Go Back   MustangForums.com > Ford Mustang Tech > 2005 - 2011 Mustangs
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 09-19-2009, 07:09 PM   #1
ThaiCobra
Default Driver's side door leak
I have heard these water leaks are pretty common on S197's.
After is has rained when I open the driver's side door there is water on the door sill and a little bit within the cabin of the car.
What is likely causing this? Is it something I can fix? If not what should I say to the Ford mechanics?
My once very fresh smelling interior now smells like stale water, it's almost humid inside.
ThaiCobra is offline   Reply With Quote
Old 09-19-2009, 07:46 PM   #2
sonicmetalicS197
sonicmetalicS197's Avatar
Vehicle: 2005 V6 S197
I have the same issue but it's fairly dry here and the mustyness goes away in an hour or so for me, so I haven't really looked into it much. However I can see it being an issue for others. I think it's the rubber lining along the door not sealing well. Maybe inspect/replace it.
__________________
SCT Xcal III w. Bama 93 Race tune, K&N CAI,
Pypes mid pipe duals w. custom H, 3.73 pluss T-lok, DynoTune 75 shot wet nitrous
____________________________________________
Tokico D-spec Shocks/Struts, Eibach Pro-kit,
Steeda LCAs, LCA relocation brackets, Adj Pahard bar, Adj UCA, 18x9 Chrome FR500s wrapped NT05s in Fully sound deadened cabin
sonicmetalicS197 is offline   Reply With Quote
Old 09-19-2009, 09:16 PM   #3
pascal
S197 Section Modder-ator
pascal's Avatar
Vehicle: 06
There are long square rubber plugs at the bottom of the door on each end...
Take those f#ckers off! Leave those holes open.
It won't collect water and build up until it comes out from the door panel, thus, leaking inside your car.
__________________
pascal is offline   Reply With Quote
Old 09-20-2009, 04:24 AM   #4
ThaiCobra
thanks pascal. I will do that.
They are not neccesary at all? Why does Ford put them in?
Old 09-20-2009, 09:39 AM   #5
Nuke
2007 Ford Mustang
My Garage
Nuke's Avatar
Vehicle: 2007 GT
Send a message via AIM to Nuke Send a message via Yahoo to Nuke
There's a TSB for the water leak issue which is NOT associated with the door seal or lower door drain plugs. If your carpet is wet by the passenger kick panel, then you need to be aware of the TSB. This problem will eventually corrode the connections at the SJB and you'll think your car is possesed.
__________________
Rick
07 GT Prem: Alloy, MT, 3.55's, Steeda CAI w/Brenspeed tunes, FRPP Stingers, 275/40/18 Goodyear Eagle F1 A/S on SVT Cobras (OE GT500's), 14" shorty, Wheelskin side scoops & qtr window louvers, A-H rear window louvers, SHR honeycomb blackout panel, Sequentials, Hella Optilux Extreme XY fogs, Silverstars
06 V6: Legend Lime, Pony Package, 14" shorty, Sequentials, Hella Optilux Extreme XY fogs, Silverstars
Nuke is online now   Reply With Quote
Old 09-20-2009, 10:24 AM   #6
05 Mustang
2005 Ford Mustang
05 Mustang's Avatar
Vehicle: 2008 GT500
good tip!
__________________
2008 Convertible GT500
Torch Red w/Silver Rocker Stripes
Alcoa Super Snake Rims
JLT CAI
2.6 Metco Pulley
Metco Double Bearing Auxillary Pulley
Borla Stingers
Eibach Pro-Kit
#415 of 463 Manufactured in Torch Red
#1855 of 2070 Convertibles
05 Mustang is offline   Reply With Quote
Old 09-20-2009, 12:17 PM   #7
pascal
pascal's Avatar
Vehicle: 06
Ford put them there so you don't see a plain hole, it's a visual thing I guess.
Doesn't matter, they are useless anyhow and you're better off without them, more air goes inside your door and dry things up when wet, thus, retarding rust issues.
I picked up a Shelby vert at my local dealer that was destined to Belgium...
It was on their lot at an uphill angle with the front facing down for about 2 weeks before I took it to my shop for mods.
Guys, this is nuts! it had 4 inches of water on the floor boards!
Right below the pedals on the left side and below the SJB on the right side.
Another week sitting there, and it would have been all over for that electronic device, lol.
The manager couldn't figure out WTF was going on and start saying the top was leaking
I told him to move the f*** over and watch...
I simply took them plugs out and water was coming out like a faucet for about 5 minutes.
I shook the door back and forth on one side and sure enough, the water was coming out from below the door panel. Those doors prolly were filled with a couple of gallon of water each.
So there you go, some Ford engineer fag wearing a butt plug must have thought it would be cool to put unwanted plugs on our cars.
__________________
Old 09-20-2009, 12:49 PM   #8
rford426
Vehicle: 2005 Mustang GT
^^pascal your the man haha mine has done this a couple times shes usually in the garage so when I get her back these plugs are gone!!
__________________
2005 Black GT Manual
Steeda CAI-SCT XCAL-Pypes O/R X pipe-Pypes Mid Mounted M80s-Red Top OPTIMA-HurstSTS-Tein Tech S-AVIC f900bt-Back up Camera-20" Black Chrome FR500s-GT500 FRONT/REAR-Factory GT500 6k HIDS-3k HID Gt500 fogs-
303rwhp/319tq
rford426 is offline   Reply With Quote
Old 09-20-2009, 01:10 PM   #9
pascal
pascal's Avatar
Vehicle: 06
Good man.
Do et!
__________________
Old 09-21-2009, 10:19 AM   #10
mmdpg
I had a few drips on the door threshold. If you take the door panel off you will see the vapor barrier/ water shield is not fully sealed to the door. Buy some sealer made for this application (never really dries, stays sticky) and re-seal the vapor shield to the painted part of the door frame and no more drips.
mmdpg is offline   Reply With Quote
05, 2000, board, door, drain, drivers, floor, ford, leak, leaking, leaks, mustang, plug, side, sides, water
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
