If you are receiving a jump start, what is a good ground point in the engine compartment for attaching the negative clamp on the jumper cable?
Thanks.
This ad is not displayed to registered or logged-in members. Register your free account today and become a member on Mustang Forums!
__________________
2007 Mustang GT Coupe Premium
High Performance White/Dark Charcoal Leather
Automatic Transmission
Rear Spoiler Delete
Interior Sport Appearance Package
MGW EJECT Power Point Plug
Words to live by--Never insult seven men if you are only armed with a six-shooter.
why wouldnt you just attach it to the negative terminal on the battery.
Because the final connection often causes sparks. The dead battery has probably outgassed quite a bit. The sparks can cause the battery to explode. It usually doesn't, but why take the chance?
__________________
Rear Spoiler Delete
Never heard of anyones battery exploding during a jumpstart, thought I dont doubt its happened at some point. I would think as long as your properly ventilated you shouldnt have to worry about it. Arent our batteries sealed anyway?
__________________
2007 Satin Silver GT w/ Black Stripes
"Powered by Ford" poser badges
GMS Strut Tower Brace / FRPP Springs
BBK CAI / Brenspeed 87 tune / Steeda CMCV / Hurst Shifter / Mac SS A/B
297 rwhp - 319 ft/lb torque
If you'd ever had a battery explode on you, you wouldn't be looking for reasons why they might not.
It wasn't from a jump start, but unless my wife managed to throw it away before I could add it into my "garage wardrobe", I've got a nicely splattered jacket I could take a picture of. Some things you don't forget . . .
No, they are not sealed, unless Motorcraft changed the design in the past six months. They have caps on the top that can be removed so you can top up the water level and check the specific gravity. Even the sealed batteries have vents that allow gas to escape under certain circumstances.
__________________
Rear Spoiler Delete
Just stick it on one of the strut mounts. There is a ground that goes there and they should be touching bare metal. Key is to get something touching bare metal really. Just dont connect it to the battery. I also hear jump starting can hurt the voltage regulator in the alt, but I have only heard that. I have always heard that bump starting the motor can hurt things too.
I would say, charge it if you can and then start it.
__________________
2005 GT Mustang - Mineral Grey - 5 Speed - Shaker 1000 - Black/Red Leather Interior - Steeda CAI - Bamachips Tune - Pypes Violator A/B - Saleen Short Shift Block - Eibach Pro Kit - DD Bullits w/ Sumitomo HTRZII's - Ford Racing 4.10's
If you connect a dead battery that has a bad cell directly to a good battery. The good battery has a chance of getting that same bad cell. It's like a cold for batteries. It's bad. So usually one car will have both pas and neg cable on battery and the other car pos on battery and the other grounded someplace else.
I usually try the strut first though.
__________________
All I want for Christmas if for people to stop saying "Factory Freak"!!!
What Norm said about the spark igniting fumes from a venting battery is a real and serious risk.
But this statment here just does not make any sense, unless the ground from the battery is bad anyway, a dead battery would apply a equal drain across the rest of the system, as it is directly connected.
Sorry for the hack job on this picture, but you get the idea.
I would try one of the posts on the back end of one of the screws that holds the intake manifold down. Unpainted, untreaded surface grounding directly to the block.
__________________ My cars pics, vids and mods
To Lazy to update pic again right now:
WeaponX COPs, BBK 62MM Throttle Body, Stephs Catch Can, Spec Stage 3 clutch, 4.10 Gears, 18X9 up front, 18X10 in the rear, Eagle F1 Supercars
In Route: CDC Classic Chin - C/S Style, 1/4 Louvers
