Go Back   MustangForums.com > Ford Mustang Tech > 2005 - 2011 Mustangs
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 11-01-2009, 06:48 PM   #11
ShadowPony
Vehicle: 2006 Ford Mustang V6 Premium w/ Pony Package
Quote:
Originally Posted by Nuke View Post
Disconnect the battery and, if convenient, attach a battery tender. It MAY prevent a weak battery from dying during the storage period. The OE Motorcrap batteries are NOT the best.
And if you can, put a moisture barrier between the tires and concrete if you'll be in storage more than a few months.
And 1 or 2 dryer sheets tossed into the cabin will keep it smelling "purty".
I'm storing my '06 Mustang and I've gotten two different answers to this question. Should I disconnect and remove the battery for a 5 month storage or just leave it alone and hope for the best? One guy says if I pull it, it will clear the computer and wipe out my performance tune and someone else says it will be just fine. The bad thing is where I'm storing it does not allow periodic starts and idles in the building and it doesn't have power turned one both do to liability worries. So I can't plug in a battery tender.
When you're talking about a moisture barrier do you mean plywood, visqueen, or linoleum? Also, would you over fill the tires or just go with the recommended pressure?
Also, i'd also been told to stuff foil in the tail pipe to keep critters out and to also block of the air intake to reduce moisture.
My biggest concern is the battery though.
ShadowPony is offline   Reply With Quote
Old 11-01-2009, 07:32 PM   #12
SaddleUp
2006 Ford Mustang
My Garage
SaddleUp's Avatar
Vehicle: '06 GT
Doesn't it suck storing the car away? I'd love to live somewhere I could drive it year 'round. I'd make the gt500 my daily driver.
__________________
SaddleUp is offline   Reply With Quote
Old 11-01-2009, 07:39 PM   #13
Nuke
2007 Ford Mustang
My Garage
Nuke's Avatar
Vehicle: 2007 GT
Send a message via AIM to Nuke Send a message via Yahoo to Nuke
Battery wise, I'd disconnect it, otherwise the parasitic current draw will eventually drain it. If possible, try to ensure it's charged before putting it in storage. Best thing would be to pull it and keep it somewhere cool at home with either a tender on it or on a periodic charge.
For a moisture barrier, sheet sof plastic, carpet, even cardboard at least under the tires will slow down tire rot. If you can, roll out a sheet of plastic and drive the car over it. It's not necessary but it helps.
Crumpled aluminum foil or some steel wool will keep critters from climbing into the tailpipes. They usually don't mess with steel wool. It wouldn't hurt to block the intake also. Just remember to remove all those items.
__________________
Rick
07 GT Prem: Alloy, MT, 3.55's, Steeda CAI w/Brenspeed tunes, FRPP Stingers, 275/40/18 Goodyear Eagle F1 A/S on SVT Cobras (OE GT500's), 14" shorty, Wheelskin side scoops & qtr window louvers, A-H rear window louvers, SHR honeycomb blackout panel, Sequentials, Hella Optilux Extreme XY fogs, Silverstars
06 V6: Legend Lime, Pony Package, 14" shorty, Sequentials, Hella Optilux Extreme XY fogs, Silverstars
Nuke is offline   Reply With Quote
Old 11-01-2009, 07:40 PM   #14
Nuke
2007 Ford Mustang
My Garage
Nuke's Avatar
Vehicle: 2007 GT
Quote:
C'mon, Shella. Pack up the kids and let's runaway. You pick the "warm" state. We'll just also need room for 5 vehicles and a boat.
__________________
Rick
Old 11-01-2009, 07:47 PM   #15
SaddleUp
2006 Ford Mustang
My Garage
SaddleUp's Avatar
Vehicle: '06 GT
My next house is going to be a garage! I'd need a couple more drivers and a trailer to get it done. A 4-car garage house isn't a easy thing to come by..... I hope you're going to make really good money. We've got expensive toys.
__________________
Old 11-01-2009, 08:07 PM   #16
Burrosito
Burrosito's Avatar
Vehicle: 2006 Ford Mustang GT
If you two can deal with the heat, you won't have to worry about storing your car down here in FL :P
__________________
Stock!
Burrosito is offline   Reply With Quote
Old 11-01-2009, 08:41 PM   #17
mygt500
Multi-Tasking Moderator!
mygt500's Avatar
Unplug the battery and the car will be fine....if you disconnect your home computer will you not have everything still stored on there from before? Of course....this car is the same way. The only thing that will be lost are radio stations and the adaptive learning and thats a good thing
Moisture barrier is like plastic you use to cover your furniture when painting. You can get it for cheap at Lowe's or Home Depot or Sam's Club or Costco. Should be 8 mils thick at least.
Covering up the pipes will help and a few moth balls around the car.
and yes I over inflate the tires.....8-10 psi over recommended (so 40 psi for mmine)
__________________
2006 Mustang GT with Cervinis Kit
Whipple Crew member
H.O. S/C 465 RWHP and 440RWTQ
First online article about my car! check it out!
http://www.examiner.com/examiner/x-8811-Detroit-Sports-Car-Examiner~y2009m5d30-Jason-McGuires-2006-Mustang-GT
http://www.cardomain.com/ride/3342086
www.mocsem.com
mygt500 is offline   Reply With Quote
Old 11-01-2009, 09:04 PM   #18
nineinchnail1024
Vehicle: 2006 Mustang GT
I regulary store my car for periods ranging from a few days to four months. I have an optima red top battery that stays attached to the car. I keep the hood up in the garage with a float charger attached to the battery to offset parasitic draw (I picked up the float charger from Harbor Freight for six bucks). I've never had a problem cranking her up. My tires are at 35psi when in storage, and I park the car on a rubber floor mat. I change the oil every Jan. 1st and July 1st, regardless of mileage or use. That's pretty much it.
__________________
Whipple Crew-10psi-Spec II-BMR LCAs-BMR sway bar delete-Spydershaft-M/T 26x11.5x17-Hurst-Prothane Mounts-PMP Line locks-Flows-Thump_rrr-Moroso separator-11.39@119mph
Daily Driver-2010 Prius-52.3mpg since new
Beater-1995 F150 XL-302 5spd
nineinchnail1024 is offline   Reply With Quote
Old 11-01-2009, 10:10 PM   #19
ShadowPony
Thanks a bunch for everyone's help!
-sp
__________________
05, battery, convertible, gt, mustang, mustangwinter, pa, preparation, s197, storage, storing, winter
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
