stuck TCS,Low brake fluid, and stuck e-brake light problems
Hey guys I did a search and thought that I found what I needed but it turns out that I still have the problem. The other day I got in my car to go home and when I cranked my car it said on the message board low brake fluid. So I was like ok thats weird I just checked it a few days prior. Then I noticed that my traction control light was on on my dash (the car with the tire track marks). So I looked over at my TCS button and it said off. I hadn't even pushed it yet. So I tried to push it and nothing happened. So I then put the e-brake down to start on my way home and noticed that the e-brake light on my dash wouldn't go away, even after several attempts of going up and down with the handle. So I get on here and search and found a thread were a guy had all the same problems that just popped up as well. Towards the end of the thread another person chimed in and said that he had the same problem and said that it was a TSB on the mustangs. It was TSB 19296 which came up as a defective ground No. G101 in the abs circuit. So I take this info to my dealer and they check it out today and said that nothing was loose or defective. But of course the morning I take it to them the lights had went back to normal. So when I got back home and later tried to go somewhere the lights came back on just like they did before. I have no clue what to do now. I was wondering though how would you test for a defective ground? I guess I am going to take it to another dealer and have them check it out. I am really nervous with the dealerships touching my car because it is so moddifed. I don't want them to mess something up. I do make sure to tell them what not to touch or do. What a pain in the butt this is becoming. I was just curious if anyone has had this problem as well, or if anyone could help. Thanks
heres the other thread on the subject http://mustangforums.com/forum/2005-...ing-brake.html
This ad is not displayed to registered or logged-in members. Register your free account today and become a member on Mustang Forums!
Did you re-check your brake fluid level? The brake warning light serves two functions. It indicates when your parking brake is on and also indicates when your brake fluid level is low. The TCS relies on the brakes to work. Just some thoughts.
__________________
2007 Mustang GT Coupe Premium
High Performance White/Dark Charcoal Leather
Automatic Transmission
Rear Spoiler Delete
Interior Sport Appearance Package
MGW EJECT Power Point Plug
Words to live by--Never insult seven men if you are only armed with a six-shooter.
Did you ever get this fixed? Mine is doing the exact same thing now. I checked and cleaned the g101 point. Did you have a bad speed sensor or something else?
I just experienced this same problem yesterday on my car. I just finished installing a paxton HO kit but never touched the brake system this past weekend. I do have a line lock installed but that was done a year ago. Where is g101 contact point everyone is talking about?
__________________
08 GT 5 Speed
3.55
C&L CAI
Bama 93 Race
Pypes Mid Muffler
Pypes O/R H
BMR LCA
Spydershaft
K-Memeber Brace w/Limiters
Steeda Tri-Ax
Whipple HO Coming Soon!!!
Here's the link to the diagram: http://www.justanswer.com/view_image...ang_Ground.png Let us know how it goes. It fixed all my problems by cleaning it up and then replacing. The diagram is right behind the headlights, and can be accessed from both the top and bottom of the car. And then when you finish make sure to disconnect the battery for a 1/2 hour.
well they checked that ground at the dealership first but it wasn't the problem. So they replaced my abs module and all was fine for a week then it did it again. But it only did it once and hasn't happen again. If it happens again It's going back to the dealer.
