009, 03:32 PM   #21
Art161
Art161's Avatar
Vehicle: 2007 Mustang GT
Quote:
Originally Posted by JDWalton View Post
yeah, newbie not meant in any way insulting here, just making a point that we have all been new at something and the smart ones ask questions before they just jump in. Did you find the post I was talking about? On the manifold there are a few nuts that have like 2" of threading sticking up that Ford left for like push on rubber cable holders. Just pull the cap off and I think that would be a great ground point for you.
No offense taken at all to the word newbie. Yeah, I don't want to be trying to figure out what is grounded and what is not if I am stranded--particularly since I don't carry an ohmmeter in the car.
When I first came on the forum I couldn't figure out what the big deal was about FI. Doesn't everybody have FI? Terms have changed over the years. FI used to mean fuel injection. I also couldn't figure out what 3V meant. V used to be used to indicate the number of venturies (or barrels) in a carburetor. Never heard of a 3V carburetor.
I haven't checked for the post you mentioned yet. I missed that when I was trying to find a good ground point. The best I did find was mentioned in this thread. That's the connectors around the strut. The top of the strut is apparently not grounded, but the fasteners are, sort of. I was only using a sharp pointed probe on the ohmmeter, and sometimes I would get an indication of ground, and sometimes not. I figured that with the jaws on a jumper cable, it would be okay as a ground, but maybe there was something better. Perhaps the nuts have some coating on them, but moving the jaws around should get rid of that real quick!
Thanks again.
__________________
2007 Mustang GT Coupe Premium
High Performance White/Dark Charcoal Leather
Automatic Transmission
Rear Spoiler Delete
Interior Sport Appearance Package
MGW EJECT Power Point Plug
Words to live by--Never insult seven men if you are only armed with a six-shooter.
Art161 is offline   Reply With Quote
Old 09-17-2009, 05:15 PM   #22
Norm Peterson
2008 Ford Mustang
Norm Peterson's Avatar
Vehicle: 2008 GT Premium
There are a couple of specific chassis grounds in front of the windshield washer fill tube. There are also a couple of unpainted body bolts nearby that returned zero ohms with respect to BAT-, one where the switch that signals hood close status and another nearer the pass side headlamp. Useful if your cables can grip someting that small.
Closer to the battery and attached to a plate inboard on the passenger side strut tower you'll find a main ground. If you use that one, I'd consider making my final (ground) connection on the other vehicle instead, away from its battery.
Like you, it took me a little while to recognize the abbreviation "FI" for its current meaning (and sometimes it does seem like everybody else has it but me).
Now, just because I remember stuff like this, Holley actually did make a 3-barrel carb, Model 3160, in 950 cfm and maybe in 1050 cfm. Two normal-ish primaries plus a single hogged-out flat-oval secondary that completely did away with the metal in between the usual round secondaries. Late 1960's, I think.
Norm
__________________
08 GT Premium Black/Light Graphite, stick, un-FStock
weenie-EP 626/V6/stick, Prepared just enough, sometimes
Norm Peterson is offline   Reply With Quote
Old 09-17-2009, 05:21 PM   #23
AK_Kayaker
How about make the last connection on the other vehicle, and just clamp onto the negative terminal on your s197.
__________________
2007 Vista Blue GT, 5sp, Rgtp | born 04/26/2007
Pypes MM | JLT2 | Xcal3
AK_Kayaker is offline   Reply With Quote
Old 09-17-2009, 05:33 PM   #24
tx_zstang
tx_zstang's Avatar
Vehicle: 2005 Mustang V6
Always positive-to-positive on battery posts; negative post on first car, AWAY from the battery on the last connection on the other car.
Try connecting the ground to a car with a shorted alternator, and you'll get all kinds of sparks, enough to ignite any nearby fumes!
I usually try to ground to a mounting bracket, like alternator or something solid connected to the block.
__________________
Mike - 2005 V6 Automatic, 300+ RWHP; 12.79 1/4
Vortech supercharger (SOLD); 180*T-stat; PLX Wideband O2, VEI digital gauges, SOS pillar pod; JBA 9MM wires; Mac LT headers, high flow cats; 8.8 w/3.73s, LPW girdle, alum driveshaft, 3000rpm TC; Steeda UCA, panhard bar, brace; CHE lca's & reloc brackets; Steeda Sport springs, Tokico DSpecs.
.. "Sally" is getting "balls" ...forged V8 swap in progress
tx_zstang is offline   Reply With Quote
Old 09-17-2009, 08:23 PM   #25
Art161
Art161's Avatar
Quote:
Well, the recommended way of doing things is to connect the jumper cables directly to the battery terminals of the car giving the jump, and to connect to a ground away from the battery on the car receiving the jump. In the example I gave, I was the jumpee, not the jumper. I guess the reason for the recommended hookup is to ensure that there is absolutely no voltage drop between the jumper battery terminals and the jumper cable. I would also be relying on the other driver to know where a good ground is on his/her car.
__________________
Rear Spoiler Delete
Old 09-18-2009, 05:12 PM   #26
157db
Got Troy'd
157db's Avatar
Vehicle: 2007 Pony Package
Quote:
Originally Posted by Boozshey View Post
If you connect a dead battery that has a bad cell directly to a good battery. The good ]battery has a chance of getting that same bad cell. It's like a cold for batteries.
I call BS.
Lets see some proof of this claim.....
Ground to the alternator body FTW....
And yes, batteries do explode.
Search YouTube and sees fors yours selves....
Just touch the bumpers together of the two vehicles
and a negative connection is not needed.....
__________________
NON PUMKIN JACKER
Oh yeah, I forgot Norm was God on here.
Give me a break!!!
Quote:
Originally Posted by Norm Peterson View Post
<rises to the bait>
. . . Definitely not God.
Norm
157db is offline   Reply With Quote
Old 09-18-2009, 09:02 PM   #27
Nuke
2007 Ford Mustang
My Garage
Nuke's Avatar
Vehicle: 2007 GT
Send a message via AIM to Nuke Send a message via Yahoo to Nuke
__________________
Rick
07 GT Prem: Alloy, MT, 3.55's, Steeda CAI w/Brenspeed tunes, FRPP Stingers, 275/40/18 Goodyear Eagle F1 A/S on SVT Cobras (OE GT500's), 14" shorty, Wheelskin side scoops & qtr window louvers, A-H rear window louvers, SHR honeycomb blackout panel, Sequentials, Hella Optilux Extreme XY fogs, Silverstars
06 V6: Legend Lime, Pony Package, 14" shorty, Sequentials, Hella Optilux Extreme XY fogs, Silverstars
Nuke is offline   Reply With Quote
Old 09-18-2009, 11:07 PM   #28
JDWalton
Vehicle: 08 Mustang GT
Quote:
Originally Posted by 157db View Post
I call BS.
welcome to page 2!
__________________
My cars pics, vids and mods
To Lazy to update pic again right now:
WeaponX COPs, BBK 62MM Throttle Body, Stephs Catch Can, Spec Stage 3 clutch, 4.10 Gears, 18X9 up front, 18X10 in the rear, Eagle F1 Supercars
In Route: CDC Classic Chin - C/S Style, 1/4 Louvers
JDWalton is offline   Reply With Quote
05, 2007, compartment, engine, find, ford, forum, good, ground, grounding, jump, location, mustang, start, starting
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
